Old 04-29-2011, 09:54 AM   #2386
Warren Weaver's Avatar
Trader Rating: 43 (100%+)
Originally Posted by JRXS_chris View Post
Hmmmm, mounts that grab the hingepin with a grubscrew. That is a brilliant idea!
thank you iam actually getting stainless steal and will test it soon.
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-29-2011, 09:55 AM   #2387
JayBee's Avatar
Trader Rating: 31 (100%+)
I just bought this car plus hopups but haven't started building it yet. I wanna know, what is AE doing about it?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-29-2011, 09:56 AM   #2388
Originally Posted by Verndog View Post
Cool, thanks Warren. Went ahead and ordered some of their universals to compare to the Xray and Spec-R's. For now I have some Xray C hubs fitted up that I can test any of the 3 options with. I prefer to not bore the hard coating from the outdrives though so the Hot bodies have the edge there.
Your idea to drill out and extend is "on track", but I dont think there is enough wall thickness in the plastic pin block to hold the set screw reliably.
i was also thinking of drilling the end were the pin will pretrude and use the screws from the arms that hold the outer hinge pin
Old 04-29-2011, 10:04 AM   #2389
Schumacher as the solution, even think xray:
Don't even know if it fits, but have some at home, gonna try a let you guys know.
jorgesimes is offline   Reply With Quote
Old 04-29-2011, 10:05 AM   #2390
JRXS_chris's Avatar
You could probabaly just use the plastic mounts and drill some holes in to test
JRXS_chris is offline   Reply With Quote
Old 04-29-2011, 10:06 AM   #2391
Verndog's Avatar
Trader Rating: 16 (100%+)
Just get to building JayBeee, by the time your done I'll have your answer.
It's not a huge deal, just an annoyance. Building alum pin mounts would be a piece of cake, and would solve alot. You know you'll get some so get busy.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 04-29-2011, 10:09 AM   #2392
JRXS_chris's Avatar
Not sure I see a solution there Jorge, although I've not seem those mounts in the flesh before.
I'm gonna dig the dremel out
Old 04-29-2011, 10:23 AM   #2393
wtcc's Avatar
After going over the car after first full day out I noticed what others have mentioned. The arm mount blocks pivoted some and all 4 arms that started the day with zero slop, finished with more then I care for. Didn't hit much either so something needs to change there.
Considering building alum. arm mount blocks that have an outside set screw that would lock the pin. This would eliminate all pin slop and put an end to block pivot issue.
Anyone else found resolution to this? I suppose eliminating the shim washers would help some by increasing block seat contact. Another option is to find small serrated washers that bite in enough to eliminate pivot.
Here is one:
wtcc is offline   Reply With Quote
Old 04-29-2011, 10:28 AM   #2394
JRXS_chris's Avatar
Awesome
I'm more interested in seeing the rest of the CAD TC6 though....
Old 04-29-2011, 10:28 AM   #2395
These are the hinge pins i will be using from tower lxakhf thunder tiger part
Old 04-29-2011, 10:32 AM   #2396
Verndog's Avatar
Originally Posted by wtcc View Post
Here is one:
Pretty cool, someone has a full on solid cad model of the TC6...must be from AE. Problem is that only works for 2 of the 8 unless you want to increase your width.
---Team Hoarders---
Old 04-29-2011, 10:41 AM   #2397
wtcc's Avatar
Awesome
Here you are:
Yes it will increase the width, but with thinner shims the width will stay the same, or am I wrong?
And one thing: It is not from AE. I measured every part several times and build it in 3D. Took some time and wasn't fun in the end, but after the TC5 had so many design failures when using LiPo I want to be prepared...
Old 04-29-2011, 10:48 AM   #2398
JRXS_chris's Avatar
Sweeeet
Old 04-29-2011, 10:56 AM   #2399
Cool ideia. For me it would be awsome if it will be one-piece only
Old 04-29-2011, 11:15 AM   #2400
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Here is one:
That wouldn't do much. The mount itself would have to have those ears integrated into it.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
