Old 04-08-2011, 07:25 AM   #2206
daleburr's Avatar
Default Which gear diff
I'm thinking of getting a gear diff. The ones that fit are the Spec-R and the Yokomo (both from the BD5), but I'm undecided which one to get.
What are peoples experiences of each of these? Has anyone had leaks, stripped gears, outdrive wear etc?
Price-wise they seem to work out about the same once the alloy outdrives are added to the Spec-R diff.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 04-08-2011, 09:15 AM   #2207
JRXS_chris's Avatar
The Spec R version is fine. Mine doesn't leak, runs smooth and hasn't (so far) needed any maintenance of any kind after a good few hours running (apart from changing oil weight). I run 2k diff oil in for use round Halifax.
I've not had experience of the Yokomo so I could not compare.
Spec R seem to have a good spares backup from Abe Racing and Demon.
JRXS_chris is offline   Reply With Quote
Old 04-08-2011, 10:42 AM   #2208
pcar951's Avatar
Trader Rating: 19 (100%+)
I have both spec r and yokomo diffs. Yokomo is a little smoother and leaks a little less, no perceivable difference on the track. Neither is showing any unusual wear.
pcar951 is offline   Reply With Quote
Old 04-08-2011, 05:37 PM   #2209
ghiro's Avatar
Send a message via Skype™ to ghiro
Fished my TC6 build today and have yet to decide wich body is better for a small twisty track.
I have 3 to choose from since have them sitting home: LTC-R / MazdaSpeed/ R9-R all in lightweight versions. Wich one is the best choice for the car?
( no carpet and no foamies for me)
Capricorn TE01-Associated RC10R5.1-Atomic VM2-Serpent Cobra811 BE-Honcho-Losi MRC/RcBros-SandScorcher-MERV
DJI' F550-HubsanX4-Toy'sPort Zorro
ghiro is offline   Reply With Quote
Old 04-08-2011, 10:08 PM   #2210
LTC-R is good for twisty track and mazdaspeed is good for high speed tracks causes is more stable
f1o7x9 is offline   Reply With Quote
Old 04-08-2011, 11:14 PM   #2211
ed517's Avatar
if the track is low to med traction the R9-R works real well on small tracks. the body offers alittle more downforce at low speeds. if traction is high i would go for the LTC-R
ed517 is offline   Reply With Quote
Old 04-09-2011, 02:16 AM   #2212
cuboi's Avatar
hi,
qtn on spur gear
417 spur gear 111 and 113 does it fit these car?
thanks
cuboi is offline   Reply With Quote
Old 04-10-2011, 07:31 AM   #2213
roger999's Avatar
hi, im building now my TC6 and there is strange thing, on flat surface like board TC6 looks like tweaked!? when i pushing one corner of the car on the back, front corner going up! I know that is just a little but i thought it should be flat at all. I was building that on flat board so i dont think i made something wrong with that, later was trying to untight screws and tight it again but always one corner is little bit up... mayby 0.2mm. Is that normal????
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 04-10-2011, 07:48 AM   #2214
Warren Weaver's Avatar
Trader Rating: 43 (100%+)
take the screw out for the motor mount brace and make sure i lines up with the chassis if not i shimmed the mount until it lined up.
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-10-2011, 08:46 AM   #2215
durtbag's Avatar
make sure that all of the countersunk screws are flush with the chassis, the ones with the letters/#'s have a larger head diameter and can protrude a little. I run a straight edged ruler across the bottom of the chassis to find the high points.
AW HELL RICKEY, I WAS HIGH WHEN I SAID THAT!
durtbag is offline   Reply With Quote
Old 04-10-2011, 08:56 AM   #2216
roger999's Avatar
i know what you mean that's why i didn't put that screw with letters... Im re assmebling again and now is better, just will check that motor mount and we'll see how is after...
Old 04-10-2011, 09:31 AM   #2217
roger999's Avatar
yeah! is done! but wasn't easy... thanks!
Any way that car is not great to build....
Old 04-11-2011, 04:14 AM   #2218
My Tc6 chassis was tweaked from new....
But when i build the kit i checked for tweak at every stage and as soon as i installed the motor mount this seemed to de-tweak the car. Stange as everybody told me to install a grub screw in the motor mount to stop it tweaking the chassis, but installing the proper screw cured the tweak on mine.
I will be purchasing a new chassis in time to rectify this but for now mine is tweak free (until i hit something )
I would say the tweak on my chassis @ the rear left corner near the motor mount is about 0.2 - 0.3mm.
tc3nitro is offline   Reply With Quote
Old 04-11-2011, 04:20 AM   #2219
What problems did you have with the build ?
Old 04-11-2011, 04:26 AM   #2220
I would go with the Yokomo - It seals nicely and stays dry if it's build correctly ( i built mine with green slime on the seals and gasket ) and is far smoother in operation. You can also notice the change in gear oil more in the Yokomo, i'm not sure wether this is due to it holding a little more oil of the fact its smoother to start with.
I have run a Spec-R diff in my tc6 too but it only managed a 3 min run before destroying the gears. I shimmed it all up and adjusted the gears but it just mullered itself.
Dale if you would like to purchase a Spec-R one i have one here needing a new gearset ?
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
