Like Tree1Likes
Old 03-01-2011, 07:19 PM   #1921
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Maybell View Post
In 17.5 no boost I am running a Kimbrough 96t with a 50 tooth pinion. That makes a 3.8 final for rubber tire racing.
Sean Maybell is the MAN!!
Speaks the truth...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 03-01-2011, 07:42 PM   #1922
burgboyz's Avatar
Trader Rating: 70 (100%+)
Originally Posted by StewartFan20 View Post
Thanks for the info. I can see where the spool would give you more on power steering. I mainly run on very low traction carpet track. I think the reduced on power steering of the front diff may help in my situation.
Were you running a gear diff in the rear? If so, what diff fluid?
Very, Very, Very low traction carpet!!!!
I will be running the spool. You and Scott with the gear diff. We should have good data to compare as soon as I can get up to speed!!
Rusty... Very Rusty!!!
See ya Sunday.?.?.?
burgboyz is offline   Reply With Quote
Old 03-02-2011, 05:09 AM   #1923
StewartFan20's Avatar
See ya Sunday.?.?.?
Is this who I think it is?
If it is, awesome! welcome back!! You will like the car.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 03-03-2011, 07:42 PM   #1924
rcscoot2539's Avatar
Default HELP
Does anyone know were I can fine 10x5x3 mm bearings at?
TC6 - B4.1 - LOSI SCTE - LRP - SPEKTRUM - SWEEP - AB CHARLES HOBBY SHOP - THE RACEWAY AT BEAVER
rcscoot2539 is offline   Reply With Quote
Old 03-03-2011, 09:04 PM   #1925
olhipster1's Avatar
Trader Rating: 96 (100%+)
Send a message via Yahoo to olhipster1
Default try Avid rc
did you try Avid RC.
believe they should have most bearing sizes...and very well priced.
Try it.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 03-04-2011, 04:56 AM   #1926
Timbulb's Avatar
If I was advertising a hobby shop in my signature I would hope they had a common bearing size in stock or at least could order them for me. Otherwise I'd be changing my signature.
Timbulb is offline   Reply With Quote
Old 03-04-2011, 07:39 AM   #1927
Quick question about kit contents: Were the kits supposed to come with the entire set of sway bars? I only had small black bars.
blanchjd is offline   Reply With Quote
Old 03-04-2011, 07:44 AM   #1928
no, 2 sway bars one for rear one for front included, car works great with this.
thilo-alexander is offline   Reply With Quote
Old 03-04-2011, 07:44 AM   #1929
nope, just the blacks
Serzoni is offline   Reply With Quote
Old 03-04-2011, 08:50 AM   #1930
Thanks.
Old 03-04-2011, 11:08 AM   #1931
rosko's Avatar
Come on ae were waiting on a gear diff
rosko is offline   Reply With Quote
Old 03-04-2011, 11:52 AM   #1932
twk-b's Avatar
Send a message via MSN to twk-b
+1
and some sexy blue weights to go down the center line, and replace the x-ray ones on the corners!
-b
twk-b is offline   Reply With Quote
Old 03-04-2011, 03:40 PM   #1933
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
+1
and
Wide hexes in an assortment of sizes
Multi-jointes CVD universals and whatever parts to make them work
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 03-04-2011, 03:51 PM   #1934
hanulec's Avatar
Trader Rating: 27 (100%+)
it is very hard to find cheap 5x10x3 bearings.. i would recommend moving away from whatever is causing you to run those bearings. you look at the wall, not even touch it, and the bearings self destruct...
i think you best bet is to search the various HK web sites...
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-04-2011, 04:50 PM   #1935
Avid carries them as well as ESKY helicopter bearings PN EK1-0288. I do not know the quality or toughness of either.
Troy
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
