Old 09-04-2010, 07:35 AM   #391
Foxxrocket's Avatar
Originally Posted by SuperEk4 View Post
U never change the rear shocks n shock tower?
Kyosho has set the car up for on road, right out of the box. Why change something that works just fine the way it is? The only thing I would change would be to lay the front shocks down one hole.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 09-04-2010, 07:36 AM   #392
R-E-A-P-E-R-'s Avatar
I wish you guys would post more pictures of your cars in this tread.
Serious About Racing........
R-E-A-P-E-R- is offline   Reply With Quote
Old 09-04-2010, 09:29 AM   #393
*BBB*'s Avatar
MikaR-How do you determine the FDR and what is optimal for this car? Have you found that getting too far away from this you loose handling? And where do you find the 40 spur?!?
Foxx- on the stock steering rod is there anything else? haha but i havent had any problems with em yet and ive taken some hellacious tumbles! Also do you run yours with the shockss in one hole? How differently does it handle?
reaper- check a few post back for the link and wheres your ride?
WORK HARD PLAY A LOT HARDER!
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 09-04-2010, 10:54 AM   #394
Registered User
snrscion's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to snrscion Send a message via Yahoo to snrscion
This is my Ofna Ultra GTP2e
snrscion is offline   Reply With Quote
Old 09-04-2010, 01:13 PM   #395
Raman's Avatar
Trader Rating: 56 (100%+)
Originally Posted by MikaR
Quote: Originally Posted by *BBB* what motor are you running? I only know about the Mamba Monster 2200 and 2650.. With the 2650 i was running 20/46, now im going to try the 2200 gear for the same top speed at 24/46 and see if there is any difference! Orion "8" 2050kv Thanks Raman for the link. I will try single speed, but with the tranny I'm pretty close FDR tranny 5.12 FDR diff 4.79 (24/46) Using the tranny with 22T would be roughly the same. Anyone thought using the 40T spur ? I think Hobao has them. When going to higher gearing like the 26/46 is there a threat the motor to overheat and loose power (and eventually break?) I'm having low temps with a tranny. __________________ Nitro: RRR evo 2 RB V12 Rody / Orion CRF12, Spada 09 O.S. FS26SC, Inferno GT Novarossi S21P3 / Orion CRF21, Brushless: Inferno VE, Ultima SC10 Orion 17T, TF-5 Orion prostock 13.5T sensored Last edited by MikaR; Yesterday at 11:24 PM.
Gearing, voltage, motor kv / amp draw are a balancing act. In order to keep temps down, you need to make adjustments. So if you go up in gearing, then you need to either go down in kv or gearing. If you keep all three high, lifespan of your motor or battery will diminish.
Raman is offline   Reply With Quote
Old 09-04-2010, 11:30 PM   #396
SuperEk4's Avatar
Trader Rating: 32 (100%+)
this is mine, have not setup yet, waiting for tires & shell
jammin x1 cr
hobbywing xerun 150amp
xerun 4168(2250kv)
spur 48
pinion 15
how u guys set the suspension lower by the ride height or droop?
my 1/8 off road is set up by shock collar, is it the same?
GT8 Class--buggy-based on road electric!-my-gt.jpg   GT8 Class--buggy-based on road electric!-my-gt2.jpg   GT8 Class--buggy-based on road electric!-my-gt3.jpg
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 09-04-2010, 11:40 PM   #397
MikaR's Avatar
I used this to calculate FDR, I think the internal gear ratio is 2.5
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
About optimal, can't say - I don't think there is one
I found a 40 spur from A-main some time ago (by Hobao/OFNA) but can't find it anymore. It could fit Inferno.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 09-05-2010, 04:58 AM   #398
Foxxrocket's Avatar
First, you're using longer shocks, made for off-road. So, setting ride height might be a problem. Like I said before, shorter shocks are better for onroad. And that is why you're not able to set the ride height any lower. Droop only controls suspension up travle, not ride height. Setting the shock collars with pre-load will set the car's ride height.
Old 09-05-2010, 05:34 AM   #399
can anyone point me in the direction of a site with a selection of GT class bodies and possibly a rally body which will fit a 1/8th off road buggy?
I am running a Losi Eight with the brushless castle conversion kit and just wanna have some fun bashing. the castle converson allows me to use dual lipo's in series , but the stock buggy body sits really high, so i wanna find something that will cover the wheels and look cool at the same time.
AKSHUN is offline   Reply With Quote
Old 09-05-2010, 06:18 AM   #400
Vision's Avatar
Trader Rating: 38 (98%+)
Im using the Inferno VE mount.. Where did you get the 26t pinion?? And how are you keeping the ipanemas on the rim with the 6s? I could never manage to do that lol.. And yea with the gt2s diff gearing on 6s would ANNIHILATE the Vorza with same gearing.
Current record in our little group is 91mph!!
Oh ok nice. What are you using for the battery tray ?. Which center diff are you using. Bases on the 26/46 combo the gt2 will be geared for over 120mph!. Do you think the 30t pinion would fit on the ve mount ?. For the tires I lay into the throttle gently lol.
6iX, GTP2e, XO-1, DM1-E, ST-R/MP777 GT2 Hybrid, GT2-VE, GT2-E Circuit, Hybrid Vorza, Rampage XB-E, Slash Platinum, tc5R
Vision is offline   Reply With Quote
Old 09-05-2010, 06:38 AM   #401
SuperEk4's Avatar
No wonder my car is still so high, my shocks collar is already at max.
The front shocks are the ones most guys use right for all the shocks right? Is it the same as DM-1 shocks?
Does a graphite chassis make a diff?
Old 09-05-2010, 06:35 PM   #402
Raman's Avatar
This one:
http://www.amainhobbies.com/product_...-Spur-Gear-40t
Old 09-05-2010, 11:25 PM   #403
*BBB*'s Avatar
Originally Posted by Raman View Post
Are you SURE this will fit our center diff and mesh with the mod1 5mm?
Old 09-05-2010, 11:28 PM   #404
*BBB*'s Avatar
Can someone tell me how to multi quote in one response?
Its geared at 25/48 now.. But on the 30t pinion.. idk? Its hard to say.. with the 25/48 i dont think i could get much more than a 26 on there.. But if i put that 40 on that raman found im sure id have more room! VE battery tray
Old 09-05-2010, 11:50 PM   #405
Raman's Avatar
I don't know. That's the $30 question LOL. Good thing about Amainhobbies is that they will take returns for store credit so long as its not used.
It is a mod 1 that I am sure of. Question is if the holes line up. My experience is that Kyosho, Mugen, Ofna diff casings are very close in size... with Kyosho MP9 being the exception
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
