Old 02-09-2011, 08:20 PM   #1261
FangsCPO's Avatar
Originally Posted by simplechamp View Post
I ran into a small issue with my build tonight and wonder if anyone can help.
I mounted up the shocks for the first time, just to test fit and get an idea of mounting positions, ride height, droop, etc. The problem is that there is no droop. The car doesn't "settle in" at all when put on the ground, not even 1mm. The wheels stay at the same height as if you had it lifted off the ground.
I did this test with lipos, motor, ESC, servo, and RX all in the vehicle, so aside from the body it was at RTR weight. I am using springs that are about 28 lb/in with the shock collars adjusted all the way to the top of the shock. Now to me this says the springs are too firm, but I spent A LOT of time researching spring rates for 1/8 on-road and everything I found tells me that 28 lb/in is on the soft end of the spectrum, and that some people use springs going up to 40-60 lb/in or even higher in some cases. That is why I am confused. The numbers always seemed high to me, but everything I found said that was what to use. But now I try it and it seems to firm.
Any insight is appreciated. I have some springs on the way that are between 18-25 lb/in so I guess I should try those next?
Check your sway bars, maybe too tight or placed wrong. Check your "set screw" on your lower arms. Aside from that, I can think of what could be wrong. Good Luck!
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 02-09-2011, 11:47 PM   #1262
kcunamay's Avatar
Trader Rating: 20 (100%+)
Default Can you post a pic?
I'm guessing that the REVO shocks you used are too long perhaps? Or it might be that the geometry of the IGT shock tower coupled with your JAMMIN arms (bottom hole for shock mount) may be different, standing the shocks up more?
Post pics of it mounted and we may be able to help you out.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 02-10-2011, 01:22 AM   #1263
Jspeed's Avatar
Phille’s Ipanema GT Warrior from Stockholm Sweden!
Jspeed is offline   Reply With Quote
Old 02-10-2011, 04:06 AM   #1264
Missle's Avatar
So is it really CF and if so, how in the heck do you press/weave that or is just a thin layer applied to the body?
Missle is offline   Reply With Quote
Old 02-10-2011, 05:36 AM   #1265
Jspeed's Avatar
I don't know how he did it, but it sure looks radical don't it?
GT8 Class--buggy-based on road electric!-philles-ipanema-warrior-gt-racing-body-close-up-front.jpg
Old 02-10-2011, 06:02 AM   #1266
Missle's Avatar
I see. I thought it was one of your high-tech bodies
Old 02-10-2011, 09:00 AM   #1267
carbon vinyl wrap
Joat is offline   Reply With Quote
Old 02-10-2011, 09:07 AM   #1268
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
Originally Posted by FangsCPO View Post
Those are Max Velocity shock towers, I found out about your shock towers after the fact.
Oh ok I like to take care of the West Coast guys over here. Us Navy Vet. need to take care of each other.
Steve
snrscion is offline   Reply With Quote
Old 02-10-2011, 11:04 AM   #1269
simplechamp's Avatar
Trader Rating: 73 (100%+)
Thanks for the suggestions/ideas guys. I can comment on a few things.
The set screws on the lower arms were backed out and not touching the chassis, and also I didn't have the sway bars attached. So those can be ruled out. The Jammin arms are basically identical to Inferno arms (really the whole suspension is almost identical) so that can probably be ruled out as a problem too.
So that leaves the shock length, which is a possibility, but I don't think that's it either. The Revo shocks put the car at the proper ride height using the IGT towers, there just isn't any droop when setting the car down. Even if they were a bit too short or too long that would effect ride height, but the car should still droop a few mm when it's set down. But I could be overlooking something there, and I do admit I don't have much knowledge of suspension geometry.
I still am leaning to the spring rate being the issue. It makes sense that it would be the cause, the only reason I second guess that is because as I said before everything I've found said these springs were right. But maybe a few lb/in is all it takes to be too firm? Would the lower weight of the CF chassis be enough to require a moderately lighter spring? I guess I should weigh the thing RTR and get a comparison to your guys rides, like IGT, DM-1, GTP2e, etc.
I am going to wait and see what happens with a slightly lighter spring, and then if it's still an issue I will take some pics. Thanks again for the help guys!
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 02-11-2011, 01:37 PM   #1270
Today I received my Ofna cam-type motor mount (OFN41125). It is supposed to be direct fit for the Jammin, but I needed 2 small washers on each side underneath the top plate. This motor mount can work for the DM-1 too since it has the same mounting hole pattern as the Jammin (may need a few washers also).
Overall the mount seems very solid, and the two M4 socket-head screws should clamp the cam in place without issue (I was a bit surprised that these screws were not included, have to provide them yourself). The cam itself mounts to the motor with two M3 flathead screws. Looks like there is a fair amount of adjustment available for different pinion sizes (although I don't think quite as much as my RCM mount), and the mount seems to favor smaller pinions and spurs.
I also received a bunch of springs today, so I need to do more testing with my suspension and see if I can get the droop figured out. Hopefully stepping down the firmness a bit will do the trick.
GT8 Class--buggy-based on road electric!-p1030246.jpg   GT8 Class--buggy-based on road electric!-p1030247.jpg
Old 02-11-2011, 02:24 PM   #1271
Pit-racer's Avatar
Thumbs up
treborwd22 you'd probably want to go with the Alpha R2 body and yes you're right on with the SWEEPS!
Team Misfits / www.igthobbies.com / Desoto Racing / Veytrex.com / JZRacing / RcShox / IGT8 Red
Pit-racer is offline   Reply With Quote
Old 02-11-2011, 02:29 PM   #1272
Pit-racer's Avatar
You'll like it very much treborwd22
Old 02-11-2011, 07:05 PM   #1273
Hooray, I officially have a roller! (I still need to adjust the shock settings, toe, camber, etc., so I do know they look a bit off)
I decided to go ahead and order the Max Velocity CF towers from Bill, and those along with the body should be here next week.
GT8 Class--buggy-based on road electric!-p1030248.jpg   GT8 Class--buggy-based on road electric!-p1030250.jpg   GT8 Class--buggy-based on road electric!-p1030251.jpg   GT8 Class--buggy-based on road electric!-p1030252.jpg
Old 02-11-2011, 07:31 PM   #1274
whipnet's Avatar
That's come together nice man.
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 02-11-2011, 08:27 PM   #1275
Thanks, I hope it drives as good as it looks, LOL!
Do I need to run sway bars in both front and rear?
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
