Like Tree1Likes
Old 01-30-2011, 01:22 PM   #1636
Originally Posted by justchris View Post
Please could some one help me i
am looking or the advice on easing
ball studs and thought it was this
thread.
Thanks a lot
Heheh
Put RPM save your time
Regards!
m
ps: or read this: http://cmldistribution.co.uk/news.php?view=0000001651
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-31-2011, 05:47 AM   #1637
RielTime Racing's Avatar
Hey all, I just bought the TC6 yesterday! I'm upgrading from the Tamiya TA05 and I have a question regarding the Front Slipper Spool. I'm used to running a regular diff like the rear set up or a front one-way in the TA05. The directions for the TC6 slipper says to tighten thrust screw fully. Man, that is pretty tight on the diff, should I loosen it at al? It is almost feeling as if it is direct drive diff. Also, as a alternative can I run the front diff like the rear diff build? Let me know what you guys think. What"s been the best set up for you and driving conditions thus far. Thanks!
Sometimes I race R/C, but when I do, I run the Team Associated TC7.
RielTime Racing is offline   Reply With Quote
Old 01-31-2011, 06:17 AM   #1638
thread.
Thanks a lot
If you are looking to free up your ball studs, this is what I did. I put the ball stud in my dremel and polished the ends with 600 grit sandpaper. Then I snapped them into the plastic end. With my dremel set on the lowest speed I spun the ball stud in the plastic end until it rotated freely. Worked well. I did manage to melt one end, so it would be good to have spares. You could use a drill instead of a dremel, that would keep the speed and heat down.
Hope it works for you....really free'd my car up.
*Team High Torque*Extreme RC Mods* Over 250 lbs. experience*
phattyphatty4x2 is offline   Reply With Quote
Old 01-31-2011, 07:17 AM   #1639
Johnn27's Avatar
Trader Rating: 71 (100%+)
I would suggest just getting a spool for up front...
Johnn27 is offline   Reply With Quote
Old 01-31-2011, 07:43 AM   #1640
The slipper spool is meant to act like a spool. It is suppose to be tightened down. The pads are there to give a little slip when you tap stuff. Helps save the outdrives and dogbones when you do.
DJG24 is offline   Reply With Quote
Old 01-31-2011, 11:09 AM   #1641
hanzo3's Avatar
Trader Rating: 55 (100%+)
Just picked one up. Ultimatehobbies does carry it. Any build tips stickies anywhere? Is there a wiki page? My 3x14 screw for bulkhead seems to go past bulkhead. Is that ok?
Chris TRF419 TA05V2
TQ RC Racing Powered by teeth
hanzo3 is offline   Reply With Quote
Old 01-31-2011, 11:52 AM   #1642
JRXS_chris's Avatar
http://www.cmldistribution.co.uk/new...iew=0000001651
Some good stuff here
JRXS_chris is offline   Reply With Quote
Old 01-31-2011, 12:11 PM   #1643
justchris's Avatar
Thanks phattyphatty4x2 and m abramowiaz
I have just assembled the tc6 its very stiff and the front belt
does seem quite tight to the top deck.
But really pleased.
Just out of interest did anyone else find the tc6 very tight at end of build.
justchris is offline   Reply With Quote
Old 01-31-2011, 12:40 PM   #1644
JRXS_chris's Avatar
The belts will free up with use. Just make sure you haven't set the cams too tight and that left and right are set the same.
Old 01-31-2011, 03:21 PM   #1645
muststopcrashin's Avatar
has anyone had there wheel bearings cracking and braking down, i've just cleaned my car and found 3, just the out side ones.
muststopcrashin is offline   Reply With Quote
Old 01-31-2011, 04:18 PM   #1646
jekyll08's Avatar
yup about three broken outer hub bearings
jekyll08 is offline   Reply With Quote
Old 01-31-2011, 04:25 PM   #1647
do you think this is the norm?
MUST STOP CRASHING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
RC10(1990),FT TC3,FT TC4,TC5,TC6
Old 01-31-2011, 04:45 PM   #1648
cheehtae's Avatar
Trader Rating: 15 (100%+)
has anyone notice the plastic ball cups from the shock splitting? especially the front ones, better check on yours. I replaced mine with Tamiya or I guess any other would work but Tamiya is the only spare i had ATM.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 01-31-2011, 04:49 PM   #1649
walkonking's Avatar
Does the TC6 use the same shock springs as the tc3 or 4?
Thanx....
pop a clutch, roll a dutch!
walkonking is offline   Reply With Quote
Old 01-31-2011, 05:07 PM   #1650
Buckaroo's Avatar
Thanx....
Yes, all the same.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28975 10-20-2017 10:40 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
