Old 05-04-2011, 11:34 AM   #1696
simplechamp's Avatar
Trader Rating: 73 (100%+)
Originally Posted by SuperEk4 View Post
Is that a nexx8?
It's a Jammin X2, so it shares almost all the same parts. I just used Nexx8 lipo trays.
You can bolt Inferno GT shock towers right up to the Jammin/Nexx8 bulkheads. Then you can also use the Inferno GT body mounts and bumpers. That is what I did.
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 05-04-2011, 11:49 AM   #1697
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
Originally Posted by kcunamay View Post
Hey Raman,
I hope to see you in Corona on the 15th. Now that you've got your ludacris speed settings on your ESC figured out, we should have a blast! I'm hearing GT8E will have a large group of racers in attendance. Can't wait!
Steve N, be ready bro!!! We will be. LOL
I am ready I hope you are it no fun lapping you twice in the qual.
SNR Graphite is offline   Reply With Quote
Old 05-04-2011, 11:53 AM   #1698
Hey you guys with the GTP2e that want to run the 360mm Kyosho bodies I just came out with CF chassis so can convert it. I will post some pictures later.
STEVE
Old 05-04-2011, 12:43 PM   #1699
Raman's Avatar
Trader Rating: 49 (100%+)
Hey Raman,
Corona... I'm still having nightmare about that light post at the end of the back straight lol.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-04-2011, 01:00 PM   #1700
Old 05-04-2011, 02:45 PM   #1701
Suspended
Any email address?
mark@mugenracing.com
s.l.c. is offline   Reply With Quote
Old 05-04-2011, 10:28 PM   #1702
i am stuck..i finally finished my OFNA DM-1 brushless conversion and now I can not get my servo breaks to work. I am running the Spektrum DX3R Transmitter with the spectrum DSM2 micro receiver and the tekno RX8 ESC. Can anyone help me. This thing is crazy fast but I have no breaks right now.
I also had my low gear pinion pop off 2 times will testing but I think it is from having no breaks and the ESC wanting to use its built in breaks/reverse programming.
I have turned my reverse down to 0 on my transmitter so it will no go to reverse.
any help will be greatly appreciated...im trying to get this things 100% by tomorrow
ToxicRC is offline   Reply With Quote
Old 05-05-2011, 03:03 AM   #1703
kcunamay's Avatar
Trader Rating: 20 (100%+)
lol. no fun getting lapped either. hahaha. The main was more fun though! We should be able to battle in both qualifiers as well as the main this time around. Looks like the SD crew will be coming out in force! Can't wait.
Forget shock springs, oil, diff weight, camber, caster, toe, droop, ride height, etc....
The single biggest change you can do for the GT8E cars is TIRES!!!!
Believe that.
2 seconds off the mark last time out. Quick change of tires and was instantly in the game.
How do you guys feel about running a spec tire? I believe that is the great equalizer. Driving/setup skills would play a huge role, vs whose car has the correct tires for the day and is able to lay down the power.
I'll post it in OC CIRCUIT's thread to ask the GT8E guys that we run with.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 05-05-2011, 04:03 AM   #1704
whipnet's Avatar
I was hoping you had a Fubtaba and I could tell you exactly how to do it. But you have to setup channel mixing between channel 3 and your throttle channel.
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 05-05-2011, 06:46 AM   #1705
Thats what i was trying to do but its not working out right and the manual is not helping much. I will call spektrum support today and see what I can get done.
DId you ever have any issues with the pinions spinning off?
Old 05-05-2011, 06:57 AM   #1706
whipnet's Avatar
I have not had any issues with the 2speed bell. I thought it spun in the direction that would tighten the gears. A little loctite should help.
If we meet up at Mike's tomorrow, we can take a look and see what's going on. I usually bring tools.
Old 05-05-2011, 07:11 AM   #1707
i just got off the phone with spektrum and found my silly error for the brake servo. I was setting it up right but forgot I set my reverse throttle to 0%. Brakes check good.
Is your RX8 ESC still programmed for forward/brake/reverse?
I want to just program it for forward/brake.
The gears are set up to tighten with the way the car moves forward but i had mine fall off when i was turning and the car rolled backwards for a second. and the 2nd time was when I hit 2nd gear. Still under testing but making progress. I added a lil loctite to the screw for the CB and to the lower gear. My 2nd gear is pretty snug but we will see what it does when i test it again.
Old 05-05-2011, 07:12 AM   #1708
clayrace24's Avatar
Trader Rating: 40 (100%+)
Default Tires for Corona
Is there a consesus on the best tires to run in Corona? Next best?
Clay
clayrace24 is offline   Reply With Quote
Old 05-05-2011, 07:20 AM   #1709
whipnet's Avatar
I mentioned turning off the reverse in our conversation last night.
Glad you got it!
I have reverse and speed control braking turned off (brakes you just set to 0) All you need is forward.
Did you adjust your transmission any for the 2speed shift? I have not heard mine shift unless it is doing it very early on. I know it's running in 2nd, because I can hit over 60mph on 4s. I just need to look at mine, but it hasn't been a problem (so much torque), so I have not yet.
Old 05-05-2011, 07:22 AM   #1710
just finished programming my forward/brake only..things are looking good. I will post a pic in just a min of the setup. No body on yet
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
