Like Tree1Likes
Old 03-05-2011, 09:23 AM   #1951
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by pyro854 View Post
Does anybody know where i could find a chasis protector so i dont scratch the crap out of the car on asphaltthis season?
The J Cocepts will work
This guy, http://www.rommelsrcworld.com/servlet/StoreFront
Has them but not for the ^ yet. Try and contact him, awesome guy to deal with!!
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\Schelle
Logi Maker is offline   Reply With Quote
Old 03-05-2011, 10:19 AM   #1952
stitchy's Avatar
Jconcepts chassis protector sheets
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 03-05-2011, 11:49 AM   #1953
117
117's Avatar
Thanks everyone for the useful posts in this thread. I ordered a TC6 last week, so it should arrive soon. I also ordered another receiver, RS Pro, 17.5 Thunder Power stock motor, and a few other parts that have been suggested throughout the thread. I'm planning to set the car up using the K. Hebert high traction carpet setup as a starting point.
Now I'm deciding on batteries. I'm looking at using something from Reedy, ProTek, etc. I might have missed it in the thread, but it looks like batteries that are around 138x48x25 should fit fine, correct?
All the batteries I have been considering run banana connectors directly on the battery, so my plan was to solder banana plugs directly to the RS Pro without any balance taps, then have a second set of banana connectors with balance taps for the charger. Is this usually how you guys run your batteries?
For the servo, I'm planning to use a Savox 1251MG.
Thanks for any advice/suggestions!
Associated RC8Be
Associated RC8.2e
Kyosho MP9e TKI
117 is offline   Reply With Quote
Old 03-05-2011, 12:01 PM   #1954
RC MARKET's Avatar
Associated had this !
http://rcmarket.com.hk/advanced_sear...dfg5923i9i6i07
RC MARKET is offline   Reply With Quote
Old 03-06-2011, 06:51 AM   #1955
trytowin's Avatar
Default bones and axles
Sorry if this was discussed earlier, does anyone know who makes a lighter weight cva bones and axles for the tc6. The steel ones weigh a ton and I don't think my 25.5 motor (VTA) will be able to turn them!! Thanks.
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 03-06-2011, 07:58 AM   #1956
walkonking's Avatar
Originally Posted by hanzo3 View Post
anyone have trouble mounting a Mazda speed 6 body? It seems the front body posts are not long enough.
Shim under body mounts!
pop a clutch, roll a dutch!
walkonking is offline   Reply With Quote
Old 03-06-2011, 09:21 AM   #1957
Buckaroo's Avatar
For those of you having trouble mounting certain bodies with the stock front posts, AE PN# 4535 is a little taller, and solves all of your problems, especially those related to most of the VTA/RCGT bodies.
Click here
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 03-06-2011, 06:52 PM   #1958
dorkmissle's Avatar
Trader Rating: 29 (100%+)
Originally Posted by ernestf View Post
I have bad luck with my TC6 ... found a dog bone that has a thicker diameter and cannot fit into the UJ cup, and then found that one of the outer a-arm pin has a smaller diameter than usual and as such the c-hub is not fitting tightly on the a-arm ... not sure if you guys also find same problem in some of the kits sold ?
Ernest I just built my TC6 this weekend and had exact same issue.
Sort of disappointed but all quality issues which are easy to fix, just annoying. Overall found design A+ as usual for AE.
I'm ordering aftermarket CVD's and replacement hingepins....look like 2.5mm. My pin was 2.3mm.
dorkmissle is offline   Reply With Quote
Old 03-06-2011, 07:18 PM   #1959
nitro rat's Avatar
Trader Rating: 5 (86%+)
hi guys,
Hows the TC6 handle out of the box on a slippery track?
nitro rat is offline   Reply With Quote
Old 03-06-2011, 07:23 PM   #1960
Originally Posted by nitro rat View Post
hi guys,
I have found the TC6 has lots of grip out of the box, I found that I've had to stiffen up my car due to to much grip and this is one a track known to low to med grip at best.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 03-06-2011, 09:47 PM   #1961
xray09ACT's Avatar
Scoots, try the no dot roll centre on the lower arms, this seems to be the best option for your situation. I also run heavier sway bars 1.5 up fron and a 1.3/4 on the rear. The longer wheelbase also seems to let it settle more mid to out.
ACE Hobby Australia | Monaro models
TEAM Associated TC6 | LRP | LRP
TEAM Associated TC6 | Nosram | Nosram
TEAM Associated 12R5.1 | LRP | LRP
xray09ACT is offline   Reply With Quote
Old 03-06-2011, 10:21 PM   #1962
I'm already running lower roll center, and I think I am running a longer wheel base.
Old 03-06-2011, 11:02 PM   #1963
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
I've been looking at this car for a few weeks now and am thinking about buying one. I drive a top photon right now and I'm just looking to get a car that my lbs can get parts for. Is there anyone on here that has driven both the photon and a tc6, I'm just looking for a comparison. How does the car perform on very low grip carpet.
sprintcarracer is offline   Reply With Quote
Old 03-06-2011, 11:14 PM   #1964
xray09ACT's Avatar
A couple of the guys have the top at the lcoal track.
My advice is always go with a car that you can setup easily and it is easy to drive. I have had no issues with the TC6 and it was very good with the kit setup out of the box on our low traction carpet. The local TOP guys have started to move away from theirs as they couldn't get it to handle as well. Saying this though, rember everyone is differet in the setup department. I just have found the TC6 easy and just like the xray, if you make a change you notice the difference.
Old 03-06-2011, 11:26 PM   #1965
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
I wrote a review for thebigrc.com a few months ago. You can check it out here:
http://www.thebigrc.com/?p=195
Since then I have continued to refine my setup for Timezone. I love the car. There are a few things I really like over the Photon. I go in to most in the review. As far as does the car make me faster? I think yes. I have TQ'd club night 17.5 sedan 5 out of the last 6 weeks. I have never done this before.
Good luck,
Troy
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
