Old 01-18-2011, 10:07 AM   #1171
pinoy69racer's Avatar
Trader Rating: 175 (99%+)
Default help
i want to used stock dm1-S chassis for brushless set -up anybody knows the part number or where can a get the motor mount that will fit in ...thanks for your help guys
HENRY C
RC TARGET/IGT8 RED /DESOTO RACING/VEYTREX DESIGN LAB
pinoy69racer is offline   Reply With Quote
Old 01-18-2011, 10:10 AM   #1172
whipnet's Avatar
I just did this and have a walk-through and part numbers used here:
http://www.rccoh.com/rc.how-to/dm-1....onversion.html
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 01-18-2011, 10:17 AM   #1173
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
Part #41125 $47.95
snrscion is offline   Reply With Quote
Old 01-18-2011, 10:23 AM   #1174
WildBillMassey's Avatar
Originally Posted by snrscion View Post
Part #41125 $47.95
Has anyone used this on a DM-1Spec?
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 01-18-2011, 10:31 AM   #1175
thank you guys
HENRY C
Old 01-18-2011, 10:58 AM   #1176
Registered User
snrscion's Avatar
No, but if I were to convert my DM1 Spec this will be the route that I will go.
Old 01-18-2011, 11:02 AM   #1177
I guess my question should of been...
Has anyone verified that this will fit?
Old 01-18-2011, 11:07 AM   #1178
simplechamp's Avatar
Trader Rating: 73 (100%+)
I know the mounting holes will line up, but as far as clearance issues with other parts on the chassis, not sure. Should work fine. I am going to try this mount on my Jammin on-road conversion when the RC-Monster mount needs to be replaced.
I got the bumper and body mounts today Bill, they fit the Jammin perfectly!
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 01-18-2011, 11:13 AM   #1179
Originally Posted by Jspeed View Post
Just a quick heads up for you GT racers.
Last Sunday, final real world competition race testing of our new Wide GT rear slicks with great results. Our new Wide slicks offer you more than 20% more surface area than standard width slicks.
This means more traction, performance, lower lap times and a lot more fun than ever before.
They will be available here in the USA within 2 weeks. With the new 2011 year upon us, expect to see our new innovative rear slicks and new rubber compounds getting the job done at a track near you.
All the best!
See ya at the races!
Do these require special wider wheels? Or do they fit standard 1/8 wheels?
Old 01-18-2011, 11:29 AM   #1180
JLock's Avatar
These new tires are already preglued on the wider rims. Ipanema tires are all preglued on BBS, 5-Star, or Dish rims.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 01-18-2011, 11:43 AM   #1181
Sweet!
I'll add that motor mount to the website then, as long as the holes line up, the rest should be fine.
Old 01-18-2011, 12:23 PM   #1182
Default INPUT NEEDED !!
Since I have an older Ofna gtp ,the only motor mount option without buying a conversion kit is rc-monster,currently out of stock and I dont much care for the design, I am trying to produce my own mount,and wanted some input on some designs I wanted to change.
Reversable mount -in the rear center support section, I wanted to make the mount work on either side of the chassis.
3 hole mounting to chassis -similar to ofna's
No recess for motor mounting bolts , this allows you to mount the motor on the either side and also foward on the leftside should I choose ?
Material will be top notch , 7075
LMK thanks
Joat is offline   Reply With Quote
Old 01-18-2011, 01:42 PM   #1183
You can do the slots like RC-M, you can use a slider like Elite RC, or you can use a cam like the Grid and also the Jammin/DM-1 mount. Slots are probably the easiest to make, but if you don't care for the RCM design you might want to do a slider or cam system, but it will be harder to make. RC-M recently also changed the design on a few of their mounts so that the bottom is just a bushing attached to the motor that pivots in a hole, and the top screw provides the holding force, making for easier adjustment. May want to look into that.
If you want to be able to use it in all 3 positions (left rear, right rear, left front) you will need to have a bearing slot on both sides of the mount.
Old 01-18-2011, 02:00 PM   #1184
On the rcm design, I just to dont like the 2 narrow mounting points the ofna, 3 point system is much more stable , I would do slots or an arch and piviot point, on the center mount for the bearing I would not have to do bearing slot, all I need to do is make sure either both bearing holder keeper/flange are either facing each other or facing away from each other at the sametime, either way bearing would be trapped
Old 01-18-2011, 02:03 PM   #1185
I'm not sure I understand how you are explaining the bearing setup. If the bearing flanges/slots were facing away from the bearing it wouldn't have any support?
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 01:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 04:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 10:39 AM
SEO by vBSEO 3.5.0
