Old 01-07-2011, 08:43 AM   #1126
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
Jay you got way too much time on your hands as many kids as you have.
Nice paint job.
Originally Posted by kcunamay View Post
Can't wait for Corona!!!
snrscion is offline   Reply With Quote
Old 01-07-2011, 01:26 PM   #1127
kcunamay's Avatar
Trader Rating: 20 (100%+)
Nice paint job.
Bwahahahahaha!!! Yep I use them to shake the paint bottles. Now, If I could only get them to cut out the mask. lol
Thanks bro!
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 01-07-2011, 01:52 PM   #1128
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Thanks bro!
Was that Lezlie's Xmas gift?
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
|HITEC|PARMA|PROTEKRC|SWEEP|IWATA|RPM|AMAIN|CREATE X/WICKED/AUTOAIR PAINTS|TEAMASSOCIATED|REEDY
charlie_b is offline   Reply With Quote
Old 01-07-2011, 02:03 PM   #1129
kcunamay's Avatar
Yeah it was....you guys are awesome. Thanks brada!
Old 01-09-2011, 08:44 PM   #1130
simplechamp's Avatar
Trader Rating: 73 (100%+)
Can someone give me a brief rundown of what changes will be needed setup wise when converting a 1/8 buggy to 1/8 on-road? I have an idea of diff setup, and a little bit about shock setup, but need to know things like caster, camber, toe, anti-squat, droop. Even if someone could post a setup sheet for any on-road vehicle like the GTP, DM-1, IGT1/2, etc. just so I could get an idea. I searched for DM-1 and GTP setup sheets, but can only find the blank ones that are in the vehicle manuals.
I got my Jammin buggies all torn down and cleaned and went through all the parts and tossed out whatever was worn out. Ordered a few things I needed new and as soon as those come in the on-road rebuild will begin.
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 01-09-2011, 11:24 PM   #1131
RC Passion's Avatar
Great to hear another 1/8 on-road conversion is on its way! Electric or gas? Were u able to mount your body of choice yet? I saw your post on the other GT based thread. Tires are very critical component you didn't mention. Many good tires are out there (Sweeps, Ipanema, PMT, ect). You really need to limit the shocks and/or change to shorter shock shafts and have ride height between 10-15mm. I'd start w/ 1 degree of negative camber on all 4 and tune from there. Try 1 degree of toe out in front to gain steering if your neutral or toed in. I hope this helps...post some pics so we can see where you're at!
Next GT8 race is in Corona Hobby Town Jan 16th! Come and check us out! Nitro or electric.
RC Passion is offline   Reply With Quote
Old 01-09-2011, 11:45 PM   #1132
Jspeed's Avatar
Most of the guys we’ve raced with on the tracks, using stand up shocks in there cars, run something like this should get you close:
Front diffs 10K to 100K, Rear diffs 1K to 30K, both depend on driving style & track layout.
Front ride height 9 to 10mm measured under steering posts, Rear ride height 10 to 12mm under diff.
Front droop 3mm to 6mm, Rear droop 6mm to 12mm off lower outer arm, with shocks & sway bar disconnected.
Front camber -1 to -2 degrees, Rear camber -2 to -3 degrees
Front toe out 0 to +1.5, Rear toe in 2 to 3 degrees
Shock oil: 60W to 100W front/rear depending on driving style & track layout.
Good luck, have fun, hope it helps.
Jspeed is offline   Reply With Quote
Old 01-10-2011, 09:46 AM   #1133
Super Moderator
charlie_b's Avatar
You guys Waited Long Enough!!!
HOBBTTOWN CORONA this Sunday!! Bring out your GT8's peeps! This Sunday, Jan 16 is the day! We been getting 2 heats consistently, so come on out and join the largest GT8 turnouts in Socal!!!
Hobbytown Corona is located at 351 Magnolia Avengue. Suite 101. Corona, CA 92879
Old 01-10-2011, 03:20 PM   #1134
Thank you guys for all the advice! That should get me where I need to be. Unfortunately I don't have any tracks even remotely close to me (Northern Michigan) so I don't race, but I still have lots of fun running in parking lots.
I will be running electric. Have an LRP Vector 8 2800kv I want to try for now until I can buy a Tekin. KV is higher than I'd like but it should be good on 3S and I can still gear it for 40mph on 4S. I will use the EagleTree data logger to compare 3S geared for 40mph to 4S geared for 40mph and see the comparison. A Mamba Max Pro is the ESC.
I did get some tires/wheels. I have one set of Ofna belted radials that I got in a trade, and one set of GRP Rally (Soft B compound) that I found in the FS/FT section brand new. I want to try a set of Ipanema too, that was my original plan, but I came across the others and couldn't pass up the deals.
Still looking for a body, but it's mostly lack of money stopping me there! I love the Ipanema Warrior, but then I also noticed IGT Hobbies started bringing in the Deltaplastik bodies, and they are very tempting! If someone had an old practice body they wanted to sell, that would be a big help to me, doesn't have to be pretty, just a temp until I can buy a nice new one.
Old 01-11-2011, 04:54 PM   #1135
whipnet's Avatar
Finally got a short video of it running. I plan on getting it to the track this week for some better video.
+ YouTube Video
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 01-11-2011, 06:02 PM   #1136
Nice, that thing is quick!
What speed do you have it geared for?
Old 01-11-2011, 06:19 PM   #1137
whipnet's Avatar
It has the 2-speed and 2650 motor. It should run 60mph on 4s and 80 on 6s.
And thanks!
Old 01-11-2011, 06:31 PM   #1138
Wow that is wild, I have my off-road 1/8 stuff geared for 40mph and that seems fast to me!
What do you have to say about 2-speed with electric setups? Is it stable on the shift or does it want to break loose?
Old 01-11-2011, 06:34 PM   #1139
whipnet's Avatar
The clutch is ultra smooth and as far as shifting, I can hardly tell that it does at all.
Old 01-11-2011, 07:41 PM   #1140
snellemin's Avatar
Trader Rating: 16 (100%+)
+ YouTube Video
Quick running monster.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
