Old 09-21-2010, 11:03 AM   #526
Originally Posted by Raman View Post
By the way, were you using a steel pinion gear or aluminium?
I myself have steel gears right now.. will see how long it will last..
Its probably best to use an aluminium with the Kyosho plastic gear.. although I don't know of anyone that makes a mod 1 aluminium gear!
Hardened steel pinnions are the way to go (I like Novak). I don't think anyone is making aluminum pinnions from good material and hard anodyzed.
williamw is offline   Reply With Quote
Old 09-21-2010, 01:36 PM   #527
Raman's Avatar
Trader Rating: 56 (100%+)
Originally Posted by williamw
Quote: Originally Posted by Raman By the way, were you using a steel pinion gear or aluminium? I myself have steel gears right now.. will see how long it will last.. Its probably best to use an aluminium with the Kyosho plastic gear.. although I don't know of anyone that makes a mod 1 aluminium gear! Hardened steel pinnions are the way to go (I like Novak). I don't think anyone is making aluminum pinnions from good material and hard anodyzed.
In general I agree, but not with the Kyosho plastic gear. It's not made out of the same plastic material as the evolva spurs.
Anyhow I'll test my car to see how long it will last
Raman is offline   Reply With Quote
Old 09-21-2010, 05:36 PM   #528
I use steel with the Kyosho plastic spurs, there is no problem. Plastic spur gears are very sensistive to the gear mesh, it needs to be set correctly.
Old 09-22-2010, 05:05 PM   #529
Raman's Avatar
Quote: Originally Posted by Raman In general I agree, but not with the Kyosho plastic gear. It's not made out of the same plastic material as the evolva spurs. Anyhow I'll test my car to see how long it will last I use steel with the Kyosho plastic spurs, there is no problem. Plastic spur gears are very sensistive to the gear mesh, it needs to be set correctly.
How close is your mesh? I leave close to no play, this way allow the gears to set in after a couple of runs
Old 09-23-2010, 07:57 AM   #530
*BBB*'s Avatar
Do you guys know if the 40t steel ofna one will work?? How about a mod1 5mm 26t pinion? anybody know where i can find?
WORK HARD PLAY A LOT HARDER!
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 09-23-2010, 10:49 AM   #531
Raman's Avatar
Here is the 26T
http://www.amainhobbies.com/product_...inion-Gear-26T
They also sell the Ofna 40T
Old 09-23-2010, 11:41 AM   #532
*BBB*'s Avatar
Can anyone verify if the 40t ofna spur will fit our diff on the gt2?
Old 09-23-2010, 01:05 PM   #533
Raman's Avatar
Can't verify, but last time I had an ofna ring gear in my possession the holes lined up with the kyosho diff casing. I think one of us will have to bite the bullet and buy it lol
Old 09-24-2010, 09:28 AM   #534
-R2-'s Avatar
SOAR SEIKI 998,Truggy, Buggy and Electric
Flashpoint Fuel/Savox/
-R2- PAINTS/PRO-LINE RACING/AIRTRONICS
-R2- is offline   Reply With Quote
Old 09-24-2010, 09:32 AM   #535
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
http://www.youtube.com/watch?v=gKsQdcLAdDw
snrscion is offline   Reply With Quote
Old 09-24-2010, 09:39 AM   #536
-R2-'s Avatar
Ultra GTP2e Video
Old 09-24-2010, 10:43 AM   #537
clayrace24's Avatar
Trader Rating: 42 (100%+)
Which center diff is the best to use with the DM-1/Teckno conversion if you are switching out the 2 speed? Model or part number(s) would be appreciated.
Here are some pics of my projects.
Clay
Kyosho GT-E
DM-1 Teckno
GT8 Class--buggy-based on road electric!-img_1416.jpg   GT8 Class--buggy-based on road electric!-img_1932.jpg   GT8 Class--buggy-based on road electric!-img_1933.jpg   GT8 Class--buggy-based on road electric!-img_1936.jpg   GT8 Class--buggy-based on road electric!-img_1935.jpg
clayrace24 is offline   Reply With Quote
Old 09-24-2010, 10:48 AM   #538
clayrace24's Avatar
Here's the DM-1 - a long way to go! The other pic is pre conversion.
Clay
GT8 Class--buggy-based on road electric!-img_1938.jpg   GT8 Class--buggy-based on road electric!-img_3508.jpg
Old 09-24-2010, 01:07 PM   #539
Clay
Kyosho GT-E
DM-1 Teckno
Jammin X2 Pro diff. is what they are using here. I've got that one and I've got an RC8 center diff. I'm waiting for this to arrive and will be playing with it this weekend. The Jammin diff fits for sure.
markw is offline   Reply With Quote
Old 09-26-2010, 04:11 AM   #540
SuperEk4's Avatar
Trader Rating: 32 (100%+)
just fixed up my GTx1 jammin, i had 5,20,3 in my diff. hard springs all around with sponge tires.
problem is it skid at the rear when throttle out of corner or brake hard.
could be the brandless tires or road(just a regular car park)
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
