Like Tree1Likes
Old 03-09-2011, 10:43 AM   #1981
Originally Posted by f1o7x9 View Post
What would be the best gear diff that I can buy for my Tc6
Yokomo BD5 Gear Diff !!!!!!!!
FrankH is offline   Reply With Quote
Old 03-09-2011, 04:31 PM   #1982
Default my tc6
Today I finished assembling my chassis tc6. basically I had problems with long links. Here we were with tire rubber in asphalt for high adhesion.
zaranza is offline   Reply With Quote
Old 03-09-2011, 09:41 PM   #1983
Default top sercet light weight hollow c hub, lol
I was driving my TC6 at the track last night. When replacing a broken c hub I found there are two big empty holes inside the plastic where the c hub snap...... I mean these thing do break but I don't expect to see some holes inside the plastic..... Don't get me wrong as I still love my TC6 but I am not sure what AE is doing........
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 03-10-2011, 02:12 AM   #1984
The stock turnbuckles are meant to use on the 7 camber link position, to use the other positions i think you have to buy these ones FT Blue Titanium Turnbuckles, 1.375"/35mm
Hope this helps.
jorgesimes is offline   Reply With Quote
Old 03-10-2011, 03:28 AM   #1985
rosko's Avatar
Any updates on an associated gear diff.
rosko is offline   Reply With Quote
Old 03-10-2011, 05:51 AM   #1986
RC-ProSpeed's Avatar
Does associated makes a Front Solid Axel for the TC6? if not, any other brand that will fit in?
Thanks!
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 03-10-2011, 05:53 AM   #1987
hacker's Avatar
Trader Rating: 140 (100%+)
doesn't it already have a spool?
I wouldn't know, I don't have a car yet
hacker is offline   Reply With Quote
Old 03-10-2011, 05:58 AM   #1988
wtcc's Avatar
Thanks!
It comes with a slipper spool.
Who wants a solid axle (that kills the blades if you crash) can get it from Litemodz for example.
wtcc is offline   Reply With Quote
Old 03-10-2011, 06:28 AM   #1989
cheehtae's Avatar
Trader Rating: 15 (100%+)
+1, sup brandon? greetz from lexington.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 03-10-2011, 06:31 AM   #1990
rosko's Avatar
Ran a regular spool on my tc5, even if I just barely tap I broke a blade, then when you realize you broke one and pull your car off the track you usually tore up an outdrive to.
Old 03-10-2011, 06:47 AM   #1991
Hope I wont crash that much! I never use a slipper spool before... does it come loose after a while??
Thanks for the info on the Litemodz, I found that it is designed to not use the plastic blades, so the problem of the broken blades is a no worry... the questions is who sells them in the USA?
Old 03-10-2011, 06:54 AM   #1992
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
contact me iam the usa distributor of litemodz
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 03-10-2011, 07:02 AM   #1993
Will do... Thanks!
Old 03-10-2011, 07:11 AM   #1994
pcar951's Avatar
Trader Rating: 19 (100%+)
The TC6 spool doesn't come lose if you build as per the instructions. The slipper spool is an absolute stroke of genius from Associated, it's one of those little things that makes a huge difference.
pcar951 is offline   Reply With Quote
Old 03-10-2011, 07:12 AM   #1995
heh
I found next bug
part 31214 it is Caster Block Bushing
one has 4.49mm diameter and 3x has 4.41mm
so I found slop at front
4.49mm is tight, and fit caster block nice 4.41 has slop
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
