Old 05-18-2015, 11:01 AM   #3391
mkiiina's Avatar
Trader Rating: 69 (100%+)
I had the throttle turned down via the end points on my radio and actually added -20% to my throttle expo to further soften it. I'll need to check my settings as its been a while since I initially put it together. Timing should be turned down all the way.
Additionally, was looking at 2 items for tuning. A full set of sway bars (could use a slightly firmer one in the front and rear) and some 12* spindles and casters. Thoughts?
mkiiina is offline   Reply With Quote
Old 05-18-2015, 12:16 PM   #3392
[QUOTE=Stealth_RT;14014076]This dual fan/heatsink works great: http://www.yeahracing.com/catalog/ya...er-p-3052.html
I was also running a second fan on top of the RX8 to push more air than the stock fan alone.
Don't be afraid to turn the current limiting in the RX8 WAY down. I was running it at 25 and could still light up the tires. Try 15-20.[/QUOT
Come to think of it, I never changed the CL in my ESC (RX8 Gen2) when I took it out of my SCT410 truck, but in the truck the CL was set at 25. My timing is at ~40 degrees but my motor is the 2050KV not the 2650. PS No motor fan and so far the motor hasn't gotten hot enough yet to need the IR temp gun at the end of an 8 minute race. The Nitro and 2650 motor guys do beat me down the straight but after the first set of turns I'm usually far enough ahead to negate that advantage because my car is so much easier to not over drive the corners without all that extra power.
John Wallace2 is offline   Reply With Quote
Old 05-20-2015, 08:44 AM   #3393
Trader Rating: 37 (100%+)
Originally Posted by John Wallace2 View Post
I have an OFNA Hyper GT on road 1/8 scale car an.nd need some stiffer springs. Since this car has 1/8 scale off road sized shocks (but shorter) I though some one might have a suggestion as to where to get some springs stiff enough for on road (GT8) racing. that would fit those shocks Mugen and Serpent apparenetly use smaller diameter shocks than what is on the Hyper GT.
Maybe GS Racing springs will work?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-20-2015, 09:12 AM   #3394
Donn's Avatar
Here is a link for what I have done to convert a RC8.2e to a GT8!
http://www.rcten.com/threads/rc8-2e-...8-2e-gt8.5972/
Donn is offline   Reply With Quote
Old 05-28-2015, 02:06 PM   #3395
mkiiina's Avatar
Anyone convert an SCTE to GT8? Since the SCTE 1.0 and rally are basically the same I'm going to snag the front bumper and see what can be done and the body mounts should be simple. Thinking 3s/3500kv would be pretty good and a bit lighter than my 8ight-GT8.
Old 05-30-2015, 01:38 PM   #3396
Suspended
you guyz need to wake up...whats up with this crap from ofna?
kongluc is offline   Reply With Quote
Old 05-31-2015, 10:48 AM   #3397
Suspended
they discontinued there onroad line up...just go to towerhobbies and search ofna...
Old 06-10-2015, 12:37 AM   #3398
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Has anyone converted the Xray XB8E or the SWORKZ S350 BE1 to GT spec? If so, can they supply some details please
|--|Hot Bodies Pro 5|-●-|The "F109X"|--|Xray X12 2015|--|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 06-10-2015, 06:19 PM   #3399
Suspended
What bodies are you guys running now...is deltaplastik the only company with 325/310 bodies...is there a body that comes with 310 in the front..as well as in the reae?
Old 06-11-2015, 10:50 AM   #3400
Suspended
would try reading the whole thread thats a lot of reading...i did read the gt8 lite thread..bur no one there has the setup..they run the pf8 bodies...and older kyosho bodies...and i double checked myself about there specs and their bodies are 360mm by 310...not 325mm by 310
Old 06-11-2015, 10:57 AM   #3401
mkiiina's Avatar
I'm getting ready to help a buddy swap his Xray into a GT8. I've heard the losi l8ight rear mount bolts up with little work. Bumper is going to be another issue. Wonder if we could talk t-bone racing into making some "universal" front bumpers (ie no holes and flat).
Old 06-16-2015, 04:24 PM   #3402
J-milz's Avatar
Trader Rating: 38 (100%+)
The serpent cobra GT front bumper mounts up to the Xray xb9 with little to no mods. The bottom chassis holes are slightly off but can be easily manipulated to fit. The upper mounts fit well too. Just grab a heat gun and mount up to the shock towers. It will bend slightly and fit eventually fit perfectly.
Anybody ever use a hobbywing SCT pro esc on their GT8? Just looking for an alternative to the Tekin rx8.
💫XRAY addict💫 sponsored by the secret stash.....tee-hee-hee.
J-milz is offline   Reply With Quote
Old 06-17-2015, 08:45 AM   #3403
Originally Posted by J-milz View Post
The serpent cobra GT mounts up to the Xray xb9 with little to no mods. The bottom chassis holes are slightly off but can be easily manipulated to fit. The upper mounts fit well too. Just grab a heat gun and mount up to the shock towers. It will bend slightly and fit eventually fit perfectly.
I'm using the SCT Pro in my offroad escale, but I'm not sure if it would handle the demands of GT8 onroad. I would go for the HW 150A 1/8th scale ESC instead. Although it is real nice to be able to turn the CL on the Tekin way down to control wheelspin, not sure if the HW punch control settings will do enough or not.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 06-24-2015, 07:05 AM   #3404
J-milz's Avatar
Thanks I just went with s Gen 2 RX8. It works fine.
Old 07-14-2015, 01:30 PM   #3405
Suspended
And me trying to give these guys a headz up was wrong?
Is that what you all are trying to tell me?
Mean mode domain range
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
