Like Tree1Likes
Old 04-15-2011, 12:02 PM   #2266
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Originally Posted by CristianTabush View Post
Is that you I see on the TC6 Thread Joe? I see Mike G and Matt hanging out in here... Another convert perhaps?
Got my kit and trying to get it ready for my 1st season of competitive TC. I ran a few kits years ago but I had no idea what I was doing then.
tr1kstanc3 is offline   Reply With Quote
Old 04-15-2011, 12:30 PM   #2267
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by jhhack View Post
"In Development" is usually what I get from software engineers on things I want that I'll never see, but they dont want to tell me officially 'no' in writing. lol
Hope an Associated gear diff shows up before summer is out.
+1,,, me want associated gear diff.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 04-15-2011, 02:36 PM   #2268
Originally Posted by roger999 View Post
Yokomo
About 14-15lbs rear and front 17-18.
Black - 14.50
Blue - 14.80 rear
Yellow - 15.70
Pink - 16.26 front
Green - 17.00
Orange - 18.50
You can also use with really low RC in rear sliver sway bar with green ae springs.
cu!
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 04-15-2011, 03:44 PM   #2269
azz187's Avatar
Default Spec r gear diff
Hey guys,
I need some help with modifying the Spec R Yokomo Gear Diff.
I just built it and was told you only need to sand back the cam holders a tiny bit for it to slot in. Now Iíve realised the Spec R outdrivers are to small for the TC6 drive shafts.
Can someone tell me how they made their drive shafts fit? Do you need different outdriver??
Cheers..
azz187 is offline   Reply With Quote
Old 04-16-2011, 03:12 AM   #2270
roger999's Avatar
ok, my car is ready to rock so now i should buy some pinions... ill stay with 87 spur, and motor will be 10.5 Speed Passion. What pinions i should have for that?
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 04-16-2011, 04:24 AM   #2271
JRXS_chris's Avatar
Originally Posted by azz187 View Post
Hey guys,
Cheers..
Yeah, the balls on the end of the driveshaft are too large so you need to open out the internal diameter of the outdrive. I used a 6.5mm drill bit on a pillar drill. I guess you could slowly remove material using a dremel however.
It's the actual case of the diff and not the cam holders that need sanding back. Where you push the bearing over the diff case it makes the assembly fractionally too wide. You need to take about 0.5mm off each side so it doesn't bind.
JRXS_chris is offline   Reply With Quote
Old 04-16-2011, 04:25 AM   #2272
JRXS_chris's Avatar
I'd go for 20t up to 30t. Personally I've only used 24t to 27t on the various tracks I've been on .
Old 04-16-2011, 04:29 AM   #2273
JRXS_chris's Avatar
Black - 14.50
Blue - 14.80 rear
Yellow - 15.70
Pink - 16.26 front
Green - 17.00
Orange - 18.50
cu!
I think XRAY 2.8(16lb) and 2.6 (14.6lb) would also just about do the same job.
Old 04-16-2011, 06:54 AM   #2274
Default Spurs
Guys,
Can I please get some clarity on spur makes.
I know the TC6 can take Team associated and Kimbrough makes, what other makes, if any, will work.
Shane Arnold
Associated TC6 | Airtronics M11X | Tekin Rs Pro |
saarnold is offline   Reply With Quote
Old 04-16-2011, 07:26 AM   #2275
JRXS_chris's Avatar
Xray
Old 04-16-2011, 07:47 AM   #2276
RW spurs work they have the hole in them so you can tighten the motor screw.
ODEN is offline   Reply With Quote
Old 04-16-2011, 07:48 AM   #2277
wtcc's Avatar
Robitronic:
wtcc is offline   Reply With Quote
Old 04-16-2011, 08:00 AM   #2278
azz187's Avatar
Thanks Chris,
I'll try to drill the outdrivers, hope I don't destroy the diff!
Old 04-16-2011, 09:16 AM   #2279
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by WEEZY View Post
What shock tower is juho using for support in the back for the body?
The rear from the TC6 is a perfect fit..
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 04-17-2011, 12:05 AM   #2280
Default Silver Can
Hi Guys,
Im trying to fit a silver can to the motor mount, but due to the size of the casing around the axel, I cant seem to put both screws into the motor.
What have other people done, have you slightly filed out the motor mount to allow it to fit?
I am wanting to run this in Pro. I didnt want to move up to the next class yet.
Any help would be appreciated.
Thanks in advance
Shane Arnold
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 Yesterday 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
