Like Tree1Likes
Old 02-23-2011, 04:38 AM   #1891
rosko's Avatar
Jeff what is your shock settings? Position on tower, piston, oil, springs
rosko is offline   Reply With Quote
Old 02-23-2011, 05:04 AM   #1892
StewartFan20's Avatar
Originally Posted by f1o7x9 View Post
would the yokomo BD5 Gear Diff fitt the tc6. and if it dose what do i have to do to make it fit
I just got my diffs yesterday. I'm going to build them tonight so, I'll let you know. My understanding is the drop right in without the thin shims on the outdrives, and the out rives need to be drilled out with a 6mm drill bit so the dog bones fit.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 02-23-2011, 05:19 AM   #1893
JRXS_chris's Avatar
They'll drop in. You will notice however that the shock tower mounts won't go back over easily though. It's best if you dremel about 0.5mm off each side of the diff casing where the bearing pushes on to get them closer to the centre.
And you're right about drilling the outdrives.
JRXS_chris is offline   Reply With Quote
Old 02-23-2011, 07:53 AM   #1894
It's best to do all the work on the long side of the diff regarding removal of material for the bearing seat as the diff mounts too close to left rear bulkhead in it's standard position, this will effectively line up the belt pulleys, just watch for the d'shafts bottoming out on suspension compression especially at high neg camber values, you will also need to slim down the associated blades for a free fit in diff half after making clearance for d'shaft ball, the associated blade extends past the ball less than the included yoke blade and gives better clearance for actuation without bottoming out.
Steve UK is offline   Reply With Quote
Old 02-23-2011, 09:53 AM   #1895
thanks guys. ok yea let me know if is hart to do. and maybe you can post and pic to see what there are talking about thanks
f1o7x9 is offline   Reply With Quote
Old 02-24-2011, 04:50 AM   #1896
I got the diffs in last night. The 6mm drill bit was too small. I had to use a 1/4 inch (about 6.3mm) drill bit. I also had to sand the blades to make them a little thinner.
The diffs did fit, but they were a little tight. A little sanding on on the diff hosing, where the bearing go fixed that.
Old 02-24-2011, 07:32 AM   #1897
what oil are you going to use.
Old 02-24-2011, 07:47 AM   #1898
I'm starting out with 100,000 in font and 1,000 in the rear.
Old 02-24-2011, 09:01 AM   #1899
you going to run a gear diff in the front to
Old 02-24-2011, 10:25 AM   #1900
Yes.
Old 02-24-2011, 11:30 AM   #1901
rcscoot2539's Avatar
On my Tamyia car I was running 500,000 front 60wt shock oil in the rear. It was a killer set-up
TC6 - B4.1 - LOSI SCTE - LRP - SPEKTRUM - SWEEP - AB CHARLES HOBBY SHOP - THE RACEWAY AT BEAVER
rcscoot2539 is offline   Reply With Quote
Old 02-24-2011, 11:54 AM   #1902
I've got some heavier diff fluid coming. I'll probably end up at 500k. The 1k feels thicker that I thought it would be. I imagine I will go lighter. I'm thinking 500 in the rear which is like the new Associated 40wt.
Old 02-24-2011, 02:33 PM   #1903
wtcc's Avatar
I felt no handling or time difference with gear diff with 100.000cst oil in front in comparison to the slipper spool when using 17,5t unboosted electronics.
wtcc is offline   Reply With Quote
Old 02-24-2011, 08:43 PM   #1904
what if I am running mod class will it work better and we'll make a difference
Old 02-24-2011, 11:17 PM   #1905
CristianTabush's Avatar
From our experience last weekend at the February freeze Race in Dallas, we tested the Gear diff up front with a boosted 17.5 and 300,000 cst on high grip carpet, the car lacked steering vs the slipper spool set-up. We settled for running the slipper spool. The gear diff will probably require some more aggressive adjustments to get the on power traction the spool gives.
All in all it was a great showing at the race for me and my buddies running the TC6. We finished 2nd (David Joor) 3rd (myself) and 4th (Ron Atomic) with Mike Dumas taking the win. Considering this was our first race out with it, and the fact that our 3 TC6's were all within 5 seconds of Mike's qualifying time it is safe to say the cars ran awesome! In the main, David finished about 6 seconds off of Mike and I managed to stay on the lead lap 2 seconds behind Dave, with a TC that had a severe understeer going into tight corners.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
