Old 06-01-2004, 04:52 PM   #16
Send a message via AIM to ZER01
Alright my turn: )...
Burbs, true, loosening a diff screw after it is fully tightening is bad as you might break the diff bolt-I know I've broke a shet load of yok diff bolts and yes I can see where tightening a diff bolt too tight will leave pitts the naked eye cannot see but affects performance. It's best to tighten the diff up untill it cannot slip by hand while holding both outdrives. The niftech tool can be used two differant ways that I know of and that is 1, use it to fine tune two diffs after you've tightened them both up to where they don't slip by hand and 2, Use only the tool to rebuild or assemble new diffs. Both are gonna get you in the ball park.
Now the tool just needs to be digital reading down to the thousandths...: )
ZER01 is offline   Reply With Quote
metal spider diffs or ball diffs in mini inferno? JEFFRO503 Micro and Mini Scales 3 01-11-2008 10:48 AM
ball diffs thommo09 Australian Racing 3 08-16-2006 02:59 PM
Ball Diffs EVADER RACER Australian Racing 4 02-16-2004 02:16 AM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 03:43 PM
ball diffs nitroblade Nitro On-Road 0 05-13-2003 06:32 AM
SEO by vBSEO 3.5.0
