Like Tree1Likes
Old 04-17-2011, 02:38 AM   #2281
Trader Rating: 32 (100%+)
Default TC6 shock pistons
Hi, guys,...
Wish to check if anyone here has tried using other brand of pistons in the shock??
The stock pistons come with 3 selections, which are all 2 holes pistons. I am looking for 3 holes piston or 4 holes pistons for the shocks.
Thanks.
hobbs is offline   Reply With Quote
Old 04-17-2011, 06:07 PM   #2282
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by hobbs View Post
Hi, guys,...
Thanks.
associated has the blank pistons which can be drilled 3 or 4 hole. i also have used losi #56 and #57 which are 3 hole
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 04-17-2011, 09:10 PM   #2283
metalflakeking's Avatar
I have tried all the different assoc pistions along with drilling my own blanks but for some reason the Losi#56 red pistions worked the best for asphalt with no modifications.
MAX SPEED
metalflakeking is offline   Reply With Quote
Old 04-18-2011, 12:57 AM   #2284
Thanks guys for the info.
Went to quick look at Losi site, there are 2 types of losi #56 pistons.
1) LOSA 5046 - shock pistons #56, Red (4)
2) LOSA 5341 - 10mm shock piston #56 (4)
Which one should I get??
Old 04-18-2011, 10:30 AM   #2285
CristianTabush's Avatar
The 10mm pistons is what I have tried and used.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 04-18-2011, 09:05 PM   #2286
big al's Avatar
Just finished the build on my tc6 and I'm wondering which inner camber mounts you guys use for a med grip asphalt track. I've attempted to link a youtube video of my home track.
http://www.youtube.com/watch?v=s-Z5dtGf9uE
big al is offline   Reply With Quote
Old 04-18-2011, 10:15 PM   #2287
ed517's Avatar
really depends on the rest of your set up. But for me 7 front with silver ball stud and 1mm washer and 1b silver 2mm washer in the rear. this is with 1b roll center arm mounts..
ed517 is offline   Reply With Quote
Old 04-19-2011, 12:44 AM   #2288
G-mini's Avatar
hi all quick question will the tc5 spool fit straight in the tc6?
cheers Ginge
DnV Racing
Sponser,Reality Racing/CML
G-mini is offline   Reply With Quote
Old 04-19-2011, 01:08 AM   #2289
AE-Reedy
cheers Ginge
No, the bearing spacing is too wide to fit the TC6.
Sean Cochran is offline   Reply With Quote
Old 04-19-2011, 12:07 PM   #2290
what is the difference between #56 & #57???
Hole size???
Old 04-19-2011, 12:11 PM   #2291
slakr's Avatar
Trader Rating: 28 (100%+)
Hole size???
Yes... hole size
#56 = 0.0465 diameter
#57 = 0.0430 diameter
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is online now   Reply With Quote
Old 04-19-2011, 09:05 PM   #2292
Originally Posted by slakr View Post
Yes... hole size
Thanks for the clarification.
Now, I assume the total holes size in #56 is bigger that total holes size in stock piston #3 from AE??
Old 04-20-2011, 06:33 AM   #2293
Trader Rating: 77 (100%+)
Default In the kit
I have my kit coming. Can anyone tell me what shock pistons come in the kit as well as what color of springs?
Thanks.
goin2drt is offline   Reply With Quote
Old 04-20-2011, 06:38 AM   #2294
Default Gear ratio
Also can someone tell me the gear ratio so I can figure out my FDR?
Old 04-20-2011, 06:50 AM   #2295
artwork's Avatar
Trader Rating: 60 (100%+)
Internal is 2.0
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28964 09-01-2017 06:44 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
