Like Tree1Likes
Old 03-22-2011, 06:22 AM   #2071
Originally Posted by cyrrus View Post
One Congrats to Juho
Second planning on going to the TC6 from the TC5 Just curious now that the car been out for awhile does the kit need any mods or extra things. just curious. to take out any bugs at all. this way i can be prepaire for the coming season.
oh I will be racing on Asphalt with sugar water lay down.
so any advice would be great.
After you go to TC6 from TC5, please list out the parts you brought.
mos-leung is offline   Reply With Quote
Old 03-22-2011, 06:26 AM   #2072
Default 6 deg caster
I saw many AE racer's set up said they are using 6 deg caster.
As i know there may totally 6 deg caster by 6 deg caster block with 0deg kick up(anti-dive). Or using stock 4 deg caster with 2 deg kick up.....
Is there any difference between both?end up either one, you can get 6 deg caster
Old 03-22-2011, 09:11 AM   #2073
the best part of the tc5 last year is i never hardly both any spares and didn't need any just from parts wearing out. from set up changes.
ummm tc6 here i come can't really justtify going xray. even though 90 percent of my club run one in one form or another.
part are both easy to get as the dist is just an hour away and my hobby shop and get both easy.
Just been on the fence is all
cyrrus is offline   Reply With Quote
Old 03-22-2011, 03:23 PM   #2074
hanzo3's Avatar
Trader Rating: 55 (100%+)
I just switched my steering hubs around. Do the turnbuckles still go over or under the steering hubs?
Anyone run their transponder in the bumper mount? How do you make the wire go cleanly past the shocks and hubs?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 03-22-2011, 03:59 PM   #2075
wtcc's Avatar
You can guide the cable between belt pulley and bulkhead (next to bulkhead), below the servo arm towards the receiver. I have a MRT transponder and the cable is strong enough to stay in place without extra help.
wtcc is offline   Reply With Quote
Old 03-22-2011, 05:29 PM   #2076
Maybell's Avatar
CRC #4020 will help you guide the wire along the inside of the left front bulkhead.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-22-2011, 05:31 PM   #2077
Maybell's Avatar
if you flip the steering blocks, the ballstud goes on top of the knuckles arm.
Old 03-22-2011, 05:39 PM   #2078
Verndog's Avatar
Trader Rating: 16 (100%+)
Save those tips my friend....back in the saddle...just ordered the TC6 from RC Hobbies here, they gave me a great deal. Will put together this weekend.
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 03-22-2011, 05:56 PM   #2079
Maybell's Avatar
Nice! Almost time for tarmac season. See you soon!
Old 03-22-2011, 07:47 PM   #2080
Smile Yokomo Gear diff
Hello!!
I'm an new owner of TC6 from Tokyo, Japan.
Please let me know how can I mount the Yokomo gear diff to TC6.
I've bought and tried to fit to my car, but the dog bone is too large to insert to joint cup.
What is the easiest way to solve this problem?
Nao@idac is offline   Reply With Quote
Old 03-22-2011, 10:13 PM   #2081
Originally Posted by Nao@idac View Post
Hello!!
I think someone said it before but here is what you need to do to fit the gear diff to a TC6. I am using spec r gear diff now but the process should be very similar. the diff is a little wider in the yoko so you need to narrow the diff housing by 1mm. I just mount it on my tire truer and sand it slightly. For the outdrive the hole is around 0.4mm too smaller. So just use a sanding wheel and sand it a little larger. Very simple job, took me 15min per diff.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 03-23-2011, 04:51 PM   #2082
pcar951's Avatar
Trader Rating: 19 (100%+)
Just received my care package from AE, replacing some original faulty bulkheads. Sent the email less than 10 days ago...now that's service!
Way to take care of your customers Team Associated!
pcar951 is offline   Reply With Quote
Old 03-23-2011, 04:54 PM   #2083
transplantlife's Avatar
Trader Rating: 43 (98%+)
what spec r gear diff fits the tc6?
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 03-23-2011, 10:22 PM   #2084
Thumbs up
THANK YOU!!
I'll try that.
Old 03-23-2011, 10:29 PM   #2085
spec r gear diff for yokomo (40T)
THANK YOU!!
I'll try that.
You welcome.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
