Modified motor forum.
#16
Originally posted by Brian McGreevy
OleC, from my experience you have to gear the Kr's like they are about 2 winds hotter than they really are.
Also, what are you setting the timing at? For a 12 turn try 15-18 degrees.
Sucks that you guys have to run 12's...being able to run 7, 8, 9, and 10 turns is so nice.
I've tried timing between zero and the third notch, but I can’t feel any change in behaviour. Maybe it’s even a bit “softer” in the low revs with zero timing, now it’s at the third notch.
Well, I guess it forces you to learn how to get the most out of the motor you have. But when you’re not able to figure out how to get it to perform (like now) it really sucks!
#17
Originally posted by Sushi Boy
OleC,
If your cooking 766's in one run there's something wrong. Despite what Reedy usually commends, I run Trinity Purple on the negative and silver on the positive. The Reedy springs are FAR to light to keep the brushes on the com. All the brush bounce could be causing the increased brush wear.
Since it's a 12 turn run a tad more timing than 1 notch (1 notch is about 12 degree's of timing) So anywhere form 12-18 degree's is fine. These Kr/Pt cans don't like mucho timing like some others do .
If you want to try some thing different, you can even try 767's and spring them super hard like with trinity silver springs all around. I haven;t tried it yet, but I have been told it works very well, and since your running a 12T it might giev you that extra edge your looking for. Hope this helps you out some.
-Sushi Boy
OleC,
-Sushi Boy
I have suspected the brush springs to be to light even after I bent them like REEDY recommends.
I have a lot of 767 brushes from stock racing so I have been thinking of testing them but I didn’t know what springs to use so thanks for the tip!
I’ll do some more test and come back to report later.
#18
Tech Legend
you may want to go to www.rccars.com ( or rccar? ) and the Big Jim motor forum as the guys there do alot of tuning to the KR and could help you out.
#19
The D5 is a 2 magnet motor. The Epic Binary mod is pretty much a D5 with 4 magnets. The Orion v2 is a good motor for someone that doesn't want to deal with cutting coms that often. I didn;t think mine was all the impressive powerwise, but Compared to some of my Reedy Kr's eveyrthing feels slow hahahahaha.
-Sushi Boy
-Sushi Boy
Just want to ask what is the big difference from running a quad magnet motor versus dual magnet motor? and is it legal to run quad magnet motors in a legal race?...
#20
Olec- No Prob dude. I actually just met Big Jim in person and talked to him a bit about the motors, so Those tips should get ya goin. A Report on how the 767's work would be really cool. I have a ton of them, but I've already been impressed with the 766's because they are the same compound as the Quasar (stand up verion) and it's probably the best overall standup brush you can get for mod motors.
Wency_TA03R-PRO- Quad mag motors just have less cogging (the notchyness you feel when you turn the motor). They Seem to just have a better powerband IMO. They accelerate really nice. Very controllable and powerful punch. They decelerate alot slower though, so sometimes it catches people off guard. I dont feel I'm explaining this good enough so my best advice is to just try one lol.
-Sushi Boy
-Sushi Boy
#21
-Sushi Boy
-Sushi Boy
For Example: Chameleon 2 sounds like an electric top on crack, Epic Binary sounds like an electric Hemi
#22
Back to the revolution (v2), hard springs are the ticket to run well on carpet in a touring car, with the hard spring, spring brush, and about 28 timing the motors are insanely fast compared to any reedy i raced against. The downside is the motor gets eaten up quickly, and it is a minor pain to change brushs/springs.
I found the medium/hard to work well for ashpault (allows a few more revs), and soft for 12th scale.
#23
Kat-
rcracingkid- The reason for the excessive wear is the amount of timing you have. All the team drivers from orion are running 18-20 degree of timing. If you run 28 degrees of timing you are messing with the powerband too much and causing excessive heat. I have tried an Orion Touring V2 8x1 and that felt good. I think it had some med hards in it, and the sprint brushes.
-Sushi Boy
-Sushi Boy
#24
Okay, My dad got this Orion HAVOK 13t....After frying it he gave me the armature....The comm looks burnt but I was woundering if I can cut it & that'd be the cure.....Can this motor even be cut? (I've heard some non-rebuildables will screw your bit)
#25
D6 Motors...
Anyone have any feedback on these motors? I've heard of racers melting the endbells on this motor!!! I have a 9x2 that i still have to try out, do you gear them differently? What timing is everybody setting it at? I see that factory settings is at 24deg. Should i set it at say 18deg instead and just gear a tooth up? thanks in advance..
#26
The orion V2's are decent motors, but not great by any means if your looking for raw HP. As a sponserd driver I can run whatever I want. My motor builder will build anything I want. The orions are good off-road motors, the are smooth and seem to make good bottom end, but they just have no rip. I race mod oval. Its the king of HP class. When all you see being run are Ti, PT and D5 based stuff, that proabably says somthing. Not that the Revs are bad motors, but watching the mod sedans go at the birds it was very easy to see who had the rip and who didnt. The Reedy and fantom guys were laying it down.
I like running reedy stiff just because the fit and finish of the motors are a little nicer then the trinity stuff, and tend to be a little more effecient. The D5 stuff allways has better spool-up, and sound cooler, but other then that run allmost idetical on the track as any Ti motor. The D6 quads are not as top end oriented as the reedy stuff, and have a little better effi. The Reedy PT's and KR's are awsome motors, but just dont have the effi. that the Ti's have. I like them for carpet tracks when the car is there, but otherwise you have to de-tune it to much to make time, and you loose all the extra power. Off-road and sedan's should have no problem making the extra power last for 5 min.
It also depends on who is winding the motor and what its wound for. That makes the biggest difference. Having someone that can actualy wind a motor specifically for the tracks you race on is very important if your looking for every last bit. Wire size, 4 or 5mm arm blanks, different winding patterens, all make a difference. For the average mod guy, they wont be able to tell the difference in a .5 guage in wire size change, or a different pattern, but if you are looking for everything that stuff does matter.
In the Kr's I allways run 767's or putnam blues. The 767 is an awsome brush. Just take whatever brush you are using and grind down the tips of it for break-in. I do rebuild the motors every run, but the brushes will stay in the whole day for club racing. In any other standup brush motor, the 728's are the only way to go for a long lasting brush that makes decent power. Otherwise I allways use Putnam x-brush. But I will use the 728 if I need to finish stronger.
For setting the timing I reccomend running the motor at 1.5 volts and adjust the timing, until the motor is pulling 10.5-12 amps. I have had some motors that need to be run at 26 degrees, and one of my newer 6x1's that we have been playing with run at 6 degrees for that range. Timing is just a number, it dosent have any real actual correlation to what the motors going to do. If I ran my 6x1 at 18 degrees I would have had no chance to make runtime. Running the motor and checking the amp draw is the only way to tell if the motor is all ok. That dosent mean that most motors can be done with just putting the timing in some range and running it, but to do it "right" running it, and adjusting for amp draw is the best way, without killing the motor.
#27
Thanks alot for a cool well explained topic on the quad magnets.
#28
how many runs are you getting out of the brushes on the kr's do you have to rebuild it after every run.?
#29
#30
