Old 06-28-2010, 04:33 PM   #1
aznewmanfan's Avatar
Default TC4 gearing
I have a team associated TC4 & I have a mamba max pro esc & a trinity pulse3 turn brushless motor to put in it, what size pinion/spur gear should I start with? I don't race it's just to run in the parking lots.
aznewmanfan is offline   Reply With Quote
Old 06-28-2010, 08:19 PM   #2
Send a message via Yahoo to custom12
well try a 78 sper and a 18/19 pinion. run for a few min then cheack the heat. dont get above about 160 deg f. or you will shorten you motor life. i run a novak 8.5 ss pro. with track temps at around 120/130 i run a 72/28 5min run i am at around 150. or you can just go for a fdr of about 5.5 to 6.5 it all realy depends on your motor temp. and you will have to play with it to find out about what gear to use. hope i helped.
custom12 is offline   Reply With Quote
ft tc4 gearing andy_b22 Electric On-Road 6 06-02-2006 02:05 AM
brushless, gearing, tc4
SEO by vBSEO 3.5.0
