New Corally 10SL- New World GT car
#62
If you refer to rokosam picture... it is a 235mm version with 2s lipo. The weight limit for pancars with 2s lipo on outdoor tracks is a lot higher then WGT. Normaly 1200 grams.
#63
Yes, my Corally 10SL is 235 mm and uses 2S lipo for outdoor asphalt tracks as we do in Europe, completely different to US indoor 1S specs, I just added 35 gr of weight to balance the chassis. Donīt think this is too much really.
#64
Hi guys, I am now the proud owner of a Corally SP10SL (GT10) car that I indeed to run through the rest of the winter series up at Ardent Raceway and the forthcoming GT10 national series here in the UK.
I indeed to use mine as a 1c/10.5 car.
First thoughts on the actual build, very high quality!! The rear end really is a brilliant bit of engineering! Everything fitted together with no issues what-so-ever.
I particulary like that the centre pivot is in exactly the right place so that so don't have to worry about the pivot moving in a stack (and tweaking the rear end!).
The side links felt a little tight to start with, but after fitting a slightly looser o-ring to each, they are now really free moving but with no play, ideal!
Will now give my car to my mate to do the supergluing/sealing (which he does a fantastic job of!) and will then put the electronics in ready for shake-down/testing.
Cheers,
Chris.
(I put the above on a new thread not realizing there was already a thread for the car!)
Cheers,
Chris.
#66
yeah Corally 10SL is the best chassis I have ever drove.. perfect, fantastic..I am looking forward to run in on asphalt as I used it only on carpet yet.. I hope it will be so nice also in asphalt. If so, I will take a part in german Pro10 national championship. it would be very cool event for me
#67
So what do people think about the new rear end parts to convert away from the side link setup, and bring in the similar system used in the 'V' series cars??
#69
There are some pics from a German website of a similar setup here:
http://www.moosi-masters.com/viewtop...t=313&start=90
You guys should be able to get the new parts (come as a complete package or seperate parts) from Corally USA soon.
Cheers!
Cheers!
#71
Cheers!
#73
My new 10SL arrived yesterday including all options available for the car
I will be using the ProtoForm Sophia body and racing 2S 17.5 motor with boost
Is the kit set up good for a Medium grip carpet , i will be using Corally wheel/tyre combo , i want an easy to drive car to learn with
Thanks Guys ;-)
Thanks Guys ;-)
#75
Thanks Guys ;-)
Thanks Guys ;-)
I have also been running my new 10SL (1c/10.5 boosted) recently and am really happy with it! It seems to have a ton of steering, but not at the expense of loosing rear end traction towards the end of a run. Can easily run fast, consistant laps! What are 'all the options' you mentioned? I have the new rear end parts heading my way but what other parts do you have?
How's about a couple of pics to show us all?
Cheers mate, Chris.
(Oh, and my friend said I can borrow his 2c LiPo's and 17.5 motor to try out if I wish.)
