Old 04-02-2011, 08:41 AM   #2146
mkennedy's Avatar
Trader Rating: 26 (100%+)
Send a message via Yahoo to mkennedy
Originally Posted by hobbs View Post
Hi, guys, wonder if you face the same problem here with regards to TC6 rear ball differential.
As far as I know, ball differential (bd) works correctly if you turn a wheel in one direction, the other wheel would turn in opposite direction.
I have tried to rebuild it about 5 times including using different brand of bd grease (3racing, xray & Schumacher), changed new 3/32 balls, changed new steel plate), but it would not work (both wheel turned in the same direction)
When I turned the bd only using my hand, the other side turned in opposite direction, but I could feel the friction.
When the bd was installed in the car with wheel, using hand, both wheels went the same direction.
What went wrong??
Sigh...
while in the car, hold the spur and turn only one wheel, the other should turn opposite. it will have resistance depending on how tight you have the diff screwed down.
Mike Kennedy
AKA - Airtronics - F1RCLab - Thunder Power - JGO Paintz - Dialed Inc. - CompetitionX.com
mkennedy is offline   Reply With Quote
Old 04-02-2011, 02:56 PM   #2147
Questions??
Sorry if this has been asked before, but what springs are the team drivers using mainly on Tarmac
Is it a mix of HPI or Associated?
I noticed some Yokomo springs on one of Juho's ETS setup sheets, but that maybe carpet?
T
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 04-02-2011, 04:29 PM   #2148
daleburr's Avatar
T
In the UK it's either AE or HPI. I prefer the HPI springs as there's less of a gap between spring rates so you can fine-tune the balance. With AE springs it's quite a big jump between rates.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 04-02-2011, 06:54 PM   #2149
Default Front Slipper Spool
Hi guys,
sorry if this has been discussed previously, and please excuse if this is a silly questions, but why is the front diff a slipper spool and not a ball diff?
what are the benefits / disadvantages?
saarnold is offline   Reply With Quote
Old 04-02-2011, 10:38 PM   #2150
Maggpie's Avatar
I know this might seem like a dumb question but when you glue the diff pully flange on does the tapered side face the out side or the gear? Also one of the bottom caps labeled BHCS part number 31324 has no threads I guess i will have to call associated and see if i can get a new one. what should I expect when i contact them about it?
Maggpie is offline   Reply With Quote
Old 04-02-2011, 11:00 PM   #2151
ed517's Avatar
AE has great customer service. Im sure they will take care of you.
The tapered side faces the belt. Only a small amount of CA on the inside edge is needed. you dont want any glue getting in the teeth
ed517 is offline   Reply With Quote
Old 04-03-2011, 02:59 AM   #2152
daleburr's Avatar
Originally Posted by saarnold View Post
Hi guys,
A spool allows you to accelerate harder out of the corner as it ensures the power goes to the wheel that has grip (the loaded outside wheel), instead of to the unloaded inside wheel.
The slipper spool is basically the same but can slip under very heavy load such as a crash, preventing driveshafts and blades being damaged.
Team Xray
Old 04-03-2011, 03:11 AM   #2153
In car footage from my TC6, A Main 3rd final after restart (LiPo fire caused restart)
+ YouTube Video
9th to 4th
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 04-03-2011, 03:27 AM   #2154
wtcc's Avatar
I love your Race TV! Can you make a pic of how you installed the camera and what camera you use. Thanks!
wtcc is offline   Reply With Quote
Old 04-03-2011, 03:36 AM   #2155
Danke.
I just use double sided tape and fibre glass tape
Camera was about AUD$9 shipped from Hong Kong to Australia via eBay.
Old 04-03-2011, 04:17 AM   #2156
Thanks Daleburr,
Now I know and it makes perfect sense.
Cheers
Old 04-03-2011, 07:53 PM   #2157
Verndog's Avatar
Trader Rating: 16 (100%+)
Is anyone running the regular arms (not the kit hard arms) in asphalt yet? I see most setups running with sway bars and combine that with hard arms seems like possibly overkill. I have yet to make first run yet but I'll give it a go, just curious.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 04-04-2011, 05:19 AM   #2158
Default shock rebound
Saw AE racer setup, rebound 10%.
Question- how to make the shocks rebound 10% or 20%?
mos-leung is offline   Reply With Quote
Old 04-04-2011, 08:17 AM   #2159
Default Savox Server Horn?
Hi,
anyone using a Savox server, which server horn did you use .. A, J ,F, H?
I cant seem to fit any to my savox 1251 - they all seem to small - unless one is correct but really tight?
Old 04-04-2011, 08:52 AM   #2160
JRXS_chris's Avatar
1. Fill shock
2. Let air bubbles dissipate (or whatever method you prefer to use; pump etc)
3. Place the bladder over the top of the body lightly holding it in position
4. Push shaft up until 10% of the shaft is still showing. Oil will bleed out.
5. Place cap on and screw up.
If you want 25% then keep a quarter of the shaft showing while pushing up or for 50% half the shaft
JRXS_chris is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
