Like Tree1Likes
Old 02-21-2011, 06:49 PM   #1876
Originally Posted by Brian Bosley View Post
3a is pretty good on carpet plus you dont get as much flex in the plastic as 0b unless you are traction rolling, then 0b or 1b would be better for you.
What do u mean about the plastic flexing???
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 02-21-2011, 06:50 PM   #1877
Originally Posted by Rocko231 View Post
Is there any date yet for the release of the replacement parts for the front bulkheads? I crashed warming up for the main and stripped one of the arm mounting holes on the left side.
Bulkheads are available.
Old 02-21-2011, 08:39 PM   #1878
rosko's Avatar
Jeff have you tried your tc6 in stock racing if so what are your roll centers F/R
rosko is offline   Reply With Quote
Old 02-21-2011, 09:05 PM   #1879
0s up front 1s in the rear.
Old 02-21-2011, 10:42 PM   #1880
StewartFan20's Avatar
Is that for high traction carpet?
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 02-22-2011, 05:51 AM   #1881
Yes upper hole in bulkhead.
Old 02-22-2011, 06:10 AM   #1882
What would you do for low traction carpet?
I've got the kit settings up front and I've raised the roll center from 2-dot to a 3-dot in the rear. The car has decent traction, but it is too tight in the center of the corner. I would like the car to rotate through the center a little more. I have the heaviest sway bar up front and the lightest in the rear. I have 50 Losi shock oil up front and 45 Losi in the rear. I've also gone up one spring rate from kit on the front and rear. The rest of the setup is kit.
Thanks in advance.
Old 02-22-2011, 06:28 AM   #1883
Thanks in advance.
Try not running the sway bars. I never liked sway bars. What caster you running and what camber?
Old 02-22-2011, 06:47 AM   #1884
I haven't tried it without sway bars. I'll give it a try.
4* caster
1.5* camber front
2.5* camber rear
Would shorter camber links help?
Old 02-22-2011, 07:47 AM   #1885
4* caster
1.5* camber front
2.5* camber rear
Go to 2 camber and shorter links in the rear and try 6 degrees. Car should be much better.
Old 02-22-2011, 07:53 AM   #1886
I'll try that this weekend.
Thanks.
Old 02-22-2011, 09:05 AM   #1887
If you are really picky, you can mount 0's and 3's with lets say a 2mm metal shim from the bulkhead and the 0's give the car more track width because they bend out at the bottom a very slight amount. Some people think that they flex inwards while the car is in motion, could be true which would make those carbon pieces found earlier pretty nice.
3a front, to 0b rear (anti-dive) is a 2 degree caster change so it will lower your roll center quite a bit to just use 3a's over 0b's.
I used to like the idea of the plastic clips because they would brace the 0's against the bulkhead but I am using aluminum spacers and 3a's now because it was too much effort to crush the plastic equally around the entire car (too easy to have left/right toe off)
Support those that support us
http://ActivRC.com http://TeamPowersUSA.net http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 02-22-2011, 10:27 AM   #1888
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Thanks in advance.
In addition to what Jeff said, and you want to run an anti-roll bar, don't run the heaviest up front if you are looking to get the car to rotate. A front bar reduces weight transfer to the front end in cornering, and 99% of the time will increase rear grip provided that you are not overloading the rear tires already. I would try 0b front and 1b rear roll centers, with either the kit silver/green springs and black roll bars, or blue/silver springs with no roll bars. 6 degrees of caster, 1.5 front, 2 deg rear camber. The higher in caster you go the less front static camber you need because you increase camber gain with caster.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-22-2011, 11:00 AM   #1889
Thanks for the info.
Going to be a busy weekend. I have a lot of things to try.
Old 02-22-2011, 02:42 PM   #1890
would the yokomo BD5 Gear Diff fitt the tc6. and if it dose what do i have to do to make it fit
f1o7x9 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
