Like Tree1Likes
Old 02-10-2011, 05:50 AM   #1741
Super Moderator
Marcos.J's Avatar
Trader Rating: 166 (100%+)
Originally Posted by Timbulb View Post
Dont worry he is gone
Old 02-10-2011, 08:52 AM   #1742
blanks596's Avatar
Trader Rating: 14 (100%+)
Originally Posted by wtcc View Post
After my horrible crash in the first final of the last race which destroyed one of the battery braces I decided to do some custom ones on my own. The reasons are:
1. TT needs 1-2 weeks to send spares and I hate to wait.
2. I have to rebuild the car anyway.
3. With my weight placing which only works without the center battery brace and antenna mount I am now able to locate the battery 1.5mm closer to the center without touching the belt.
4. The battery now is better supported and has just a minimum space to move if the tape should detach.
5. I also hope this solution will be stronger in accidents than the oem part
Here some pics:
Are those the stock ball cups and ball joints or aftermarket? if aftermarket, what brand? thanks
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 02-10-2011, 09:19 AM   #1743
There stock ball cups.
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 02-10-2011, 10:22 AM   #1744
DaveW's Avatar
Originally Posted by MDawson View Post
Just finished building the TC6. This is the first AE car that I have purchased since the TC3!
Happy that the build went well. No issues with parts, fit or assembly. All systems are go.
Looking forward to following this thread.
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 02-10-2011, 12:16 PM   #1745
Buckaroo's Avatar
Originally Posted by twk-b View Post
96 should give you a good range either way around 4 FDR.
-b
+1. Good starting point for non-boost 17.5
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 02-10-2011, 04:17 PM   #1746
Originally Posted by Josh Hohnstein View Post
From lowest to highest:
1-a
2-a
3-a
0-b
1-b
2-b
3-b
Each step should be 1 deg.
Josh, do you have a tc6 carpet setup? I have used your tc5 setups in the past. thanks
franc furter is offline   Reply With Quote
Old 02-10-2011, 05:25 PM   #1747
Billlance's Avatar
Any advice on rusting screws on my car and tools? Oils?? Gotta love the good ol' state of Florida. HUMIDITY is not my friend.
88 miles per hour is the magic speed.
1.21 gigawatts will get me there.
Billlance is offline   Reply With Quote
Old 02-10-2011, 08:18 PM   #1748
walkonking's Avatar
I hope this car is better on the track then the pain in the ass build, problem after problem! I have built a lot of cars in the 14 years i have been racing and I have to say this TC6 is the WORST!!!!!!!!!
Anyone want to buy it? $350 shipped............................
pop a clutch, roll a dutch!
walkonking is offline   Reply With Quote
Old 02-10-2011, 11:07 PM   #1749
hanzo3's Avatar
Trader Rating: 55 (100%+)
Where can I get new arm mounts and the arm mount bushing?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 02-10-2011, 11:35 PM   #1750
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
get titanium screw and also spring steel tools !
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-10-2011, 11:38 PM   #1751
kschu's Avatar
Today the repair/maintenance of my car came to an end. I also concluded my rebuilds. The car has now new Lipo braces, a more centered battery position and carbon arm mount spacers all around.
The final work today was the build and install of a gear diff. I filled it with 1000cst oil and will try it with my unboosted 17,5t electronics on a high grip carpet on friday. I am really curious how it will perform, because I have no experience with gear diffs yet.
why the camber link mount like that ???
Old 02-11-2011, 02:10 AM   #1752
wtcc's Avatar
No special reason. I tried all the opportunities for the camber link positions this car gives and couldn't make out differences on the clock. So I stayed with this option as it is easy to setup the link degree with shims (and with that an easy way of fine tuning the behaviour of the car) and you can use the long links.
wtcc is offline   Reply With Quote
Old 02-11-2011, 02:27 AM   #1753
daleburr's Avatar
The build does take some time if you want everything to be perfect. I spent about 3 weeks on mine.
But once it's on track the effort pays off, the car is fantastic. I've never driven anything that has as much high-speed steering as the TC6 while still remaining stable and predictable.
Run the car before selling it, otherwise you will regret it.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 02-11-2011, 02:56 AM   #1754
Timbulb's Avatar
You can probably do it quicker if you spend more than 10minutes a day on it.
Timbulb is offline   Reply With Quote
Old 02-11-2011, 03:04 AM   #1755
walkonking's Avatar
Your right Dalebur, I will stick with it! Everybody says how great of a car it is on the track. Rear camber links hit rear shock tower, hinge pins did not fit in arms ,steering knuckles or rear uprights. The instructions are the worst. Sorry to be ranting but I'm letting off a little steam guy's. I'm sure it will be fine thou.
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28952 05-01-2017 04:47 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
