Like Tree1Likes
Old 02-16-2011, 05:27 PM   #1831
mattleegee's Avatar
Would i hate my life if i bought a used TC5 instead of getting a new TC6
i dont know the big differences... i only got to page 18 - lot of chassis flex talk and TC5 parts working on TC6 except the outdrives... and the new shocks with the build on the outside which i love on my v2 offroad shocks...
anything else?
AE ft b4.1 Ballistic 13.5 + SXX comp v2 (3-5-3-8) 1258tg
AE ft b4.1 Ballistic 17.5 + SXX comp v2 (3-7-0-4) 1257tg
BRCR
I pick things up and put them down
mattleegee is offline   Reply With Quote
Old 02-16-2011, 05:30 PM   #1832
Kevin H: I remember on your TC5 you ran the double jointed front shafts either Losi or HB, are you using them on the TC6? If so, what parts, if not, why?
Thanks!
Murray is offline   Reply With Quote
Old 02-16-2011, 05:35 PM   #1833
Buckaroo's Avatar
One man's opinion, the unqualified answer to your question is: Yes. I say that owning two TC5s, one TC6, and having another TC6 on order.
The TC6 in basic form fixes all of the brushless/lipo issues that the TC5 had....and required mods and money. Out of the box the TC6 delivers more than the TC5 can fully modded, with NONE of the previous issues.
That being said, the 5 CAN be competative in VTA or RCGT, but it's got some handicaps when compared to the 6 or other first line chassis (Photon/417/T3-11/etc) in the Touring Car class that make it a less than desirable option.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 02-16-2011, 06:08 PM   #1834
mattleegee's Avatar
Thank you Tom, straight forward on what i wanted to hear
BRCR
Old 02-16-2011, 07:19 PM   #1835
walkonking's Avatar
Originally Posted by Warren Weaver View Post
if you are using the ion 3 or duo3 the shaft is long and doesnt have the cut in the shaft far enough in on the motor so the offset spur helps get the pinion in the right spot.
Just turn pinion around. Thats what i had to do Warren.........
pop a clutch, roll a dutch!
walkonking is offline   Reply With Quote
Old 02-16-2011, 08:33 PM   #1836
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
i do have the pinion on backwards i also feel the x ray spurs are much true with less runout
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 02-17-2011, 06:24 AM   #1837
If you turn the pinion around you have to watch it doesn't hit the batt and set screw isn't rubbing the belt.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 02-17-2011, 12:37 PM   #1838
What is a good high end servo to run in a TC6 with a M11x?
dreadwing is offline   Reply With Quote
Old 02-17-2011, 01:05 PM   #1839
Timbulb's Avatar
Savox 1251
Timbulb is offline   Reply With Quote
Old 02-17-2011, 01:51 PM   #1840
Savox SC-1251MG?
Looks like it has pretty fast specs. never used the Savox brand. Do they worl well with a Tekin RS and 17.5?
Old 02-17-2011, 02:17 PM   #1841
walkonking's Avatar
Yea, I had to dremmel the inside of the grub screw (make it shorter) so it would not hit the belt. Hey Jeff, did you turn ur steering knuckles up side down?
Old 02-17-2011, 05:04 PM   #1842
Buckaroo's Avatar
Originally Posted by dreadwing View Post
Savox SC-1251MG?
That's what I'm running, and the Savox works perfectly. Its motor makes some noise, but you can't hear it from the driver's stand! Has stood up to some major abuse, too. Highly recommended.
Tom Keith
Old 02-17-2011, 06:52 PM   #1843
I heard they are a bit noisy but I guess most digital servo's buzz. Any advantage with the 1257 over the 1251?
Old 02-17-2011, 09:23 PM   #1844
Lol this was a funny topic at my track last Saturday. As per the instruction I guess I have them upside down. The ball cup is on the top side of the steering knuckle. It looks better and couldn't find any negative effects on bump steer. Have a month on the car and im amazed on how much the chassis generates traction.
Old 02-17-2011, 11:12 PM   #1845
hanzo3's Avatar
Trader Rating: 55 (100%+)
I picked up a savox. The servo horn for futaba doesn't fit on it. It seems like it is too small? Anyone have this problem? I used a diff futaba servo horn and it fit just fine on the savox.
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28961 07-11-2017 01:29 PM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
