Old 03-24-2011, 01:39 PM   #2086
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
What are the stock springs (and spring weight) included with the TC6? Wondering if I should buy a set of silver springs to match Herbert's setup.
tr1kstanc3 is offline   Reply With Quote
Old 03-24-2011, 02:16 PM   #2087
Send a message via AIM to Jonesy112
the kit comes with silver(14.5 lb) springs in the front, and greens(12 lb) in the rear.
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 03-24-2011, 03:10 PM   #2088
wtcc's Avatar
If you set up your car like Keven the silver springs in the rear really make the car turn a lot better. An inexpensive tuning for your laptimes.
wtcc is offline   Reply With Quote
Old 03-26-2011, 09:16 AM   #2089
In lower RC (0 in b) at rear with green's also help thicker (silver) sway bar.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-27-2011, 02:22 PM   #2090
bhambrent's Avatar
Guys need a little help!
I broke a bulkhead part#31309 testing this weekend and can't find a replacement any were.
Any help would be great,I need it for our money race next Saturday
Thanks,
brent
bhambrent is offline   Reply With Quote
Old 03-27-2011, 03:28 PM   #2091
Verndog's Avatar
Trader Rating: 16 (100%+)
Any help would be great,I need it for our money race next SaturdayThanks,
brent
Looks like my reliable sources are out also...sorry. How did you manage to break a bulkhead, thats not easy to do?
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 03-27-2011, 04:30 PM   #2092
bhambrent's Avatar
I did not put thread lock on the back left on the bulkhead. The screws came out, the car hooked left into the wall.
That was the 4th run with a new car. So make sure your screws are tight.
Old 03-27-2011, 05:27 PM   #2093
poochy's Avatar
hi, before i make the purchase, have some tc6 questions:
will a tc5 body fit on a tc6?
any problems with the initial build out, or any defects (tc5's diff was difficult for me to build bc of the thrust bolt and nut)?
poochy is offline   Reply With Quote
Old 03-27-2011, 07:19 PM   #2094
hanzo3's Avatar
Trader Rating: 55 (100%+)
Same body mounting positions.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 03-27-2011, 09:20 PM   #2095
Verndog's Avatar
Default Initial Build
Thought I'd check back in after completing the initial build. Let me start by saying my hat is off to all those that helped create the new TC6, and to Associated for putting out an excellent product for a fair price!
The build went awesome, I had no problem with directions (helped I built a TC5 though), and everything was there and it very close to ready to roll. The only Associated related issues I ran into was, 1 CVA that was not bored deep enough and bound after assembled, 1 arm that a hole was under and had to ream out, and the stock flathead screws that have the stamped letters were thicker then normal and stick out below chassis (replaced then with stainless RC screws anyway).
I did have to take out some slop in the arm mounts using a little CA let dry then insert pin...ALL arms and steering have close to zero slop, a huge improvement over the TC5 there.
Balance--Weight. WOW
With all electronics mounted and a Thunder Power 5300 the car balanced within 3 grams side to side, and on top of that weight is within 2 grams or Roar 2011 limit of 1380 grams! Incredible job Associated!
Test run will have to wait a couple weeks, this is an asphalt season build so I'll hope the debut goes half as well as the build and I'll be content.
Also side note...no wheel chatter at full turn (like my Xray...had to buy $100.00 worth of ECS's for ). Take the smoothest 2 CVA's and put on the front...helps to deburr the slots and the steel barrel nut for chatter free turns.
---Team Hoarders---
Old 03-27-2011, 09:33 PM   #2096
ed517's Avatar
tC5 bodies will fit. for the diff and spool use the diff nut from the B4(offroad) keeps the diff bolt truer and stronger with alittle more thread. sorry cant remember the part #
ed517 is offline   Reply With Quote
Old 03-27-2011, 10:06 PM   #2097
I'm not using the B4 diff bolt and not had a single issue except for needing to rebuild one diff so far.
Heres a great bit of footage I recorded with my TC6...
+ YouTube Video
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 03-27-2011, 10:18 PM   #2098
Hey guys just gearing up for the summer months. going with the tc6 due to already have the tc5.
my question is which tires are you guys running. and why.
I race on asphalt and we use sugar water to help with traction.
So any help would be greatly appreciated.
thanks
A
cyrrus is offline   Reply With Quote
Old 03-27-2011, 10:21 PM   #2099
Verndog's Avatar
... sorry cant remember the part #
Screw kit #6575
http://www.losipartshouse.com/servle...st-Bolt/Detail
---Team Hoarders---
Old 03-27-2011, 11:25 PM   #2100
Trader Rating: 32 (100%+)
Default shock piston - what is the difference
Hi,.. the kit comes with 12 shock pistons (PTFE, part #6465) & also silicon fluid (40wt) for shock assembly.
May i know what is the difference between shock piston marked as #1, #2 & #3???
They all look the same to me (thickness & number of holes).
What other spec of silicon fluid you use besides going for the 40wt???
Kindly advise.
Thanks.
hobbs is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 07:34 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28937 01-14-2017 07:26 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 12:42 PM
SEO by vBSEO 3.5.0
