Old 12-14-2010, 09:50 AM   #1096
snellemin's Avatar
Trader Rating: 16 (100%+)
Originally Posted by danketchpel View Post
A 4S is faster than a pair of 2S in series though, not 100% sure why of that.
The only thing I can thing off for that issues, is the added resistance of the additional connectors and/or the 2s packs are heavier.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 12-14-2010, 09:57 AM   #1097
I think you might be right about the added resistance of the connectors. I ran a pair of Thunder Power 65C 2S and was pretty happy with the speed. Then I tried a Blue Lipo 4S 40C and went "wow", now we're talking........ it was a very noticeable difference. But I was still pretty competitive with the pair of 2S Lipos. I think the weight was pretty close between them.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 12-14-2010, 10:03 AM   #1098
snellemin's Avatar
What connectors are being used on the Thunderpower?
6 KiloWatt Racer
Old 12-14-2010, 10:07 AM   #1099
whipnet's Avatar
Most people here are sticking to 4 cell batteries, that also gives you the option of running a pair of 2 cells in series if need be. I "suspect" that in the event that rules start to be applied to this class the 4S battery will be the size chosen. A 4S is faster than a pair of 2S in series though, not 100% sure why of that.
I'd suggest the 2650kv motor, that seems to be the sweet spot for most people so far. The Tekin stuff seems to be working very well with no DNFs that I know of. They don't seem to be running too hot either. I'm extremely happy with my Tekin setup so far, it's very smooth, has all the power I can use as I can keep up with anybody on the straights, and has been 100% reliable.
The Castle stuff also seems to be holding up well.
Something else I noticed from your photos. Seeing that you went with mechanical brakes I think you will need to upgrade the rotor and pads. That setup you have does not work very well at all, at least it didn't for me when I was running mine with Nitro power. To be perfectly honest, going direct drive and using electric brakes is the way to go. But, if you want to stick with mechanical brakes I'd suggest getting Ofna's special cut rotor part# 49009 and their special pads part# 36659.
Excellent info danketchpel! I appreciate it.
I use Tekin in other rigs and really like their stuff (plus Jim Campbell is a really nice guy who will bend over backwards for you if you have problems) so I was actually planning on going with the 2650 T8 and RX8 on this as well. Your comments sealed the deal. And good news on the 4s. I was hoping to hear that as well.
I plan on eventually converting to a single speed direct drive and using the motor as brakes, but all of this came with the kit, so I figured I'd try it out for fun first. I'll be sure to pick up the better parts.
Can you tell me what direct drive you used for future reference when I am ready to change it?
Thanks again for all of your info. It is very helpful.
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 12-14-2010, 10:25 AM   #1100
TPhalen's Avatar
R/C Tech Charter Subscriber
I experimented with the motor braking as well, but when back to the mechanical for the main reason that I really think, once dialed in, will greatly benefit these big ol' cars in the turns. Motor braking locks all 4 tires up...not a whole lot of tuning other than making the brakes stronger or weaker. Fooling with the mechanical brakes, however, can help a pushy car rotate through the corners better...as I was able to get working (slightly) better in the main. I think if you have the ability to use them, try them.
whipnet: that setup looks pretty sharp. Liking it!!!
Tony Phalen
UF1 Team Lotus/Renault
RCDriver.com
CompetitionX.com
R Sector / F1 Paint Labs
TPhalen is offline   Reply With Quote
Old 12-14-2010, 10:43 AM   #1101
whipnet's Avatar
Thanks for the info and compliment!
Old 12-14-2010, 12:50 PM   #1102
Did you use differential braking, ie front & rear rotors etc?
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 12-14-2010, 03:42 PM   #1103
kcunamay's Avatar
Trader Rating: 20 (100%+)
I believe so,
The last time I looked at it, Tony was running the TECHNOKIT conversion for his Losi 2.0 with the center diff, f/r brake disks/pads installed. I've yet to get to the "jedi" level, so I'll be sticking with the electric brake setup.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 12-14-2010, 06:08 PM   #1104
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Congrats to the winners of GT8 at the 12th Annual Toys 4 Tots Race!!
Click HERE for more pics!
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 12-15-2010, 08:39 AM   #1105
TPhalen's Avatar
I used the stock Losi front and rear bias brake setup. Worked pretty good but I think the light center diff fluid didn't let me take full advantage of it. I'll be working on that soon...
Tony Phalen
RCDriver.com
CompetitionX.com
Old 12-15-2010, 11:36 AM   #1106
[/URL][/B] for more pics!
NICE shot! Another podium finish for Team Nitronic.
So.... who's thinking a GT8 3hr team enduro might be a very cool thing?
The Team based 1/10th class Enduro Charlie ran in 2010 was an absolute blast with battery and driver changes every 20 minutes.
Hopefully we'll see one in 2011........
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 12-15-2010, 11:50 AM   #1107
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
Oh hell yeah I am in. 6s with 1400kv can go 20 min easy.
snrscion is offline   Reply With Quote
Old 12-15-2010, 01:18 PM   #1108
FangsCPO's Avatar
Originally Posted by whipnet View Post
Finally got the BL conversion done. Now all I need is the power source. Going with Tekin, any recommendations on KV rating? 4 vs 5 vs 6 cell? What's a sweet spot?
Thanks much!
Very nice!!! Reminds me of mine when I first converted her over to electric.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 12-15-2010, 08:52 PM   #1109
bubuz28's Avatar
Trader Rating: 18 (100%+)
What's up guys. You have been holding out on me. I didn't even know that this thread existed. Anyways, I finally got to see the picture of me with my Third Place Trophy. I know. Why celebrate third place. Did you guys not notice who finished ahead of me. Not too shaby. Anyways, great race and did you guys check out the lap times. Nice.
www.TeamNitronic.com STEVE D
OC Circuit. You name it, they race it.
XRay T3, Mugen MTX4R
Ebay User Name BUBUZGT
bubuz28 is offline   Reply With Quote
Old 12-28-2010, 08:10 PM   #1110
whipnet's Avatar
Finally got the build/conversion done on the DM-1.
I'll have more pics and video posted soon.
Here's the build:
OFNA DM-1 Conversion Build <--
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
