1/10 Touring Car Advice
the tamiya TA05 variants are the best value for money, get an IFS-R (if u can find one) or a TA05V2 chassis.
they handle awesome, and can beat carbon chassis cars if driven well.
once you want something more, you're better off buying a higher end chassis than modding the TA05..
Alot depends on what you want to do with it. Bash or race? New or used? If you're looking for a race car, the TOP Photon is one of the most competitive cars on the market and also happens to be the best bang for the buck. $380 and it comes with 2 chassis' and an extra suspension set (arms, knuckles, caster blocks, rear hubs) at no charge. If you're looking to bash, you can usually find a used TC3 or TC4 on here pretty reasonable.
Since associated is finaly coming out with a new car you should be able to grab a TC5 at a halfway decent price. its a good competitive car
Bottom line though, figure out what car there running at your local track because thats what your really going to want to steer twords brand wise. Buy somthing parts will be easy for you to come by. Everybody races X-ray here so I have to carry a hobby shop around with me. Broke a part at my last race thats a stupid any hobby shop should have on the wall part (hinge pin brace) and just didnt think to have one in my spares box because its not somthing I've ever broken on a touring car before. I acctualy didnt break it but had a screw vibrate loose and lost it on the track somewhere. Still, it would have been nice if I had a car that I could have gone and bought that $2 part for and kept racing, I got lucky and made some cobed up rig work for the mains
But otherwise a shaft driven car would be better. They are more direct, and durable, and lower maintenance. They cost less to repair and maintain. A TC3 or 4 would be good here. But they suffer from torgue steer.
Speaking of TC3....I just picked one up for 125 used. Stock. I'm a off road guy myself and was wondering what I should do as far as up grades and whatever else. We all know how this goes. Motor, carbon, suspension, servo bla bla bla. Not sure I'll compete but need to make better.
go with a t3r great price, great handling car!!!
I like the Kyosho TF-6. I'm looking to get into electric TC, too; And so far, it's either this or the new TC6 from Associated.
Handles great, some of the upgrades I'm planning are replacing the stock steering assembly with the dual bellcrank setup from the Nitro TC3 and upgrading the motor mount setup to avoid tweeking the chassis.
A common upgrade is moving the battery inwards towards the shaft by removing some of the reinforcements below the shaft.
There are some awesome tutorials out there for all this stuff...
You can also swap out some of the TC4 parts - There's a full FAQ on the AE website that lists all the interchangeable parts.
IRS used to make some lightweight shafts for the tc3, the rpm blue ball ends are strong too.
Another tip is that the rear shock tower fitted up front allows more aggressive shock and camber positions, giving a lot more steering - this is needed if you run a locked front diff (locked diff takes away steering. . .)
