Old 10-18-2010, 04:03 PM   #676
How are you all keeping your wheel nuts tight?
These 17mm nuts seem to want to come loose all the time even if you torque the crap out of them.
BTW, I discovered the Ofna nuts use a different thread pitch (1.3) compared to the Kyosho & XTM nuts (1.0).
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 10-18-2010, 04:04 PM   #677
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
We order it straight from PMT in Italy through Picco.
snrscion is offline   Reply With Quote
Old 10-18-2010, 04:05 PM   #678
Registered User
snrscion's Avatar
Ofna has these serrated 17mm nuts it will not come off.
http://www.ofna.com/images/parts-images/10000/10994.jpg
Old 10-18-2010, 04:06 PM   #679
FangsCPO's Avatar
I use loctite and have yet to loose a wheel. Now watch, I've gone and jinxed myself for saying that.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 10-18-2010, 04:08 PM   #680
FangsCPO's Avatar
Wow!! I never noticed that. I guess I should be paying better attention to what I'm doing. I'm guessing these are stock that come with the DM-1 Spec and GTP2e??
TLR Team Driver
Old 10-18-2010, 04:08 PM   #681
We have serrated one available. Part# 10994
D Starks is offline   Reply With Quote
Old 10-18-2010, 04:09 PM   #682
Originally Posted by FangsCPO View Post
I see you have the DM-1 with the Tekin RX8 System...I think?? Are you using two speed or or a center diff? What gearing? ....and what diff wt lube are you using?
I was starting out with a spool in the center and I'm going to switch to a diff, no 2-spd nonsense.
It was suggested to me to run ~100-120K weight in the center diff.
I'm still working on gearing, but something in the order of 46/15 should be close.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 10-18-2010, 04:11 PM   #683
Sweet! Thanks.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 10-18-2010, 04:14 PM   #684
FangsCPO's Avatar
I've got my center diff with 120k wt and I'm geared at 48/16. I agree with that 2-spd being a pain. What shock oil are you running? I've got it at stock. I believe 80wt.F&R but I did put the white springs on the front (medium). A little better than when I had the red (soft) up front. Then again, I'm just experimenting. Trial and error.
TLR Team Driver
Old 10-18-2010, 04:25 PM   #685
My suspension is all stock at the moment. I have not had enough time to actually race this car to find out what I want to change on the suspension.
Yesterday was the first time it saw a full day of racing.
I'm planning on going to upright mounted shocks in the front, then I will mess with oils, springs, etc.
SNR is the guy to talk to about suspension on these cars.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 10-18-2010, 04:52 PM   #686
That would be great to maybe put together a group buy for the PMT tires (unmounted). Any ideas?
TYLORD is offline   Reply With Quote
Old 10-18-2010, 05:00 PM   #687
Sounds like a great idea. How about it Steve?
williamw is offline   Reply With Quote
Old 10-18-2010, 05:02 PM   #688
Raman's Avatar
Trader Rating: 49 (100%+)
I'm in!
Although I did email them a while ago, telling them that we collectively find the rims f'ugly..
I'm sure they will respond with a "vaffanculo"
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 10-18-2010, 05:05 PM   #689
Raman's Avatar
Im actually curious to try out their 1/10
Scale touring rubber (threaded and slicks)
Old 10-18-2010, 08:39 PM   #690
Yeah, I noticed that when I picked up some extra wheel nuts and they didn't work. Was going to toss some RC8 hubs on it, but the drive pins on the RC8 are bigger than the ones on the Ofna. I'd like to make everything the same wheel nut. The stock DM1 nuts aren't serrated.
So the ofna uses 2.5x17 mm drive pins vs the 3x17mm that losi and AE use.
Oh, hey whose A/B/C/D aluminum plates should we get for the DM-1. Want to be prepared for if I smack the light post.
markw is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
