Old 12-20-2011, 11:16 AM   #2896
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Default OFNA Late Model Oval vs. GTP2e
Why is it preferable to use the GTP2e over a OFNA Late Model Oval for onroad?
My reasons for liking the Oval version is:
  1. Price
  2. Front and rear pillow ball suspension
  3. Lower profile rear shocks and shock tower
Is there something about the GTP2e that makes it more suitable for onroad aside from the included Protoform body?
YR4Dude is offline   Reply With Quote
Old 12-20-2011, 12:29 PM   #2897
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
  1. Price
That true you get the rear pivot ball suspension but now you have a body that can't be use.
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 12-20-2011, 12:49 PM   #2898
What motor would you guys suggest for a parking lot track with a 160 foot or less back straight?
Stregone is offline   Reply With Quote
Old 12-20-2011, 01:18 PM   #2899
RC Passion's Avatar
  1. Price
Yeah, I'd go with the late model if you're willing to buy another body. I converted my dm-1 to shorty rears and they work well and there's some weight savings!
RC Passion is offline   Reply With Quote
Old 12-20-2011, 01:48 PM   #2900
YR4Dude's Avatar
Default 4S charging
Okay, I thought I was just gonna pick up a 4s pack and throw it on my current charger for 2s batteries and thats it. Just checked the specs and it says I can only charge at 4A with a 4s pack. With a 5000mah pack that works out to about 1 hour and 15 minutes. No biggie but, how much charge do these things use in a normal 5min qualifier?
If it uses the whole 5000mah then its a pain to pump it back up in time for the next heat. If its only about 3000mah used then that's not so bad.
How do you guys manage your charging to stay in pace with the race schedule? Having more packs is nice but can get awful expensive. Are there any special chargers you guys use that get these 4s packs charged quicker?
Old 12-20-2011, 01:56 PM   #2901
You wont being using all 5000mah, that would go well below LVC.
I use a hyperion 14201 net 3 charger , and gensace 5000 4s, they can be charged 2c,the charger is onsale from $180 down to $130 at allerc.com
Joat is offline   Reply With Quote
Old 12-20-2011, 02:29 PM   #2902
YR4Dude's Avatar
Okay, I checked the spec sheet for it and it says I need a 24V input? My power supply only has 12V with a maximum of 9A, will that do?
Even if I charge at 8A which is less than 2C thats not so bad but do I need 24V?
EDIT:
Okay, I saw this and it sounds like a great deal considering its price and charge rate.
http://www.hobbypeople.net/index.php...a-output.html#
If anyone has any experience with this charger please comment.
Old 12-20-2011, 03:16 PM   #2903
Micro-E's Avatar
FWIW, my charger only charges lipo at 1C. I have a 2050KV motor in my GTP2e and use about 2600ish ma in 5min. I have two cheap 4500ma packs, charge up the night before. Use pack A for Q1, charge A for main (at the track), use B for Q2.
I run 2 classes and it does not get in my way.
- Erik
Micro-E is offline   Reply With Quote
Old 12-20-2011, 03:55 PM   #2904
YR4Dude's Avatar
Thanks. Thats exactly the information I was looking for.
Old 12-20-2011, 03:56 PM   #2905
EDIT:
Its really up to you, it should handle fine, my 1420 is 550watt 20 amps output,I bought a cheap 28v power supply, this way I can charge up to 14s,which may seem like overkill, but I can charge 2 x 7s at the sametime,but for me ,2 x 4s ,5000mah is more then enough for me to charge at 1 time.
I wanted a charger that could handle charging 2 different packs at the sametime.
Old 12-20-2011, 05:56 PM   #2906
Default My conversion nearly done ,teaser pics
My conversion is almost done, heres some tease pics of the parts I made.
Aluminum is 7075,and Titanium 6ALV4
I have a older gtp, with a 4mm cnc option chassis ,converting to BL
Sorry but this is my first attemps at using my mill , no cnc
Motor mount
Stand up servo mount
DM1 bumper adapters ,titanium
I'll let you guess what these are for
Next up carbon parts, I cut on my mill,
I went cheap and used abs sheet to make a battery tray
Old 12-21-2011, 01:45 AM   #2907
RC Passion's Avatar
Ditto!
How u been Erik?
Old 12-21-2011, 01:55 AM   #2908
RC Passion's Avatar
Go for a 2050 or 2250kv motor! Anything more you'll be plowing thru the end of the straight! I've seen some do this even in an almost 200ft straight! I wont name names.... Not a pretty site!
Old 12-21-2011, 09:43 AM   #2909
YR4Dude's Avatar
Default Charge rate
Okay so for 5min the typical mah used is about 3000mah. If I throw it on a charger that allows for a maximum of 4A with 4s packs would it be charging it at 1.3C for the 3000mah I need to put back in the pack? Or is that 4A only apply to its full capacity when at 5000mah which works out to .8C?
Old 12-21-2011, 10:35 AM   #2910
Why are you charging only at 4amp. A 5000mah pack you should be charging at 5amp.
www.snrgraphite.com
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 01:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 04:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 10:39 AM
SEO by vBSEO 3.5.0
