Old 06-22-2011, 07:40 PM   #2251
Capt'N_Slow's Avatar
Looking to get some handling advice from the GT8e racers.
Usually bash at the local Lowes parking lot which gets washed down once a week so it's relatively high traction. Just for fun I went to the new local school as it has new ultra smooth blacktop layed down.
To my amazement the rear end was everywhere but planted. It felt like I was driving a drift machine.
Looking to stick the rear end a bit more expecially on corner exit. Corner entry the car pushes which is really predictable.
Using box stock springs.
sway bar front - non in rear
80wt front
50wt rear
100k wt front
locked stock spool middle
30k wt rear
Shocks layed all the way down in the rear and the front is as vertical as I can get them. Using the most outside lower hole on the arm.
Rear upper link:
Outside : Middle Upper Hole
Inside : Upper Inside Hole
Running sweep 45s tires on all four corners they get fairly hot and gummy after running for 2min so I think the tires are working well.
Rx8 1900kv 25 boost start 9k end 23k
throttle profile 3
Initial throttle 8
Current Limiter : 75
Stock Spur - 23 Pinion
Micah
Capt'N_Slow is offline   Reply With Quote
Old 06-22-2011, 08:20 PM   #2252
Suspended
Originally Posted by SNR Graphite View Post
Jammin/Nexx10
Oh snaps, then I think I won't post up my Jammin for sell then
s.l.c. is offline   Reply With Quote
Old 06-22-2011, 11:06 PM   #2253
kcunamay's Avatar
Trader Rating: 20 (100%+)
80wt front
50wt rear
100k wt front
30k wt rear
Rear upper link:
Inside : Lowest Inside Hole
Rx8 1900kv 20 boost 5.5k-22k
throttle profile 3
Initial throttle 8
Current Limiter : 80
Stock Spur - 21 Pinion.
Hi Capt'N.
You didn't mention what type of car you're running so, I will guess it's a GTP2E.
If you're just bashing, the setup isn't quite as important, as its about FUN FUN FUN.
However, to HELP plant the rear of your car, I would suggest swapping the center spool for a diff. IT HELPS TREMENDOUSLY.
Most setups I've seen start with Front Diff - 20K, Center 100k, and 10k in the rear. Purchase the center diff and TUNE IT TO YOUR LIKING FIRST.
Good luck.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 06-23-2011, 01:12 AM   #2254
clayrace24's Avatar
Trader Rating: 42 (100%+)
Default DM-1 Pro Techno 2-speed to center diff swap
I'm trying to convert my DM-1 Pro/Techno car from a 2 speed to using a center diff. I bought a Jammin center diff which is a reasonable fit in the center diff bracket, but there is some side play between the bearings and the bracket sides as the 2 speed is a little wider. The bigger issue is that the diff gear sits too close to the mechanical brake servo, maybe 1 mm of clearance if I can get the diff shimmed all the way to one side. There certainly isn't enough room to get a pinion to mesh well without hitting the servo.
The chassis has a recessed location for the diff that has cutouts too, so I really can't move the center diff by redrilling the chassis either. Has anyone else tried to do this conversion? May have to get one of those custom SNR chassis!
Clay
clayrace24 is offline   Reply With Quote
Old 06-23-2011, 09:00 AM   #2255
Mark the Hammer's Avatar
Trader Rating: 14 (100%+)
Jammin/Nexx10
I can not wait to see it done.. Is it done yet???
MUGEN RACING
M.A.D. Racing products
TC Hobby's
Mark the Hammer is offline   Reply With Quote
Old 06-23-2011, 09:01 AM   #2256
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
No not yet I will work on it this weekend. I coming for you Slash guys.
SNR Graphite is offline   Reply With Quote
Old 06-23-2011, 12:38 PM   #2257
Get it done..
MUGEN RACING
TC Hobby's
Old 06-23-2011, 12:42 PM   #2258
FangsCPO's Avatar
This is going to be fun!!! I should be getting my conversion kit today or tomorrow. It will great to see a bunch of these at the next HT Corona Race. Let's definitely get a group photo of all the rigs.
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 06-23-2011, 11:31 PM   #2259
clayrace24's Avatar
Why not June 3rd at Huntington Beach? Can't wait to run with you guys again!
Clay
Old 06-24-2011, 03:20 AM   #2260
Jspeed's Avatar
GT8 Class--buggy-based on road electric!-ipanema-41mm-47mm-wide-gt-slicks-1.jpg   GT8 Class--buggy-based on road electric!-ipanema-41mm-47mm-wide-gt-slicks-2.jpg   GT8 Class--buggy-based on road electric!-ipanema-41mm-47mm-wide-gt-slicks-3.jpg
Jspeed is offline   Reply With Quote
Old 06-24-2011, 10:53 AM   #2261
Originally Posted by Jspeed View Post
Nice AD.... Why don't you just put prices and sell direct??
MUGEN RACING
TC Hobby's
Old 06-24-2011, 10:57 AM   #2262
Any update to the wide treaded?
Joat is offline   Reply With Quote
Old 06-24-2011, 11:11 AM   #2263
Jspeed's Avatar
Our "Road Stars" are expected next month, thanks.
Old 06-24-2011, 01:25 PM   #2264
How many GT8's are going to the race this week end at G.R.A.L.R.C. Nitro or electric??
MUGEN RACING
TC Hobby's
Old 06-24-2011, 02:46 PM   #2265
Raman's Avatar
Trader Rating: 54 (100%+)
I can't make it.. I'm baby sitting a guest from Italy.. He's non RC related.. So no track time
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
