Old 08-28-2010, 02:32 PM   #316
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Wow thx for the detail explanation n pics. So these 2 types of chassis can race together? Or separate class?
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 08-28-2010, 03:09 PM   #317
Callahan_88's Avatar
Same class of course!
Okhobby.hk have an really cheap BL combo for 108 us$ 2050kv!
Go big or go home! :)
Callahan_88 is offline   Reply With Quote
Old 08-28-2010, 04:57 PM   #318
SuperEk4's Avatar
Btw is 2 speed a need or 1 speed is good enough?
Old 08-28-2010, 06:31 PM   #319
Foxxrocket's Avatar
I remember someone saying that 2 speed works best on long high speed tracks, and a single speed works best on shorter, more technical tracks.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 08-28-2010, 07:41 PM   #320
SuperEk4's Avatar
Thx man! Btw what's the recommended diff oil for GT buggy convert, shock oil n spring type?
Sorry for so many questions.
Old 08-29-2010, 06:27 AM   #321
Missle's Avatar
I've got a kyosho IGT2 vette that I finally got fed up with the nitro system so I made my own conversion kit. The motor was a 1700kv (don't remember the name but "max" voltage was 3S) of which I had a 28T pinion. I decided to use only the 2nd gear (43T with the clutch shoes locked out) so the drive ratio was 1.54 (43/28). For bats, was using 2 packs in parrallel of 4S 3700mah that are mounted on custom made CF plates on both sides of the frame. For the ESC, was using an old 100A airplane ESC with fan mounted on it. This was basically a quick solution to see if I'd like the electric race car so please don't think I'm absolutely insane with the parts selection above
As to how she drove, well I absolutely LOVED the way she drove on the track (a local race track here in Fairfeild OH). She was definately faster and more fun than she'd been with both the stock .28 and a .21 motor. The problem came when I was trying to see the mah draw of a 15 min race. Around the 12 minute mark, the motor demagged (yes I knew this would eventually happen as the motor was only rated for 3S and I was running 4S).
So now I'm gonna order the proper electronics. I'm liking the 1/8 Mamba Max V3, Neu 1518 1Y 1800kv motor, 4S2P 7400mah bats, and a 30T metal pinion and the 43T 2nd gear.
Using one of the online calculators, this predicts ~ 68mph so not quite the top end I want. So now I'm thinking maybe I should go with 5S and a 28T spur gear which calculates to 79mph.
Anyone using this motor yet?
Missle is offline   Reply With Quote
Old 08-29-2010, 06:48 AM   #322
SuperEk4's Avatar
Wow! What diff oil are you running?
Old 08-29-2010, 07:33 AM   #323
Missle's Avatar
I believe I've got 100k in both front and rear. I'm gonna change the rear to a lighter oil (prob around 30k) but haven't done it yet until I get the power system where I want it.
As for brakes, I opted not to use motor brake so as to reduce motor load (heat) as much as possible. Ive got a custom front/rear disk brakes that can be independently adjusted when needed.
Old 08-29-2010, 04:31 PM   #324
Raman's Avatar
Trader Rating: 54 (100%+)
With a 1700 KV motor, you should be running 5S. See the following chart by Tekno RC
http://www.impaktrc.com/product_info...oducts_id=3076
I myself am running 5S with 1700 KV tekin. Where did you get your metal pinions 28T to 30T.. are they mod 1 pitch?
Raman is offline   Reply With Quote
Old 08-29-2010, 04:43 PM   #325
*BBB*'s Avatar
I am running the MM2650 on 4 and 5s.. 22/46 center diff ratio.. On the 5s im maxing out on the straight around 55-60 mph and have no problem with acceleration.. So to answer an earlier question i dont see an advantage to the 2-speed but i am up to suggestions bc ive got a blackhawk one laying right here that needs some use!
WORK HARD PLAY A LOT HARDER!
[ Inferno VE MM2650 ][ Inferno GT2e MM2200 ][ XO-1 ][ Baja 5B ][ Baja 5Te ][ Jato ][ Grave Digger ][ MERV ]
*BBB* is offline   Reply With Quote
Old 08-29-2010, 04:49 PM   #326
SuperEk4's Avatar
whats your diff oil setup?
Old 08-29-2010, 04:56 PM   #327
*BBB*'s Avatar
right now 120/100/10 but i think im gna try 120/500 or solid/ 30.. have you gathered any more good info on this? or if the 2 speed is worth having?
Old 08-29-2010, 05:04 PM   #328
SuperEk4's Avatar
2 speed is a challenge as mine is a buggy convert n my track is not that big Also.
Btw what shock oil u guys use? Front n rear? 60 n 70? Or?
Old 08-29-2010, 05:08 PM   #329
*BBB*'s Avatar
Also has anyone found tires that are faster than Johns BSR 1/8 foams? They are taller in diameter than the ipanemas=+mph and with compound they hook very well..
Old 08-29-2010, 06:52 PM   #330
How is the Kyosho tire?
And the GRP?
The first step!
Out with the stinker!
Some drift touch!
And there was a hole in the body!
Hhmmm!
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
