Like Tree1Likes
Old 04-23-2011, 02:45 AM   #2311
oops missed that on the notes, forward placement.
jorgesimes is offline   Reply With Quote
Old 04-23-2011, 05:00 AM   #2312
JRXS_chris's Avatar
Jorge how did the car feel with quite a high roll centre?
JRXS_chris is offline   Reply With Quote
Old 04-23-2011, 07:17 AM   #2313
actually they are very low, but i think it could be a specific thing to our tracks, that are huge and flowing tracks, with not that much grip. Although almost every cars on the market that i know have the same arm position or distance to the chassi that A3 gives on TC6. It's kind more of a feeling to you, for me and on that specific track and conditions it worked, so try it out.
Old 04-23-2011, 10:22 AM   #2314
roger999's Avatar
Recommended drive ratio for 10.5? 5.2 - 6.4 is ok? don't really know what pinions to buy?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 04-23-2011, 01:33 PM   #2315
Fastfreddy74 is offline   Reply With Quote
Old 04-23-2011, 01:55 PM   #2316
CristianTabush's Avatar
Our track is high grip and technical asphalt. We all have gone to the A3 roll center. The biggest advantage of this roll center is that the arms do not get loose during a run, because these are the shortest blocks, so there is much less leverage on them. We have also used this roll center with a lot of success on high grip carpet and low grip asphalt.
Boost or no boost? This should be good for non-boosted settings. Depending on the length of your straightaway.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-23-2011, 02:13 PM   #2317
JRXS_chris's Avatar
I'm running b0 as that's what's on all the setups I've seen. Is a3 very similar then?
Old 04-23-2011, 02:18 PM   #2318
It should be about 1mm lower
Old 04-23-2011, 02:32 PM   #2319
Yes, it is actually closer to 1.5mm lower. Personally, we liked the A3 position more. Yes, many of the AE guys run the B0, but the car is not as consistent because the arms get the loosest with the 0 blocks. You can get very close to the B0 roll center by raising the outside camber link by 2 mm to a total of 4mm on the outside or you can start using shorter links to increase your roll stiffness to something similar. We are working on a solution for the blocks to not move over at Reflex. Maybe then, the B0 will be a good option, but as long as they get that loose, I would recommend to stay away from them. They will not hold up properly for a complete run.
Old 04-24-2011, 02:00 AM   #2320
roger999's Avatar
Boost, dont know the length of straightway, that is in small hall so probably is not very long...
Old 04-24-2011, 02:47 AM   #2321
Originally Posted by artwork View Post
I think this chart is really nice, but it is not entirely accurate...I have been running 31/104 64p and according to this chart that wont fit.
Hm.
I must see it.
I don't have this 104/64p
I just calculate it from 48p and some tests for 64p I did,
it could works but you know
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 04-24-2011, 03:05 AM   #2322
If boosted you should start from a fdr of about 8.5 to 7.0, depending on track size and motor/esc brand
Old 04-24-2011, 04:58 AM   #2323
JRXS_chris's Avatar
Cheers Jorge and Cristian, I'll give A3 a try at the track tomorrow and come back with some feedback.
I'll share a bit of know how now. I was advised by two Associated drivers to run Xray springs. I'm running 2.8 on the front and 2.6 on the rear. The car felt much freer without losing traction
Old 04-24-2011, 08:54 AM   #2324
Chris, have you seen my Thread? Our springs approximate the XRay springs very much, except they fit much better on the AE shock.
The Xray C2.8 springs are 16 lb springs and the C2.6 are 14.82 lb springs. With the long links it is just about perfect. With shorter links, like I run on our vertical-stud bulkheads, I went slightly softer to a 13.5lb rear and a 15.5lb front spring.
Give the A3 a shot, you'll find that you don't need to re-tighten the arms after every run anymore. Good place to start on the outside is with 4mm underneath the outside stud in the rear and 2mm in the front, with the extra long links (7 hole).
Old 04-24-2011, 02:30 PM   #2325
daleburr's Avatar
Yes, it is actually closer to 1.5mm lower. Personally, we liked the A3 position more. Yes, many of the AE guys run the B0, but the car is not as consistent because the arms get the loosest with the B blocks. You can get very close to the B0 roll center by raising the outside camber link by 2 mm to a total of 4mm on the outside or you can start using shorter links to increase your roll stiffness to something similar. We are working on a solution for the blocks to not move over at Reflex. Maybe then, the B0 will be a good option, but as long as they get that loose, I would recommend to stay away from them. They will not hold up properly for a complete run.
B0 blocks with alloy spacers definitely doesn't work, they just rotate.
I made up some carbon spacers and this fixes the problem; the spacers are the full size of the blocks and I roughened the surface with 60 grit sandpaper, so there's much more surface area and friction.
Maybe something you guys could produce? A few people have mentioned it but no one is doing it yet.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 Yesterday 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
