Old 01-27-2011, 06:32 AM   #1576
mugenize1's Avatar
Originally Posted by Chris Furman View Post
+1
All it takes is a Hacker to slap your car, Then you will see the problem.
mugenize1 is offline   Reply With Quote
Old 01-27-2011, 06:44 AM   #1577
mugenize1's Avatar
Originally Posted by touringdriver View Post
here's the list
Do the bulkheads work I am looking around. I never had the TC5 so I can not check but if someone has a TC5 will you please have a look.
Part # Item
1401 FT Blue Titanium Turnbuckles, 1.30"/33mm
1403 FT Titanium Turnbuckle, 1.65", blue
1418 FT .825" Turnbuckles, Ver. 2
2230 Front & Rear Body Mounting Posts
31058 FT Blue Roll Bar Ballstud
31162 Axle Shim Set
31166 Diff Rebuild Kit
31169 Diff Pulley, 40T
31173 Slipper Spool Pads
31184 TC5 Cam Holder Set
31185 Diff Bearing Cam
31187 Front Belt
31188 Rear Belt
31198 Arm Mount Shim Set
31200 Wheelbase Shim Set
31205 Front Suspension Arm
31206 Rear Suspension Arm
31212 Caster Block, 4
31214 Caster Block Bushing
31215 Steering Block Set
31218 Rear Hub, 0
31221 Inner Hinge Pin Set
31222 Outer Hinge Pin Set
31227 CVA Rebuild Kit
31231 CVA Stub Axle
31232 CVA Bone
31233 FT Axle Crush Tube
31234 FT Clamping Wheel Hex
31237 CVA Pin Retaining Clip
31238 FT CVA Bone Blade
31249 Shock Shaft Ball Cup
31250 FT Shock Bushing
31261 FT Roll Bar, 1.25mm
31264 Anti-Roll Bar Mount
31269 FT Anti-Roll Bar Kit
31280 Ballstud, short, 5mm
31281 Ballstud, short, 8mm
31286 FT Ballstud Washer, aluminum
31400 Bearing, 5 x 8mm
31401 Bearing, 10 x 15mm
31404 Bearing, 6 x 10mm
31556 TC5 Castor Blocks, 2 (Hard)
31558 TC5 Castor Blocks, 6 (Hard)
31563 Rear Hubs, 0.5 (Hard)
31564 Rear Hubs, 1 (Hard)
3897 Pivoting Body Mounts, 8 body clips
3906 D-Drive Ring
3941 FT Green Spring, 12.0 lbs.
3942 FT Silver Spring, 14.5 lbs.
5407 Red Silicone O-Ring
6465 Shock Piston, PTFE
6475 Preload Spacers, Collars, Cups
6573 Diff Thrust Washers and Bolt
6574 Precision Diff Thrust Ball, 5/64"
6581 Carbide Diff Ball, large, 3/32"
6582 Diff Thrust Spring
8828 Anti-Roll Bar Cup Set
9180 Servo Horns, molded
************* All FT Srings Fit
************* All Caster Blocks
************* All Rear Hubs
Old 01-27-2011, 07:12 AM   #1578
daleburr's Avatar
Originally Posted by mugenize1 View Post
Yo guys do TC5 bulkheads fit the TC6. If so why not use them till Associated fixes the problem?
No the bulkheads don't fit, totally different.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 01-27-2011, 07:25 AM   #1579
mugenize1's Avatar
Originally Posted by xtrememadness View Post
i was lookind at snowbird pics and noticed kevin hebert is running different bulkheads on his tc6 with arm mounts from the tc5 his screws are threaded into the arm mounts not the bulkhead. maybe this is a significant problem
Can you post a pic
Old 01-27-2011, 07:42 AM   #1580
mugenize1's Avatar
Yes I see it now I was just looking at the TC5 manual online. So how do we fix this lil probelm that the TC6 is having
Old 01-27-2011, 08:08 AM   #1581
daleburr's Avatar
Superglue, or maybe arm mounts from a different car (I'll measure up some Schumacher Mi4 ones when I get time as they seem to work without issues).
Team Xray
Old 01-27-2011, 08:45 AM   #1582
twk-b's Avatar
Send a message via MSN to twk-b
Originally Posted by pcar951 View Post
Wow, this suspension mount issue is getting a life of it's own here. Honestly, I race 2 TC6's indoors on carpet (CRC boards), probably 1000 laps a week including practice nights, have not had a "significant" problem with these mounts. I don't get it!
+1
I have seen some minor issues where the blue insert has rolled around slightly (after 5000 laps), and it only happens in the from arm mount. This has not caused me any grief, only that it takes a minute longer to get the blue inserts out. I had similar issues in my TC5R when I ran the same setup for a long time.
I do check the car flor slop regularly, and might make an adjustment to the arms once a night. Like any other part after getting slammed enough times you might want to replace it to reduce the slop (usually at the same time you replace inner hinge pins)
I am wondering if you could insert them slightly off center (or maybe this is happening by really cranking them down)?
I am wondering if most the people having the issue upgraded from a TC5 (or otherwise came across TC5 parts). I know I have a lot of the arm mounts left over and might have thrown in some TC5 ones instead. Obviously the new ones have a new part number (because they includes the 0s), perhaps there is a slight difference in hole size to match the new blue inserts (which I haven't seen a part number for)?
-b
twk-b is offline   Reply With Quote
Old 01-27-2011, 09:05 AM   #1583
Blue Screw's Avatar
Send a message via AIM to Blue Screw
where in the world is jeff "the setup master"cuffs.... just wait guys till he has his standard steup out for u to try its gonna make u love thecar even more
Angelo DAlessandro
AE~REEDY~LRP~JCONCEPTS~NOVAROSSI~HUDY~IRS~KALGUARD ~ABSOULUTE HOBBYZ~GRAVITY-RC~TnT CUSTOM GRAPHICS
NITRO ONROAD
XRAY~RCAMERICA~HUDY~SRC~MURNAN MODS
Blue Screw is offline   Reply With Quote
Old 01-27-2011, 09:07 AM   #1584
Anyone know of someone with a tc6 for sale?
CEFX Photon/Boss motor sports/Thunderpower motors/Savox/Airtronics
Tommy Kitchens
aka: STRAIGHT LINE
devilsquid is offline   Reply With Quote
Old 01-27-2011, 09:36 AM   #1585
mugenize1's Avatar
AATSCO store on ebay has them instock Now
Item number: 230576681525
Item location: New Jersey, United States
Dinball store on ebay has them
Item number: 380311737426
Item location: Hong Kong, Hong Kong
tcx7046 also on ebay has them
Item number: 280618342229
Item location: kirkland, WA, United States
Old 01-27-2011, 10:37 AM   #1586
Buckaroo's Avatar
Originally Posted by twk-b View Post
+1
-b
Different inserts, won't work, and can't accidently mix them up that it doesn't become instantly obvious. The TC5 ones have internal threads. The TC6 ones are smooth bore.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 01-27-2011, 10:50 AM   #1587
twk-b's Avatar
I mean the plastic arm mounts the blue sleeve goes into. Is the outer diameter of the new sleeves the same as the old ones? and are the wholes in the plastic arm mounts the same size?
what I am suggesting is perhaps mixing TC5 arm mounts with TC6 arm mount sleeves = bad?
Old 01-27-2011, 11:08 AM   #1588
xtrememadness's Avatar
Send a message via AIM to xtrememadness
woops guys! i didnt realize i was looking at 2010 pics it was his tc5 with some tc6 parts!!
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 01-27-2011, 01:36 PM   #1589
Buckaroo's Avatar
Nope, sleeves have the same outer dimension, and the holes in the arm mounts are the same, too. In any case, I built my TC6 from parts in the TC6 box! No chance of cross polination on that one.
Tom Keith
Old 01-27-2011, 02:56 PM   #1590
mugenize1's Avatar
So we should be able to use this part from the TC5 and put the screw from the inside the only problem I see is that it will have to be threaded on the bulkhead also, would this cause a problem you guys think.
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28947 03-17-2017 11:30 AM
Team Associated TC5 RCknight Electric On-Road 13249 01-14-2017 06:34 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
