Like Tree1Likes
Old 05-08-2011, 05:05 AM   #2506
Originally Posted by Rotax125 View Post
Is it just me, or does the Protoform LTC-R 190mm body not fit this chassis?
I just finished painting mine,and its too short in the wheelbase..
Lucky i had a Speed 6 lying around.
That's strange, i didn't had any issue fitting the ltc-r on my tc6 (well you have to put a pair of washers under front body posts to raise them a bit, but that's it)....
do you have any picture?
Fastfreddy74 is offline   Reply With Quote
Old 05-08-2011, 07:37 AM   #2507
Trader Rating: 77 (100%+)
I fit mine and drove with it yesterday, no issues.
goin2drt is offline   Reply With Quote
Old 05-08-2011, 07:42 AM   #2508
Default Found religion
Wow. Took my TC6 out for the first time yesterday and what a fun day. I love that car. I am a rookie and coming over from a TCX which was the first car I owned.
The TC6 was WAY more stable on the straight, turned like a dream in the infield section and so much fun to drive. I have to say it was not a set up issue either. Both cars had awesome set ups from really great drivers.
Lastly and most important...WAY MORE DURABLE. I broke one part yesterday and it was my fault I did not tighten down a screw enough which caused the camber block to break.
Lots of fun, can't wait to get out again.
Old 05-08-2011, 07:44 AM   #2509
Timbulb's Avatar
It's just you.
Timbulb is offline   Reply With Quote
Old 05-08-2011, 08:18 AM   #2510
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Molala4 View Post
would the end side of the gear rub against the front belt? this is what is happening to me... i have already lowered the front spool...it is still the case..........i am using kawada 46 pinion and speedmind 100 spur
It's VERY close. It may barely touch if at all and not enough to do any damage to belt.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 05-08-2011, 11:37 PM   #2511
Trader Rating: 23 (100%+)
Here is a pic of what i mean with the LTC-R body not fitting..
ox
Rotax125 is offline   Reply With Quote
Old 05-08-2011, 11:39 PM   #2512
Yet here is my Speed 6, perfect.
ox
Old 05-09-2011, 03:51 AM   #2513
I'm not the most perfect, but here it is:
jorgesimes is offline   Reply With Quote
Old 05-09-2011, 04:23 AM   #2514
JRXS_chris's Avatar
Rotax, notice how much less material there is between the arch and the rear bumper on Jorge's shell.
You must cut the rear arches out when the shell is mounted so you get the correct position of the rear wheels.
I always dab some grease on the end of the rear axle then push the shell in to leave a mark for the centre of the wheel.
JRXS_chris is offline   Reply With Quote
Old 05-09-2011, 07:46 AM   #2515
CristianTabush's Avatar
The problem with some of these bodies is that you must shave down the front bumper a bit, otherwise you will not be able to push the body all the way back. This looks like it is exactly what happened with yours. Without shaving the front of your bumper, the bumper pushes the front of the body. I usually use some 400 Grit sandpaper to sand it down and then I smooth it out with 600-800.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 05-09-2011, 08:59 AM   #2516
Verndog's Avatar
Ding ding...we have a winner! It helps to sand the top front edge down and put a radius to break the corner for some bodies as well.
---Team Hoarders---
Old 05-09-2011, 09:35 AM   #2517
Keven Hebert car at ETS in Austria:
Old 05-09-2011, 07:55 PM   #2518
is that a gear diff in the front? what is the diferents from the spool
f1o7x9 is offline   Reply With Quote
Old 05-09-2011, 08:11 PM   #2519
How do I get those blue screws? Those are sweet.
Old 05-09-2011, 08:34 PM   #2520
Verndog's Avatar
Practice lots, win lots, go pro, win lots more, then their free.
---Team Hoarders---
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
