GT8 Class--buggy-based on road electric!
#3257
I do have a couple of questions:
What size chassis is the body being designed for?
Will it come with light buckets for the front and rear end? (for adding led light kits)
What is the approximate price?
Any way to tweak the body so that it looks like a real (scale) GT racer without making an exact copy so that licensing of the body isn't an issue?
Other than that, great work! I look forward to seeing the final product all painted up and on a chassis!
#3258
I do not think so, I have not seen any with all the searching I have been doing that last few weeks.
I know there are brushless conversions for the D8, but as for GT8, you will more than likely have to mod some parts from kyosho or ofna to fit your chassis.
Download some manuals and have a look at the part listings and more importantly how the key parts go together.
If your not into doing the mods yourself, the ofna GT based models are reasonably priced and have parts support. That route may be the cheapest for you, if you are on a budget.
Hope that helps.
Hope that helps.
#3259
Wow, looks promising!
#3260
The body looks great! May I suggest a little higher wing in the back for more down force.
Steve
SNR-GRAPHITE
#3261
That looks nice , make a Lambo Aventador body ill buy 10 of them right now
#3262
GT8 Blade RX1 Style, xerun 150A + 4274 2000Kv, 6S, on board.
https://www.youtube.com/watch?v=93jhiQgVr1U
#3263
#3264
#3265
The batteries are kypom 3S - 35C - 5800mah x 2, but I think the 35C is not real because ESC cuts after 4 minutes of run time and the batteries were in 3.89v each cell...
We want to test with nanotech batteries...
#3266
#3267
http://www.gensace.com/epages/genspo...1P-HardCase-15
You might also check your connectors if they are realy in a good shape.
What was the amout of energy used / recharged with the pack you have after those 4 minutes ?
#3269
This might also be a candidate if you are loocking for a hardcase.
#3270
Temp after 4minutes: motor 50ºC, esc 45ºC. I expected 8-10 minutes with these bateries...
I think that after 3-4 minutes, in strong accelerations, the battery voltage drops below 3.2v and the ESC cuts. After 10-20 seconds the esc returning to work for a while...
