Like Tree1Likes
Old 02-08-2011, 08:10 AM   #1726
Hi!
trf416 belt or yokomo ?
Anyway, if you use a lot of weight, there is some move on double side foams?
Maybe better is screw them ?
What is total weight of car? And which class you drive?
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-08-2011, 12:52 PM   #1727
wtcc's Avatar
"trf416 belt or yokomo ?"
Yokomo.
"Anyway, if you use a lot of weight, there is some move on double side foams? Maybe better is screw them ?"
Sideways no move. I use a 0.25 mm thick double side tape. It holds the weights a long time and very good, but is also very good removeable. It is a TESA carpet tape with fibers in it.
"What is total weight of car? And which class you drive? "
1400gr., 17.5t unboosted : http://lrp-hpi-challenge.de/ Under "Reglement" and 17.5t you will find everything.
Edit: While I am working with carbon I did also some arm mounts shims that help reduce the leverage effect on the screws:
wtcc is offline   Reply With Quote
Old 02-08-2011, 03:14 PM   #1728
DaveW's Avatar
Good thinking WTCC!!!
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 02-08-2011, 03:34 PM   #1729
Buckaroo's Avatar
+1. Best solution I've seen yet!
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 02-09-2011, 02:13 AM   #1730
Yokomo.
Really like the solution you have here.
Planning on selling any ?
Mark
tc3nitro is offline   Reply With Quote
Old 02-09-2011, 03:02 AM   #1731
wtcc's Avatar
No I am not selling them. Because they are too easy to make. All the carbon I use is from my old TC5 ITF chassis. It was scrubbed during the asphalt season and the radio plate was broken. So if you guys have some unused carbon (or other plastics, fiber material) lying around, a ruler and a dremel you will be able to do these things in a minute
Old 02-09-2011, 03:10 AM   #1732
Default Carbon Arm mount spacers.
Some of the UK Associated team have been running these for a while now, a kit of 8 of each thickness, 0.5mm, 1mm, & 2mm.. They work great and can be used throughout the car for arm mount spacing they also help to stop the mount rotating due to the larger surface area between block and bulkhead.
I believe CML distribution are thinking of producing them as a kit for retail.
Steve UK is offline   Reply With Quote
Old 02-09-2011, 01:10 PM   #1733
Buckaroo's Avatar
Sounds like that's the REAL answer that Associated should be developing commerically.
Tom Keith
Old 02-09-2011, 02:30 PM   #1734
wtcc's Avatar
Today the repair/maintenance of my car came to an end. I also concluded my rebuilds. The car has now new Lipo braces, a more centered battery position and carbon arm mount spacers all around.
The final work today was the build and install of a gear diff. I filled it with 1000cst oil and will try it with my unboosted 17,5t electronics on a high grip carpet on friday. I am really curious how it will perform, because I have no experience with gear diffs yet.
Old 02-09-2011, 08:20 PM   #1735
walkonking's Avatar
What spur gear are you guys using, boosted 17.5?
Thanx!
pop a clutch, roll a dutch!
walkonking is offline   Reply With Quote
Old 02-09-2011, 10:10 PM   #1736
Trader Rating: 19 (100%+)
Just finished building the TC6. This is the first AE car that I have purchased since the TC3!
Happy that the build went well. No issues with parts, fit or assembly. All systems are go.
Looking forward to following this thread.
MDawson is offline   Reply With Quote
Old 02-09-2011, 10:30 PM   #1737
Thanx!
I'm currently using a Robinson Racing 84t 48p spur.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 02-10-2011, 04:57 AM   #1738
Timbulb's Avatar
Thumbs down
Originally Posted by mnbv.cvcv View Post
I dont know hwat kind of controller you have but what you can do is get the same reciver for the two trucks.
Timbulb is offline   Reply With Quote
Old 02-10-2011, 05:31 AM   #1739
walkonking's Avatar
I cant understand why this kit comes with a 48p spur. What 64p gear are you guys using (size)?
Old 02-10-2011, 05:48 AM   #1740
twk-b's Avatar
Send a message via MSN to twk-b
96 should give you a good range either way around 4 FDR.
-b
twk-b is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
