Old 10-18-2010, 09:53 AM   #661
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
I've ran them both, I personally don't like the mechanical brakes.
snrscion is offline   Reply With Quote
Old 10-18-2010, 10:52 AM   #662
Originally Posted by FangsCPO View Post
So in your opinioin you'd choose electric braking/motor over mechanical brakes? Is it because of the drag brake feature you get with electric braking/motor?
For me the benefits of electric braking are;
1. Way simpler
2. Much stronger braking
3. No fade problems
Now you are aware that the mechanical brakes do reduce your motor temps?
Yes, I'm aware of that, but it does not seem to be much of an issue. It's really the same as running electric braking on 1/10 scale cars, just scaled up. Nobody runs mechanical brakes on 1/10 scale electric cars.
Maybe others will have different opinions but I really can't see any reason to mess with mechanical brakes on these cars. The motors are capable of equal braking torque as driving torque.
Just think of them as big 1/10 electric cars.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 10-18-2010, 11:05 AM   #663
Raman's Avatar
Trader Rating: 54 (100%+)
1. Way simpler
3. No fade problems
+1!
If these motors have enough power to launch these 8 pound cars from a standing start, then they have plenty of power to slow them down and stop them. If the motor fries as a result of electric braking then the manufacturers need to improve the motors.
Personally I think the voltage you run has more effect on motor temps. I ran 5S and my motor did not even get over 100 degrees... and believe me I was using the brake a lot since I'm the newbie racer.
Raman is offline   Reply With Quote
Old 10-18-2010, 11:05 AM   #664
Registered User
snrscion's Avatar
Old 10-18-2010, 11:15 AM   #665
FangsCPO's Avatar
1. Way simpler
3. No fade problems
I agree with your three reasons but I was swayed to mechanical brakes previously and they seem to do pretty well.
I see you have the DM-1 with the Tekin RX8 System...I think?? Are you using two speed or or a center diff? What gearing? ....and what diff wt lube are you using? Sorry to ask so many questions. I'm still in the trial an error phase but I gotta say, this beast is fast and when you get a few more together it's crazy.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 10-18-2010, 11:47 AM   #666
Raman's Avatar
Fangs, I almost went the same direction as you did, even was going to run two speed to put less stress on the motor.
Then it dawned on me that if I have to go these two routes then these motors are not yet designed for such a purpose.
Well in fact they are and they do a fine job of handling it all.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 10-18-2010, 01:18 PM   #667
FangsCPO's Avatar
I'm going to start playing with the motor brakes again and see how it goes but I'm not too keen on the two speed. I had a two speed on something else many years ago and it drove me crazy. Too much hassle. How much drag brake are you using if any? What's your gearing?
TLR Team Driver
Old 10-18-2010, 01:51 PM   #668
Raman's Avatar
Quote: Originally Posted by Raman Fangs, I almost went the same direction as you did, even was going to run two speed to put less stress on the motor. Then it dawned on me that if I have to go these two routes then these motors are not yet designed for such a purpose. Well in fact they are and they do a fine job of handling it all. I'm going to start playing with the motor brakes again and see how it goes but I'm not too keen on the two speed. I had a two speed on something else many years ago and it drove me crazy. Too much hassle. How much drag brake are you using if any? What's your gearing? __________________ Slash 4X4 PE - MMPro, TeknoRC M6 Drive shafts E-Revo Brushless Edition - Mamba Power Baby!! Losi 8ight-E Buggy TC-4 - Tekin RS Pro w/ Tekin Redline 17.5 OFNA DM-1 Spec Tekno BL Conversion - Tekin RX8 System
My gearing is based on a 1700 kv motor and 5s LiPo, so not sure if it will help you. Spur 44T and 18T pinion.
Drag brake I'll have to check with computer.. I pretty sure it's set to minimum. Current limit is way up though, close to 70% .. then again motor is a 1700 kv.
Old 10-18-2010, 02:00 PM   #669
Registered User
snrscion's Avatar
I run zero drag brake and set my epa on my radio to 65% brake. No need for so much brake, these BL motor stop the car on a dime. I run MMM with 2650 and 4s.
Old 10-18-2010, 03:26 PM   #670
Raman's Avatar
Since our favourite tyre for this class seems to be the PMT Rally 06, how about we start a petition for a new rim style :-)
ps I'm fluent in Italian.. so I can really get the point across!
Old 10-18-2010, 03:30 PM   #671
Registered User
snrscion's Avatar
Raman you saw my rims right? I got the unmounted tires and mounted on OFNA rims or I have a vinyl cutter I made some sticker of simulated rims to go over the dish rims.
Old 10-18-2010, 03:42 PM   #672
Raman's Avatar
Where did you get them unmounted?
They fit standard rims? I thought the were slightly smaller in diameter.
Old 10-18-2010, 03:49 PM   #673
FangsCPO's Avatar
Who carries these PMT Rally 06 tires???...premounted would be even better.
TLR Team Driver
Old 10-18-2010, 03:51 PM   #674
Registered User
snrscion's Avatar
fgsupply.com they are in LA ask for Angel tell him you run with SNR.
Old 10-18-2010, 04:01 PM   #675
Raman's Avatar
its the one place I can actually walk to from where I live LOL. So they ordered you the tyres un mounted?
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
