Old 04-25-2011, 08:04 AM   #1636
Originally Posted by Dasmopar View Post
I thought his car looked really stable in the first two rounds. Then as the track warmed up his tires went away or his set-up changed? Not sure since I didn't talk to Russ much about it. He did mention he thought the foam on the track from the foam tire cars might have been a issue also?
On my next post you can see foam balls that were sticking to my tires.
I've seen this at other on road tracks both carpet and asphalt when foam and rubber are used on the same day.
Before the gas guys got there Al & I (both with the same tires 45s) had good traction and as the day went on it seemed to go away or get weird, I'm not sure which.
I need to run there more to get a feel for the track.
Lazer Guy is offline   Reply With Quote
Old 04-25-2011, 08:13 AM   #1637
I found it strange that I was able to race 27s tires on my 1/10th Mod car, I have never been able to run that soft of a tire without overheating them.
I made 2 changes to the GT car, took some droop out of the front & it gave me more steering but the back end was too loose.
I made the rear links longer at the hub, that made the rear looser.
GT8 Class--buggy-based on road electric!-p4240759.jpg   GT8 Class--buggy-based on road electric!-p4240757.jpg
Old 04-25-2011, 08:26 AM   #1638
Originally Posted by kcunamay View Post
I'm curious to see the laptimes for nitro vs electric running at the same time on the track. From what I have observed/experienced, although the top end during race conditions are similar, the acceleration favors the electric cars.
I also believe that the firmer shore ratings will help tremendously for hooking up with the GT8E cars. I believe they will be available soon. I can't wait to try them.
Only have a lap time from last year
Das ran 24.2
Give me a week or 2 and I think i can beat that but it wont be by much
Desoto Racing, Serpent America, Novarossi, KoPropo, Xceed.
2011, 2013, 2 Time Midwest Series 1/8th Open, Champion
2011 Byrons onroad 1/8th Open 3rd
2011 Roar Nats 1/8th Open, 5th
2012 GLC 1/8th Open Q7 Finish 5th, 2013 GLC 1/8th Open Q4 Finish 7th
Vector03cobra is offline   Reply With Quote
Old 04-25-2011, 08:29 AM   #1639
Originally Posted by Lazer Guy View Post
I found it strange that I was able to race 27S tires on my Mod car, I have never been able to run that soft of a tire without overheating them.
I made the rear links longer at the hub, I could not get a feel for the track, just seemed weird
What shore are those tires ?
Old 04-25-2011, 08:41 AM   #1640
45s on my gt8.
Jspeed
Are my tires to soft ?? Is that why I have the feathering ??
Everybody was very helpful Saturday !!!! Thank you all very much !!!!
I had a good time :-)
Old 04-25-2011, 12:15 PM   #1641
Jspeed's Avatar
45s on my gt8.
Jspeed
It sure looks that way, if not too soft a shore for your heavier E-GT car, you're getting a lot of wheel spin and cooking the rubber a little.
Also looking at the tire pictured, most of the "gatoring" seems to be towards the outside of the slick; meaning a little more negative camber is needed. It would also reduce the heat on the slick's edge and distribute it a little more even across the surface area.OK
Jspeed is offline   Reply With Quote
Old 04-25-2011, 12:24 PM   #1642
kcunamay's Avatar
Trader Rating: 20 (100%+)
I found it strange that I was able to race 27S tires on my 1/10th Mod car, I have never been able to run that soft of a tire without overheating them.
Looking at the pic, I believe that is tire degradation. We have 0 racers using foam on our local track and my tires looked like yours. I believe it to be a result of too soft of a shore for the temps they were used on. I'd love to try some 60 shore compounds with FIRM inserts for GT8E in the upcoming tripple digit temps we experience at our track.
Since the electric cars are generally heavier than their nitro counterparts and have instant availability of monster torque, I believe it is much easier to overdrive the tires given the same shore rating.
GT8E is pretty new to most, so getting the tires, setups and etc perfect is all happening as we type. In time we should have a multitude of great references to use as starting points. Great thing we have this thread to document it.
Jai Cunamay - Racing 1 class sucks.
kcunamay is offline   Reply With Quote
Old 04-25-2011, 01:24 PM   #1643
I tried, Sweep 45 exp out of the package. no custom foam,
They sucked. push like crazy and never did warm up car was lose the hole run.
An other guy there had sweep's no idea what tire with custom foam they worked really well.
PMT tires work ok and I turned my best laps on them. but they are a handful the first 2 mins then they start to work about as good as the guy with the custom sweeps.
in the 3rd round Custom sweeps turned in a 24.56 and I turned in a 24.52
Air temp is 65-69 cool breeze
track prep is water and pop syrup.
Going to try sime Impinama's this week I hope, I will report my results.
Old 04-25-2011, 03:57 PM   #1644
1/8th and 1/10th nitro racers get 2 to 3 minutes on the track to warm up engines and tires, maybe a few laps to warm the tires would help.
williamw is offline   Reply With Quote
Old 04-25-2011, 04:11 PM   #1645
I have been doing 2 laps myself with a lot of scrubbing before the start.
2-3 mins of running isnt really ideal. not yet anyways.
5000 Mah is good for about 9:30 of run time. maybe a bit more.
Old 04-25-2011, 04:55 PM   #1646
rcwck's Avatar
[QUOTE=Vector03cobra;9016737]in the 3rd round Custom sweeps turned in a 24.56 and I turned in a 24.52(QUOTE]
Don't exaggerate Jeff. You only did a 24.54 lap and you shorted the Klunk dude too. Careful, I be watching. lol
rcwck is offline   Reply With Quote
Old 04-25-2011, 06:27 PM   #1647
[QUOTE=rcwck;9017746]
LOL look at that again 24.52...=Zuke
Going to make for some great races. keep us both working for the win.
Duratrax
Old 04-25-2011, 06:36 PM   #1648
Rcwck = Klunk = Yellow car
Vector=Zuke=Monster car
Team Duratrax leading the race 1, and 2
I am following waiting for tires to warm up.
GT8 Class--buggy-based on road electric!-215993_1762745665628_1148689881_31574095_507737_n.jpg
Old 04-25-2011, 09:47 PM   #1649
Jspeed's Avatar
After looking at the heat build up in the pictures posted above, maybe the 50 shores would work much better than 45s. In the summer E-GT cars might want to use of 55 to 65 shore ratings, like Jai said in his post we'll have to learn this together.
Old 04-25-2011, 10:43 PM   #1650
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Alright another forum dude!!! Just need to figure out that quote button. lol
Lon Burling II
Capicorn, Serpent America, Novarossi, Enetti tires
Chicky fan club member #11
Dasmopar is offline   Reply With Quote
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
