Like Tree1Likes
Old 03-15-2011, 05:01 PM   #2041
[QUOTE=hacker;8803188]I have heard of losi lcd's being used on the tc5, however apparently you need to use losi steering knuckles and hubs too. Currently wheeling a losi, have a tc6 on the way and will look at converting with the losi lcd's QUOTE]
I jumped on this thread to ask if this would work on the TC6. By using the Losi C-hub and knuckles you also get to run a much bigger bearing.
I hope someone can confirm this will or will not work.
Thanks!!!!!!
Murray is offline   Reply With Quote
Old 03-15-2011, 06:49 PM   #2042
jag88's Avatar
[QUOTE=Murray;8807640]
Thanks!!!!!!
It can be done but I think that the ackerman geometry is different and will give you a different feel to your steering.
jag88 is offline   Reply With Quote
Old 03-16-2011, 07:59 AM   #2043
Can anyone explain me what is the main difference of changing the RC in the camber link vs suspension arms?
jorgesimes is offline   Reply With Quote
Old 03-16-2011, 08:10 AM   #2044
CristianTabush's Avatar
Changing your camber link is just a minor change. Moving the arms creates a much larger change in the roll center of the car.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 03-16-2011, 08:22 AM   #2045
Ok thanks mate.
Old 03-16-2011, 08:36 AM   #2046
woozer71's Avatar
Trader Rating: 23 (96%+)
My steering linkages on the steering bellcrank balls are very tight. Do they wear in over time or is there a easy fix?
Fraser Coast RC Car Club/FCRCCC
VBC D06 / Xray T4 2013
Yokomo BMax2 ver 2 - Tamiya F104 x1
Sanwa MT-4
woozer71 is offline   Reply With Quote
Old 03-16-2011, 10:31 AM   #2047
daleburr's Avatar
Pop them on and off a few times till they loosen up.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 03-16-2011, 10:43 AM   #2048
daleburr's Avatar
Lets say you want to lower the RC by 2.5mm.
Lowering the arm mounts by about 1mm would do this (e.g. going from B1 to B0).
Raising the inner camber link by about 3mm would also do this (so going from hole 3 to 1 will be close as that is 2.3mm apart - you could then lower the outer ball by 0.7mm and you'd be spot on).
However moving the camber link will have more of an effect on camber gain than moving the lower arm. The lower arm position will have negligable effect on camber gain, the camber link will affect it quite a bit.
So if you wanted to lower the RC and keep as much camber gain as possible for maximum grip, you'd lower the wishbone.
If you wanted to raise the RC to keep the car flat, but add some camber gain to maintain traction, you'd lower the inner camber link which would raise the RC and add some camber gain (about half a degree on the outside wheel at full roll from 5mm RH).
Team Xray
Old 03-16-2011, 11:18 AM   #2049
But lowering the wishbone could also add more shock pack and affect the shock behaviour. Is this correct or it's hardly noticed?
Old 03-16-2011, 01:22 PM   #2050
thats a fantastic explanation on RCs!, thank you for takeing the time to type it
im sure others apreciate it as much as i do
Ed
Edwin Pibal is offline   Reply With Quote
Old 03-16-2011, 08:06 PM   #2051
303slowdown's Avatar
Trader Rating: 19 (100%+)
squeeze them with pliers and turn them a few times while their conected to the ball stud it will loosen them
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 03-17-2011, 02:15 AM   #2052
daleburr's Avatar
I think any change to pack will be unnoticable. Only a computer would be able to see the difference.
Team Xray
Old 03-17-2011, 03:54 AM   #2053
Thanks Dale awsome explanations. I've asked this because i've made some measurements and i'm interested in maintain the shock links on 7 position, but i think i need more roll. And like once Grainger said that the perfect position for the arms is 5 mm for the chassi and the 0B is kind a off, i'm thinking in playing with this, but i have some doubts about the consequences.
You have cleared me up, thanks.
Old 03-17-2011, 04:24 AM   #2054
daleburr's Avatar
This may help:
I took measurements of the car when I was building it and put them all into a roll-centre calculator. I performed a sweep of the lower and upper link positions which is what that table shows.
The one thing missing from the table is the main effect of going from camber link position 1 to position 7. This only has a small effect on the camber gain and initial RC (which adding a 0.5mm shim to the outer ball would pretty much eliminate), but position 7 will cause the RC to drop a lot more as the car rolls. This tends to give a lot of grip, but can make the car feel quite lazy. So good for low grip conditions
Team Xray
Old 03-17-2011, 06:23 AM   #2055
Really awsome, can i get a hand at that RC calculator LOL
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
