Old 08-22-2012, 07:11 AM   #3091
mosaics12's Avatar
Originally Posted by Raman View Post
I Don't think it's that great of a value.. For $580 (ceptor non licensed body) you could pick up an Ofna GTP2E plus Tekin RX8, install your own radio and servos and still have money to spare.
im just curious about this kit. im running igt2 nitro. im only looking for this kit for a reason i dont have to carry or buy 2 different parts/brand. you have a valid point too.
kyosho inferno GT2 pro.. kyosho ultima sc.. HPI savage X.. tamiya m-05 pr
mosaics12 is offline   Reply With Quote
Old 08-22-2012, 10:31 AM   #3092
Raman's Avatar
Trader Rating: 54 (100%+)
Originally Posted by grimmjow View Post
Ok, thanks for your reply.
It's obvious that the GTP2E have a more simple design and so a better durability.
The DM1 chassis plate look sooo good, but yes i really don't like this front suspension layout !
What option or spare should i take with the GTP2E ? i heard the rear pivot ball kit is a really good value !
Thanks again for your help.
As a general rule its a good idea to keep suspension arms, up rights as spares. Option: not sure, since I don't personally run the car.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 08-22-2012, 10:42 AM   #3093
Raman's Avatar
It's basically a conversion kit as a ready to run. Esc and battery tray in place of motor and gas tank. Motor mounted to centre bulk head on back side. Parts are interchangeable with your GT2 nitro.
Most popular kits ran are ofna gtp2e or Losi l8ght, because less work needs be done. We also predominantly run on the short wheel base.. Kyosho is the only one at the moment with the long wheelbase.
Old 08-22-2012, 08:03 PM   #3094
RC Passion's Avatar
GTP2E. Its more durable and easier to fine tune.. The DM1 Spec does not have droop settings.
They are actually hidden up under the bumper/body mount/ suspension pin holder piece right above the stabilizer bars!
RC Passion is offline   Reply With Quote
Old 08-22-2012, 08:53 PM   #3095
SC Shaun's Avatar
Send a message via Skype™ to SC Shaun
You guys running the Revo Shocks:
What did you guys decide to run for oil and springs? I am building a custom with standing shocks and have them laying around with a spring kit to boot. Anyone gimme some quick suggestions to start?
Standing Revo Shocks:
Springs?
Oil?
SC Shaun is offline   Reply With Quote
Old 08-22-2012, 10:49 PM   #3096
grimmjow's Avatar
Yep i also saw that in the DM-1 spec E PDF manual, so i am one more time confused about wich one i should buy ... the DM-1 Spec E with the standing shock front suspension mount or the GTP2E with the rear pivot ball and blades stabilizer bar upgrade ...
grimmjow is offline   Reply With Quote
Old 08-23-2012, 10:38 PM   #3097
CL
CL's Avatar
Trader Rating: 32 (100%+)
The DM1 have better gears, layout, and just about everything else.
Believe in yourself!
CL is offline   Reply With Quote
Old 08-24-2012, 12:33 AM   #3098
RC Passion's Avatar
Lightbulb
Dm1 Spec e FTW! It is designed for onroad racing, it has a more balanced layout (as CL says), it has lots of tuning options, the inner suspension pin holders are modular, therefore easier to perform maintenance and repairs as opposed to having the the pin holders as part of the fr/rr bulkheads. One major advantage over the gtp2e is lower cg due to the bumpers mounting flush with the chassis. Gtp2e mounts the bumper under the chassis forcing you to run a higher ride height. Good luck with your decision, but in the end, either of them will be very fun to drive!
Old 08-26-2012, 03:03 PM   #3099
rcwck's Avatar
I am almost convinced. I have 2 Ultra GTP2s(one standard wheelbase and one SNR stretched version) and a Kyosho GT2 converted. Two of these DM1s showed up at our local track and I was impressed. For some reason I thought they were the long wheel base GT2 type and they are not. I like the ball suspension fr and rr, the separate inner lower hinge pin holders, chassis/bumper config and the blade type anti- sways. So much for the buggy based roadrace cars. I think this car will be hard to beat in the right hands. It's too late in the season around here to give it a try but next season............
rcwck is offline   Reply With Quote
Old 08-29-2012, 07:04 PM   #3100
has anyone tried converting caster ex1.5r 1/8 buggy?
vintage boy is offline   Reply With Quote
Old 09-02-2012, 10:46 PM   #3101
Raman's Avatar
Not that I know off.. basically if its a buggy, it can be converted. All you need are body mounts, front bumper and an extra set of front shocks to run on the rear.
Old 09-10-2012, 12:49 AM   #3102
RC Passion's Avatar
Let's go GT8 racing! Time to bust out the GT8s for Corona, Ca hobby town USA this Sunday Sept 16th!
Btw, I'm looking for a new lid for my Dm1 Spec! Any suggestions? Pics would help a lot!
Old 09-10-2012, 06:00 PM   #3103
Waflet's Avatar
Trader Rating: 30 (100%+)
Hideeho
I'm so happy! I found a bunch of guys that race on road locally! It's VERY informal with a little bit of everything, 1/8 on road, gt8, buggies w/ street tires, & even some 1/5 scale 2wd gas cars! Now that I've found some place to play with a street car, & found I should be able to use the Losi l8ight front bumper & rear body mount, what is the best way to limit the ride height? I raised the spring perch all the way up & set the droop screws so I only had a few mm of droop. My fronts were pretty much sitting on the droop screws, but the rears were sitting on the springs, not the screws. With this kind of ride height in the rear do I need shorter shocks for the rear? Will a gt body fit over the rear shock towers?
"Just leave me alone, I know what I'm doing."-Kimi Raikkonen
Mugen MBX7R Eco/Tekin RX8g2/Savox 2274/SMC 1900kv/Aitronics mt-4/promatch
Mugen MSC7(1/10 pro4 sct)/Tekin RX8g2/Savox 2274/Tekin Pro4HD 4300kv/Airtronics mt-4/SMC
Waflet is offline   Reply With Quote
Old 09-12-2012, 01:40 PM   #3104
Raman's Avatar
Default LWB GT8
I just ordered the Audi R8 body by Kyosho for my GT8.
I've been working on changing over my TRF801 to LWB / 360 mm +.. Here is how it looks so far
Old 09-13-2012, 02:40 AM   #3105
salze145's Avatar
Hello from Barcelona,
Here is my GT8 (Rally Gamem in Europe). I'ts a Italian Crono RS03 gas chassis converted to brushless with a home-made motor mount, mamba monster ESC + 2200kv motor, turnigy 4S 5000 30C and savox 1258TG. Porsche GT body.
some pics:
regards
salze145 is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
