Old 02-08-2011, 05:15 PM   #1246
simplechamp's Avatar
Trader Rating: 73 (100%+)
Damn, $50/pair!
Have you thought about using a set of plastic wheels and trying to paint them with a chrome or brushed alloy effect? Normally I would never paint wheels, but if they are going to be for shelf queen and picture use only?
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 02-08-2011, 08:50 PM   #1247
treborwd22's Avatar
Well it finally arrived!!! Hope to test it out sometime this week and get it ready to race by the 18th!!!
Thanks igthobbies!!!
Team Associated Tc6 "Blinky"
Xray T2 Exotek "Spec GT Class"
Ofna GTP2e w/Tekin RX8 2250kv
Losi SCTE
Spektrum DX3r Pro
treborwd22 is offline   Reply With Quote
Old 02-08-2011, 09:09 PM   #1248
Very nice, love the GTP2e. If I ever decided to convert my Jammin back to off-road I would definitely pick up one of these.
Old 02-08-2011, 09:50 PM   #1249
FangsCPO's Avatar
What gearing are you planning on running?
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 02-08-2011, 10:27 PM   #1250
treborwd22's Avatar
Not sure yet Chief.
I am going to start with a 15t and see how it goes from there. Im not looking for speed but rather something that can get me around the track with consistent lap times.
Losi SCTE
Spektrum DX3r Pro
Old 02-08-2011, 10:35 PM   #1251
I would say your lap times will get much more consistent once you get some wires on the ESC and motor, LOL!
Running the stock body or another? What kind of paint are you doing? Do you paint yourself or have someone else paint it? Do I ask too many questions?
Old 02-08-2011, 10:37 PM   #1252
FangsCPO's Avatar
LMAO!!!!
TLR Team Driver
Old 02-08-2011, 10:39 PM   #1253
treborwd22's Avatar
What kind of paint are you doing for the body? Do you paint yourself or have someone else paint it?
HA!! Yeah I agree with you about the wires. Just couldn’t wait to talk a pic and post it. I don’t paint myself other then rattle can. I am going to run the stock body. I used a 1/4 drill bit on the foam bumper and drilled new holes to bring the bumper closer to the front diff. Once I did that the body fits like a glove with the foam bumper.
Losi SCTE
Spektrum DX3r Pro
Old 02-08-2011, 10:41 PM   #1254
FangsCPO's Avatar
Not sure yet Chief.
I am going to start with a 15t and see how it goes from there. In not looking for speed but rather something that can get me around the track with consistent lap times.
I had mine at 17/48 and it was too damn fast. I dropped down to 16/48 and it seems more controllable. I'll see how she does this Sunday if all goes well. If not, I've got a 15T, I can put in as well. It's always trial and error. Are those slicks Sweeps or OFNA. If they are OFNA, I'll let you know that I tried those out and it was like driving on ice. I was all over the place. The treaded stock are much better and if you go with the Sweeps 45s or 50s, you'll really enjoy how the car handles.
TLR Team Driver
Old 02-08-2011, 10:46 PM   #1255
FangsCPO's Avatar
HA!! Yeah I agree with you about the wires. Just couldnít wait to talk a pic and post it. I donít paint myself other then rattle can.
Nothing wrong with "rattle can". That's how I paint all my lids. It's not fancy but it works for me.
Here's a photo of my three favorite rigs. I'm sure you can pick out my OFNA DM-1 Spec Tekno Conversion.
TLR Team Driver
Old 02-08-2011, 10:48 PM   #1256
treborwd22's Avatar
NO... they are Ipanema 50s. I only use them when my car is at home so my good tires stay fresh locked up in a ziploc bag. Once race day hits.... Out come the Sweeps!!!
Losi SCTE
Spektrum DX3r Pro
Old 02-09-2011, 03:28 AM   #1257
I ran into a small issue with my build tonight and wonder if anyone can help.
I mounted up the shocks for the first time, just to test fit and get an idea of mounting positions, ride height, droop, etc. The problem is that there is no droop. The car doesn't "settle in" at all when put on the ground, not even 1mm. The wheels stay at the same height as if you had it lifted off the ground.
I did this test with lipos, motor, ESC, servo, and RX all in the vehicle, so aside from the body it was at RTR weight. I am using springs that are about 28 lb/in with the shock collars adjusted all the way to the top of the shock. Now to me this says the springs are too firm, but I spent A LOT of time researching spring rates for 1/8 on-road and everything I found tells me that 28 lb/in is on the soft end of the spectrum, and that some people use springs going up to 40-60 lb/in or even higher in some cases. That is why I am confused. The numbers always seemed high to me, but everything I found said that was what to use. But now I try it and it seems to firm.
Any insight is appreciated. I have some springs on the way that are between 18-25 lb/in so I guess I should try those next?
Old 02-09-2011, 12:39 PM   #1258
whipnet's Avatar
Originally Posted by danketchpel View Post
But, if you want to stick with mechanical brakes I'd suggest getting Ofna's special cut rotor part# 49009 and their special pads part# 36659.
This upgrade made a huge difference (thanks!), even with 1 disk and that leads me to a question. Do I need both disk? Seems to be OK with 1 and not fading, but it's also winter time. So do I need both disk, or can I save the rotational mass and run 1?
Thanks again!
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 02-09-2011, 01:00 PM   #1259
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
what front tower are you running on your DM-1?
Steve
snrscion is offline   Reply With Quote
Old 02-09-2011, 08:13 PM   #1260
FangsCPO's Avatar
Steve
Those are Max Velocity shock towers, I found out about your shock towers after the fact.
TLR Team Driver
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
