How Do You Store Rubber Tires?
#18
Justr zip lock them. Since they are airtight and cheap, they're perfect. The airtight will keep the rubber good and keep them from cracking. As for sauce, I don't want to add that to my equation, but I don't have any experience on whether its bad. Seems like you ar adding a softening compound for an indetermined time. Also, depending on what tires they are, some don't need sauce. For parking lots, takeoffs work great with nothing or Simply Green.
#20
i store my foams in a tennis can . . .
#21
I just throw em in a crystal lite tube.
#23
I store mine in an empty Pringles can. Fits 2 sets of tires perfectly.
#24
R/C Tech Elite Member
Originally posted by John Fontaine
Does anyone have one of those Seal-A-Meal from the infomercials? This would be a great way to really make them airtight (ig. pressurizing the package and sucking all the air out of it). When I start running rubber tires all the time I might go this route.
John
John
I have that "FoodSaver" vacu-sealer, and it works really well....Got mine from Costco along with extra bags.
#26
Guest
Originally posted by evaa
here's another question, our track does not need tire sauce coz of its natural grip. if i sauce tires before storing them, wont they overheat when i use them after storing them for a few days?
#27
Originally posted by tornado
While the tires are still in the ziplock bag, just throw them into the ccooler box for a couple minutes....that way you would start the run with a cooler tire and end up not too hot at the end and it won't overheat
i think putting them in a cooler bag is out of the question in our track coz it normally requires at least half a lap for the tires to get up to normal racing temp.
#28
If any of you guys now the australian airline company called QANTAS they give you two types of toothbrush bags. they fit 2 sets of 24mm rubbers perfectly. I use Wd40 for my track at night when the ground is cold.
#29
Originally posted by Cole Trickle
And what do you guys do, if you're not allowed to use traction sauce? Just put them in an air tight bag?
Spray them with some WD-40 before putting them in the Bag (Zip-Lock type). Keeps the rubber fresh and soft. Just wipe them dry before installing them on your Car.
#30
Re: How Do You Store Rubber Tires?
Originally posted by popsracer
Cole;
Cole;
i beleive i have a couple of tennis ball containers at home, i'll give them a shot also.
