Like Tree1Likes
Old 04-29-2011, 10:19 AM   #2401
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Originally Posted by Brian McGreevy View Post
That wouldn't do much. The mount itself would have to have those ears integrated into it.
+1 the mounts will still shift
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-29-2011, 10:26 AM   #2402
Verndog's Avatar
Trader Rating: 16 (100%+)
Originally Posted by wtcc View Post
Here you are:
Yes it will increase the width, but with thinner shims the width will stay the same, or am I wrong?
And one thing: It is not from AE. I measured every part several times and build it in 3D. Took some time and wasn't fun in the end, but after the TC5 had so many design failures when using LiPo I want to be prepared...
Wow...you must have over 60 hours into that. Did you use a CMM to measure or just layout on a rock with height gage and calipers?
If they are still effective down to 1mm thick you could keep width the same in most cases, except for fwd. rear where most use zero shim.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 04-29-2011, 10:31 AM   #2403
Verndog's Avatar
Not if they were made in a T shape with flange sticking out on block side and the bulkhead side.
---Team Hoarders---
Old 04-29-2011, 10:34 AM   #2404
wtcc's Avatar
Sorry guys made a mistake in the first design... (multitasking is not my strength...)
This one will work, but can be just a help not a final solution.
The best solution for us right now will be to drill a hole in the arm mount where the second unused hole is in the bulkhead and hold the armmount with a screw or pin. Only possible with the long one dot or zero dot mounts I think.
wtcc is offline   Reply With Quote
Old 04-29-2011, 10:39 AM   #2405
thats nice and would work sweet
Old 04-29-2011, 10:40 AM   #2406
correct
Old 04-29-2011, 10:42 AM   #2407
Verndog's Avatar
Keeping the prutruding tang down low only prevents pivot in 1 direction. Make it full length up past C/L of the screw, and now it cannot pivot either direction. Also T shape it to lock block and bulkhead and it doesn't have to come in from backside, just front. As you have it now it only prevents pivot in the direction it already cannot move, bottoms pivot out away from wheel.
---Team Hoarders---
Old 04-29-2011, 10:42 AM   #2408
nice change wtcc
jorgesimes is offline   Reply With Quote
Old 04-29-2011, 10:42 AM   #2409
wtcc's Avatar
@warren weaver: Maybe you litemodz guys can mill some prototypes and test them...
Old 04-29-2011, 10:44 AM   #2410
CristianTabush's Avatar
Default Arm Mounts.
We have a similar, but simpler solution on the way already. Prototypes should be ready soon and production should follow like 5 weeks later.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-29-2011, 10:50 AM   #2411
wtcc's Avatar
Simpler sounds good! What about the full length arm mount shims that were "promised" some pages earlier which should cover this problem?
Old 04-29-2011, 10:55 AM   #2412
Verndog's Avatar
Not sure about simpler, I could have 8 of those done and on my car before I went home today. Quick, cheap and simple to build in 1 machine operation.
I still prefer my setscrew idea as it also deals and resolves pin slop....2 birds with 1 stone.
---Team Hoarders---
Old 04-29-2011, 11:07 AM   #2413
Verndog's Avatar
Old 04-29-2011, 11:07 AM   #2414
wtcc's Avatar
Will you post some pics when you build them?
Old 04-29-2011, 11:17 AM   #2415
Verndog's Avatar
Sure....no problem...propably will have a thru hole so there is no left and right block, and may require a longer pin...have to layout and see, just eliminating the pin slop will in fact greatly reduce the amount it even can pivot, especially if the pin extends beyond C/L of the screw that it pivots around, and much easier to control in a reamed hole as opposed to a molded fit with slop.
---Team Hoarders---
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
