Old 10-28-2011, 12:30 PM   #2836
WildBillMassey's Avatar
After many months on back-order, Kyosho America finally received GT2 bodies. After filling all of our back-orders here at IGT Hobbies, we have the following left...
Corvette Clear
Corvette Completed
McLaren Clear
We also got more 350Z bodies in for GT1.
These will go unbelievably quick, so if you want one, you better get to gettin'
WWW.IGTHOBBIES.COM
Former owner of The Nitro Pit and IGT Hobbies
Now living in the Great White North.
You may think you know what you're talking about, but the only person you're fooling is yourself - Wild Bill Massey
WildBillMassey is offline   Reply With Quote
Old 10-28-2011, 10:15 PM   #2837
FangsCPO's Avatar
Originally Posted by Justpassedu View Post
Good price I just ordered the ofna porshe body from you. When are you planning on having the dm1 e in stock?
OFNA has a Porshe body?? Is it the prepainted silver one?? I'm currently running the Ferrari body and I really like it.
http://www.flickr.com/photos/fangscpo/6198828795/
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 10-28-2011, 10:21 PM   #2838
Raman's Avatar
Trader Rating: 47 (100%+)
So that's what the Ferrari body used to look like.. I forgot.. mine looks like a blob now
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 10-28-2011, 10:26 PM   #2839
FangsCPO's Avatar
LOL!!!
TLR Team Driver
Old 10-28-2011, 11:29 PM   #2840
Justpassedu's Avatar
Trader Rating: 115 (100%+)
Yes the pre painted silver ofna body , I think they are being discontinued also.
Mugen Mbx6 Eco
Justpassedu is offline   Reply With Quote
Old 10-29-2011, 11:39 AM   #2841
They are already discontinued, we have more coming in next week, and they are all painted silver. There are about 25 of these left at OFNA.
http://www.igthobbies.com/OFNA-OFN31...DY_p_1559.html
Old 11-02-2011, 10:16 AM   #2842
DM-1Spec Electric kits are on the way to us! We have 4 coming, 2 already sold this morning, so I will have 2 left from the initial shipment. Our price is $269.99 with free shipping to the States and Puerto Rico.
http://www.igthobbies.com/OFNA-OFN34...IT_p_1819.html
Old 11-02-2011, 10:31 AM   #2843
whipnet's Avatar
This would have simplified things greatly for me last year (and the savings of $$) Even still, I love my conversion and the smooth as butter feel of the clutch and 2 speed.
Great to see this product though!! Thanks Bill.
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 11-02-2011, 10:36 AM   #2844
Cool.
I bet with the addition of a 2-speed from the DM-1 Nitro (which should drop right in), and the Tekno E-Clutch, these are going to be sweet on the track.
here are links to those products as well.
http://www.igthobbies.com/TEKNO-RC-T...IT_p_1397.html
http://www.igthobbies.com/OFNA-OFN35...PE_p_1691.html
Old 11-02-2011, 10:51 AM   #2845
jrz93's Avatar
Originally Posted by WildBillMassey View Post
Cool.
Will that 2speed work in the gtp2e?
---NEMO RACING USA--BULLITT--BETA TIRES--CRITTERS HOBBYSHOP--HOBBYWING--TRINITY--TOBAMEISTER PAINT--NYRT--GMK Supply--
--Critters Raceway--Barnstormers Raceway--360v2 Raceway
jrz93 is offline   Reply With Quote
Old 11-02-2011, 10:54 AM   #2846
yes, it is actually the official upgrade for the GTP2e, we just also list it for the DM1 as a full replacement. I have more coming in on Friday if you want to order one.
Old 11-02-2011, 12:23 PM   #2847
By adding a 2-speed to a GTP-2e
You would need to add a brake system, a servo for braking, and your radio will need to have the ability to mix for braking.
Because the 2-speed free-wheels there would be no braking ability.
D Starks is offline   Reply With Quote
Old 11-02-2011, 12:37 PM   #2848
I will rephrase my answer to....
yes, it will fit*
*depending on your setup other items may be needed, each model will be different. Knowledge of 2-speeds and brush-less systems is highly recommended.
Old 11-02-2011, 12:37 PM   #2849
How does the 2 speed actually work ? , you cannot use the motor for braking with it installed ?
Mugen Mbx6 Eco
Old 11-02-2011, 01:12 PM   #2850
teknorc's Avatar
The two gears ride on a one-way bearing. When there is enough centrifugal force the 2nd gear engages (this is adjustable) and 1st gear is idling on the one-way essentially. The one-way bearing causes the drivetrain to freewheel off-power or with reverse input, so yes, you need mechanical brakes with a 2-speed.
If you run mechanical brakes, 3rd channel throttle mixing is recommended, but you can also use a Y connector in a pinch.
With a 2-speed, you don't have front/rear brake bias like you would with a center diff, but it is still recommended to use brake discs on both diff outdrives to improve braking force and minimize brake fade. A good servo is required for braking a 1/8th on-road GT car since there is so much traction available, the brakes heat up pretty quick.
Using mechanical brakes will increase weight ~4-5oz and your setup will be a little more complex, but you will increase the durability and reliability of the drivetrain and your electronics (motor/esc). It will reduce heat on the motor/esc and usually increases run time (efficiency) as a result of less heat.
Mechanical brakes aren't for everybody, but definitely worth a try if you're curious. It's really easy to set up once you have all the parts. I won't run a GT8 without them .
Tekno RC
www.teknorc.com
teknorc is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 04:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 01:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 04:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 10:39 AM
SEO by vBSEO 3.5.0
