Old 09-03-2010, 03:51 PM   #376
Raman's Avatar
Trader Rating: 49 (100%+)
Originally Posted by *BBB* View Post
With these motors producing SOO much torque i am geared for top end and cannot imagine it taking off any faster!
We run a 4,5, then 6s race on out track.. I havent noticed much difference with the different c ratings, when i first got in to it i bought 40c batts at a much higher price than the 25c i have and i really dont see much difference
+1 BBB
I ran Nitro GT for 3 years and recently switched to Gte
I'm running a Tekin 1700 KV 5 Cell and I have set punch control up to 50 to avoid wheel spin. Im running LiFe batts which are lower voltage than 5 cell LiPos.. nonetheless the car runs strong.
Gearing I am running stock centre diff 48T with 20T pinion. Im going to pick up a 24T and 26T pinion soon. I will most likely turn the punch control down to 20s..
I myself don't see a need for 2 speed on these cars.
Raman is offline   Reply With Quote
Old 09-03-2010, 04:17 PM   #377
*BBB*'s Avatar
Originally Posted by Vision View Post
*BBB*, which motor mount are you using ?. Do you think the gt2e can be as reliable as the vorza ?. I have 26/44 in the vorza and on 6s and ipanema's it rips, so I can just imagine the gt2e being as fast if not faster!.
Im using the Inferno VE mount.. Where did you get the 26t pinion?? And how are you keeping the ipanemas on the rim with the 6s? I could never manage to do that lol.. And yea with the gt2s diff gearing on 6s would ANNIHILATE the Vorza with same gearing.
Current record in our little group is 91mph!!
WORK HARD PLAY A LOT HARDER!
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 09-03-2010, 04:34 PM   #378
Raman's Avatar
Quote: Originally Posted by Vision *BBB*, which motor mount are you using ?. Do you think the gt2e can be as reliable as the vorza ?. I have 26/44 in the vorza and on 6s and ipanema's it rips, so I can just imagine the gt2e being as fast if not faster!. Im using the Inferno VE mount.. Where did you get the 26t pinion?? And how are you keeping the ipanemas on the rim with the 6s? I could never manage to do that lol.. And yea with the gt2s diff gearing on 6s would ANNIHILATE the Vorza with same gearing. Current record in our little group is 91mph!! __________________ WORK HARD PLAY HARD! Inferno VE w/ MM2200 VORZA Inferno GT2e w/ MM2650 TC3 .18tz
You can use this pinion
http://www.amainhobbies.com/product_...inion-Gear-26T
Old 09-03-2010, 04:35 PM   #379
Raman's Avatar
Does anyone know of a pinion higher than 26t that is a mod 1 pitch?
Old 09-03-2010, 06:50 PM   #380
Callahan_88's Avatar
I just orded an HOBBYWING 2000KV Brushless Motor for 1/8 RC Car!
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
and now im looking for an good ESC!
Any good ideas?
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 09-03-2010, 07:14 PM   #381
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Any good ideas?
It's a good motor, get the xerun 150amp esc. It's good n cheap
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 09-03-2010, 10:00 PM   #382
Vision's Avatar
Trader Rating: 38 (98%+)
Oh nice, I didn't know that mount would fit. Is it a direct fit ?.
What are you using for the battery tray ?. Wonder if I can use the vorza battery holder. I usually lay into the throttle slowly lol.
Do you have pics of your setup ?
6iX, GTP2e, XO-1, DM1-E, ST-R/MP777 GT2 Hybrid, GT2-VE, GT2-E Circuit, Hybrid Vorza, Rampage XB-E, Slash Platinum, tc5R
Vision is offline   Reply With Quote
Old 09-03-2010, 10:01 PM   #383
Vision's Avatar
Raman I plan to eventually run 30/44 gearing in my vorza. The 30 you can get here - https://sdp-si.com/eStore/
Old 09-03-2010, 11:07 PM   #384
MikaR's Avatar
what motor are you running? I only know about the Mamba Monster 2200 and 2650.. With the 2650 i was running 20/46, now im going to try the 2200 gear for the same top speed at 24/46 and see if there is any difference!
Orion "8" 2050kv
Thanks Raman for the link.
I will try single speed, but with the tranny I'm pretty close
FDR tranny 5.12
FDR diff 4.79 (24/46)
Using the tranny with 22T would be roughly the same.
Anyone thought using the 40T spur ? I think Hobao has them.
When going to higher gearing like the 26/46 is there a threat the motor to overheat and loose power (and eventually break?) I'm having low temps with a tranny.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 09-03-2010, 11:34 PM   #385
*BBB*'s Avatar
Who is Hobao? Ive never seen a spur that would fit our car that small!! But yea as you gear for more tope end the temperature threat goes up! I try to shut mine down around 190..
And yea man im trying to upload my dang pics of my setup but my computers acting weird.. im goin to try another route right now
Old 09-03-2010, 11:40 PM   #386
*BBB*'s Avatar
Yea its a direct fit.. i would think the battery tray would work..
Do those guys in your link make the 30t pinion? That would be awesome!!
Also Vision how did you like that wide stance with the extended arms you had? Stability wise
Old 09-04-2010, 12:14 AM   #387
*BBB*'s Avatar
Badabing! Pics are here-
http://www.flickr.com/photos/5359323...137704/detail/
Let me know what you guys think
Old 09-04-2010, 02:16 AM   #388
MikaR's Avatar
Very cool! Body looks great, too!!
(Hobao=OFNA)
Old 09-04-2010, 02:29 AM   #389
Foxxrocket's Avatar
I see you're used the original steering rod in your car. I did the exact same thing. The kit only came with one tie rod and nothing else. Lame!
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 09-04-2010, 02:50 AM   #390
SuperEk4's Avatar
U never change the rear shocks n shock tower?
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
