Like Tree1Likes
Old 04-05-2011, 11:00 PM   #2191
SlowPushin's Avatar
does the tamia gear diff work in TC6 or is the diff made by yokomo. also where do i get the spool for the front?
IT's Not THe CAR,IT's THe NUT on the GRIP
S e r p e n t [7 4 7] [4 1 1]
SWEEP TIRES
ENNETI TIRES
SlowPushin is offline   Reply With Quote
Old 04-05-2011, 11:15 PM   #2192
pcar951's Avatar
Trader Rating: 19 (100%+)
You'll need the Yokomo Spec R (or an actual Yokomo gear diff). No need for an aftermarket spool, the kit supplied slipper spool is by far the best.
pcar951 is offline   Reply With Quote
Old 04-06-2011, 05:21 AM   #2193
Hi Guys,
Your assistance has been great, and therefore as performance punishment I have another question.
I have fitted the front and rear anti-roll bars, but they move around a little and the anti-roll bar mounts also move. I assume this is correct behavior as I followed the instructions to the letter, however, on a previous car (TA05), they were firm and didn't move.
Is this just a different implementation?
saarnold is offline   Reply With Quote
Old 04-06-2011, 05:44 AM   #2194
Buy Tamiya #53827 or any other brand Rod Stopper, basically it will stop that movement. It's not a matter of malfunction, but it's best to have it.
jorgesimes is offline   Reply With Quote
Old 04-06-2011, 07:10 AM   #2195
SlowPushin's Avatar
Where do I get the yokomo diffs in the U.S and do I need to shim the diffs?
SWEEP TIRES
ENNETI TIRES
Old 04-06-2011, 07:43 AM   #2196
pcar951's Avatar
Check with www.driftspeed.com for Yokomo. No shimming required, in fact you'll have to shave a little off the case to make it fit (lots of posts on here about that).
Old 04-06-2011, 08:46 AM   #2197
SlowPushin's Avatar
Thank you for the link.
SWEEP TIRES
ENNETI TIRES
Old 04-07-2011, 01:47 AM   #2198
roger999's Avatar
hi, how meny balls going to spool thrust bearing?
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 04-07-2011, 02:07 AM   #2199
Sorry, in the thrust? Because in the pulley it's none.
Old 04-07-2011, 02:15 AM   #2200
Edgar_P's Avatar
Hello,
I am considering buying a new TC6, but still have plenty of time until our next nationals. Do somebody know if AE is going to release updated version of TC6 in coming 3 months?
BMI COPPERHEAD 12
Edgar_P is offline   Reply With Quote
Old 04-07-2011, 02:20 AM   #2201
roger999's Avatar
sorry is in manual on the back i didn't see it. There is 6.
Old 04-07-2011, 02:53 AM   #2202
daleburr's Avatar
Originally Posted by Edgar_P View Post
Hello,
Very unlikely, AE cars tend to stand the test of time.
Get the car now and enjoy 3 months of testing so that you're well prepared for the nationals.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 04-07-2011, 12:52 PM   #2203
roger999's Avatar
hi all, what is going on with rear spool differential? wanted to tight mini locknut for set diff and all thread went out from that locknut...?? with front slipper was no problem...
Old 04-07-2011, 02:05 PM   #2204
wtcc's Avatar
Normally there should be no problems. But now that you have one maybe you try this part:
#6575
wtcc is offline   Reply With Quote
Old 04-07-2011, 04:07 PM   #2205
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Logi Maker View Post
Had a great time at carpet nats. The AE guys went above and beyond support. Sat down with the TC6 designer Bob (he hooked me up with a rear shock tower). Awesome guy, one of the nicest people I have met in this "hobby". He was actually driving the first TC6 that all the team tested with. He just changed out the original top deck and chassis last week. He got into the history of the design and why everything from the arms out are TC5, for now... TC6.1 in the near future. He basically designs the on road stuff. Such a nice guy. Got a look at the 12R6 too... what an experience. Had some issues with my LRP esc and walked right over to Sean Cochran for some help.
Big shout out to Region 11 (WA state) rep Sean Maybell, there all week to help us local guys out. Multiple times seen roaming the pits with a box of parts and set up tips, can't say it enough how he is the perfect guy for us to lean on.
The only thing I decided to upgrade is the front body posts, went with the CRC thickies.Thanks Bob, Sean and Maybell for an awesome experience. Wish I could have ran my main, but my ESC took a dump post tech and could not fire back up. Again Sean C is handling it..
AE RULES!!!
Hello,
Kyle Predmore
Facebook - "AE Fanboy"
B6D|B64D
TC7|TC6TEK|12R5.2|10R5.1
Logi Maker is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
