Like Tree1Likes
Old 02-12-2011, 07:54 AM   #1771
xtrememadness's Avatar
Send a message via AIM to xtrememadness
my tc6 has arrived!! i will start the build today and see how it goes
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 02-12-2011, 09:11 AM   #1772
JRXS_chris's Avatar
Originally Posted by muststopcrashin View Post
thanks, i allready have 3* would 3.5* or 4* be to much? rear toe
3.5* will be fine
JRXS_chris is offline   Reply With Quote
Old 02-12-2011, 10:08 AM   #1773
F-1
Hello!
I saw that some Team drivers are turning steering knuckles on their TC6's, why?
Is this mod good or not?
Associated B4.1 - SXX TC V2 - X-12 - Reedy - Proline
Associated B44.1 - SXX TC V2 - X-12 - Reedy - Proline (soon)
Associated TC6 - SXX TC V2 - X-12 - Reedy - Proline
- M11X -
Upgrade Rc 2010 Race Brigade Team
F-1 is offline   Reply With Quote
Old 02-12-2011, 10:37 AM   #1774
Originally Posted by F-1 View Post
Hello!
That give more bumbsteerin and its easier to drive in corners.
I try it and I think it´s good mod.
Team Associated Tc6 | Sanwa M11x | LRP Sxx Tc Spec | Sävox | GM
rrike is offline   Reply With Quote
Old 02-12-2011, 12:28 PM   #1775
daleburr's Avatar
Hello!
With the 0B arm mounts the steering turnbuckles hit the arm mounts if you don't flip the knuckles. You also have loads of bump steer. So well worth flipping them if you run the arms in this position.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 02-12-2011, 02:51 PM   #1776
azz187's Avatar
I haven’t run my tc6 yet but I’ve noticed the turnbuckles hitting the arm mounts on the bench.
If I flip the steering blocks is there any mods I need to do, or is it as simple as turning them upside down??
azz187 is offline   Reply With Quote
Old 02-12-2011, 03:42 PM   #1777
wtcc's Avatar
Just flip them. You have nothing to change. It works fine.
Just one thing occurs: now the turnbuckles (meant was steering block) can touch the wishbone where it got the form for the anti roll bar mount (maybe just if you use the 6° c-hubs). I saw it two days ago and never recognized it while driving. So I think it is no problem (as many teamdrivers drive it that way also).
wtcc is offline   Reply With Quote
Old 02-12-2011, 10:28 PM   #1778
GreenSC10's Avatar
Default 2011 region 11 carpet championships
2011 Region 11 Championships at the Hanger 30 Seattle Wa, C main, I had a rough start check out the video.
http://www.youtube.com/watch?v=XT8pliuBTHg
GreenSC10 is offline   Reply With Quote
Old 02-13-2011, 03:54 AM   #1779
F-1
Where I can find alum washers for lower arm mounts? I see many 3mm washers, but they is 6mm of outer diameter or smallers. I think that I need shims with 7-8mm outer diam. What shims are using Team drivers?
Thanks!
- M11X -
Old 02-13-2011, 04:20 AM   #1780
muststopcrashin's Avatar
Originally Posted by JRXS_chris View Post
3.5* will be fine
thanks mate, in the end i had a crap start to the day,got hit up the back end and wiped out big time (my fault) don't get it by boosted cars.
then just had a real hard time getting the car right again, till i changed shells to a 6 from a speed 6 and from then on car was grate, but all in all it was a good learning day for me and the car.
what would peoples go to shells be if you took 2/3 to every event, as your 1st tuning tool? and why if you don't mind telling me.
MUST STOP CRASHING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RC10(1990),FT TC3,FT TC4,TC5,TC6
muststopcrashin is offline   Reply With Quote
Old 02-13-2011, 06:18 AM   #1781
wtcc's Avatar
Thanks!
They are using these: #4617 Front Bulkhead Shim
http://www.teamassociated.com/cars_a...s_accessories/
Old 02-13-2011, 07:02 AM   #1782
JRXS_chris's Avatar
It depends on the layout at Ardent. In my experience the LTC gives more steering however the MS 6 is more stable. If you've got one the original Mazda 6 is great on high speed tracks.
Old 02-13-2011, 07:03 AM   #1783
JRXS_chris's Avatar
Just one thing occurs: now the turnbuckles can touch the wishbone where it got the form for the anti roll bar mount (maybe just if you use the 6° c-hubs). I saw it two days ago and never recognized it while driving. So I think it is no problem (as many teamdrivers drive it that way also).
I've flipped mine and the ball cups are no where near the arms. You do have the ball studs mounted on the top and not underneath the hubs?
Old 02-13-2011, 07:18 AM   #1784
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Right. The blocks are supposed to have the arm on the high side and the ball-stud mounted underneath (even shows you in the manual ). Steering links are pretty much parallel to the ground and are nowhere near hitting anything.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-13-2011, 07:31 AM   #1785
wtcc's Avatar
(It only occurs if you drive with the 0 armmounts in front.)
This one is nonesense. Sorry.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
