Bearing preperation and rebuilding >
Old 05-25-2004, 06:36 PM
FUK_WRX's Avatar
Default Bearing preperation and rebuilding
Just curious, do you rebuild your bearings? or rather replace them with new ones?
If you do rebuild them do you have tips what oil to use etc..
And new bearings do you flush them out and re-oil them? One of the fast guys in the track said to flush out bearings and re-oil. Im all confused.
All comments welcome.
FUK_WRX is offline
Old 05-25-2004, 07:58 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
usually you can flush them out with motor spray, let them dry, and then put very little oil on them.
This is really good thing to do with bearings that you don't know what kind of lube was used on them.
Cain is offline
Old 05-25-2004, 08:16 PM
Default Bearing Maintainence
ok .. I flush out and relube even new bearings just becasue most come with a grease in them rather than a lube .. and that grease adds rolling resistance / kills top speed ... also .. depending on where you run I also remove one of the shields of the bearings from my TC3 this also reduces rolling resistance .. I only do this on my carpet chassis tho .. not on My outdoor chassis ... removing the shield reduces bearing life and increases needed maintanence but it really helps the drivetrain be as free as possible .. if you do this ... put the shielded sides out and the unshielded together in the wheel hubs ... and the shielded out on the diff cases ... I even go as far as for the main shaft support it uses two at each end .. so the totally sealed in one I remove both shields ... for maintainence ... I soak the bearings in denatured alcohol over night after removing a shield ... then give a quick shot of motor spray .. let them dry ... and I use Trinity Royal Oil myself ... its purple and runs about like water would its a very thin oil ... and I put 4 drops in for small bearings .. and one drop inbetween every other ball in bigger bearings .. so like a wheel hub 3/8 inch od bearing usually has 8 balls in it ... I do one drop at the four cardnal directions .. like looking at a clock face .. 12 3 6 and 9 ... and on bigger bearings .. I do one drop inbetween every other bearing ... so like 6 or 8 drops in a diff support bearing .. for the bearings inside a diff I usually leave in the factory installed grease .. or if a bearing is getting gritty in there I use a heavier oil .. usually the Trinity Stock Bushing Oil ... just to keept eh maintainence down ... I redo my main bearings at least once a month .. usually more like every other week .. during carpet season .. outdoors .. I do them every week ... just because of the increase in dust and fine grit getting in there from parking lot running ... hope this helps ...
have fun racing
E
roddude65 is offline
Old 05-25-2004, 08:26 PM
FUK_WRX's Avatar
Hmm thanks........ is singer sewing machine oil as thin as the trinity royal oil?
And do you guys rebuild every race meet? Thats damn hard and time consuming anyways all comments welcome.
-Luie
FUK_WRX is offline
Old 05-25-2004, 08:46 PM
evaa's Avatar
basically, i do what the others have said, but after cleaning the bearings, i try to spin them, you can see which bearings are already shot, the bearings that are smooth even without oil are lubed and used on my car, whereas the bearings that are no longer smooth will be cleaned again. after being cleaned the second time and are still not as smoth, then they are either thrown away or lent to a competitor . seriously though, after checking which bearings are still ok i lube them with a synthetic bearing oil (FUKWRX, i beleive i included a synthetic bearing oil in the package i sent you), seal them, and youre set.
i usually clean brand new bearings and relube them. however, when i got the xray, i felt that there was no need to do my usual bearing preps, seems like the blue sealed bearings are really of high quality.
o another thing, i've long been wondering, has anyone ever tried tribu comm drops as bearing oil?
evaa is offline
Old 05-25-2004, 08:51 PM
evaa's Avatar
-Luie
Luie,
dont think so, i think singer sewing machine oil is a tad thicker.
rebuilds depend on the condition after a race, but when a big race is up, a rebuild is imperative.
Jon
evaa is offline
Old 05-25-2004, 08:56 PM
FUK_WRX
during the indoor season carpet racing I rebuild every other race date ... at big races I rebuild between rounds even ... or take a second set and use fresh rebuilds every round ... for outdoor racing .. I rebuild every race date ...
have fun racing
E
Old 05-26-2004, 07:29 AM
jeepnyy's Avatar
I use ultra-sonic jewelry cleaner with wd40. The ultrasonic breaks down the dirt & grime that got stuck in the bearing and removes it from the metal. I put a couple of drops of Zubak's bearing oil before the race. I clean them after every weekend race. For storage after the last race of the season...After cleaning I soak them on oil in a zip lock bag till next racing season. Some says they use Duralube or Restore or something like that...I don't know if it works or not. It wouldn't hurt it .
jeepnyy is offline
