Old 04-12-2011, 07:50 AM   #1561
anyone running 5s lipos on their rides? If so what size mAh and C rating do you have?
I have these 3 right now..
8000mAh 5s 30C
5000mAh 5s 40C
4000mAh 5s 30C
I will be running the tekin RX8/T8 1700kv system. Any gearing recommendations?
I arrive home in about 12 days and this project will begin!
I also went ahead and bought the single speed conversion kit Fangs posted up incase I ever want to change out my 2 speed.
ToxicRC is offline   Reply With Quote
Old 04-12-2011, 12:12 PM   #1562
Raman's Avatar
Trader Rating: 51 (100%+)
8000mAh 5s 30C
5000mAh 5s 40C
4000mAh 5s 30C
I run 5s 5000 mah with 1700kv motor. Gearing is 44T/ 16T. To cut down on torque (theres an sh*t load with 1700kv and 5S) I had set the current limit my rx8 really high, side effect was a lot of lag on the infield. I turned it off and now I'm going to try to learn to be smooth on the throttle instead of electronic assistance.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 04-12-2011, 12:18 PM   #1563
whipnet's Avatar
The Tekno Elektri-Clutch makes it smooth as butter if you haven't tried one yet. I am thinking about getting one for all of my BL rigs. (Of course you will need mech brakes)
Beat Your RC Like It Owes You Money!!
http://www.RCCOH.com
whipnet is offline   Reply With Quote
Old 04-12-2011, 12:31 PM   #1564
Raman's Avatar
Techno clutch = new motor mount, adding a brake servo, making mount for servo.. Roughly an additional $100.. Prefer to keep it simple and learn to use the throttle more smoothly. Will benefit me in the long run
Old 04-12-2011, 01:11 PM   #1565
thanks for the info Raman. You must be running a single speed tranny. I know I will have alot of testing to do with my ESC programming and gearing selection to get the performance I want.
After talking with Whipnet I learned I needed a 3 channel Transmitter so I decided I would treat myself to a top performing TX/RX system. I have never used anything better then stock traxxas 2.4ghz. I ended up with the new Spektrum DX3R Pro kit.
I am just counting my days now...14 days
Old 04-12-2011, 05:04 PM   #1566
blueryu's Avatar
Default IGT2 Carbon Fiber Chassis
Hey all,
I am making carbon fiber chassis for a few who are interested. Refer to this thread for details.
Kyosho Inferno GT2 Carbon Fiber Chassis Brushless Conversion Kit
PM me if interested.
Thanks!
Crux Components
email: cruxcomponents@live.com
web: www.cruxrc.com (coming soon)
blueryu is offline   Reply With Quote
Old 04-12-2011, 05:23 PM   #1567
Missle's Avatar
Originally Posted by blueryu View Post
Hey all,
Thanks!
I applaud your desire to make a better product, but at a cost of $200, why not just get a CF kit that's already produced. For example, I believe Max Velocity (or something like that) already has one that's like $120
Missle is offline   Reply With Quote
Old 04-12-2011, 05:30 PM   #1568
Missle's Avatar
hey,
do you have any pics of the part you broke? and links to HPI parts used?
I bought both the HPI assembled diff set #86127 (for the savage) as well as the alluminum alloy diff case # 86827 (also for the savage. I could've just got the aluminum diff case and the output cups, but then I would've had to order the larger inner diameter bearings (the HPI bearings have a larger inner diameter but same outer diameter) so it's actually cheaper to just get both. The diff set was $35 and the aluminum diff case was $12 so all together $47. Not bad considering it fits much better (the end to end lenght is approx 4mm longer so much less play in the front axels) and the case in stronger.
Old 04-12-2011, 06:17 PM   #1569
blueryu's Avatar
There are many who will share your sentiment. My products will only be affordable by small percentage of industry and i am ok with that. MV carbon chassis is $150 and is only capable of nitro and perhaps the Kyosho conversion kit, although they show no pics of it working as a conversion. My kit allows more tuning options, it is specific to brushless, and includes battery tray. The price is comparable. I am sure MV makes great products and with no disrespect to MV i would wager that if set side by side, brushless racers would choose my product. Thanks for your encouragement though.
Crux Components
Old 04-12-2011, 09:13 PM   #1570
FangsCPO's Avatar
I was wondering if I should go with the tekin 5.5 or 6.5mm bullets for my ESC to battery connection..or if anyone has recommendations to connectors better then the Deans.
You don't need the bullets unless you plan on switching your motor back and forth between rigs. Just solder the motor to the ESC directly and that will reduce the amount of resistance. I recommend you use Traxxas Plugs, they can handle the heavy loads this rigs produce. Just my .02.
Here's a photo of my rig:
Losi 5ive-T - OBR G320RC "Reed" 31.5cc Full Mod
Losi 5ive-T - "2WD PRO2" OBR G290RC 30.5cc Full Mod
Losi 5ive-B - OBR G320RC 31.5cc Full Mod
OBR/TR Core Team Driver
TLR Team Driver
FangsCPO is offline   Reply With Quote
Old 04-12-2011, 09:54 PM   #1571
whipnet's Avatar
What rear chassis brace is that Fangs? Yours is a lot shorter than mine and appears to fit. I had to modify my chassis to get mine to work.
Old 04-12-2011, 10:10 PM   #1572
Matthew_Armeni's Avatar
Trader Rating: 31 (100%+)
This is the chassis brace you want.
Tekno RC
Matthew_Armeni is offline   Reply With Quote
Old 04-12-2011, 10:21 PM   #1573
FangsCPO's Avatar
I think this is what you are asking about: OFN40578
http://www.nitrohouse.com/Car-Hop-Up...duct_info.html
TLR Team Driver
Old 04-12-2011, 10:30 PM   #1574
FangsCPO's Avatar
If you use Traktion Drive, you can use either mechanical brakes or motor brakes.
If you use Eletri-Clutch, you need to use mechanical brakes. Motor brakes, will not work.
It is added cost but it will definitely help you contain your motor temps down even more during the hot summer months.
TLR Team Driver
Old 04-12-2011, 10:32 PM   #1575
FangsCPO's Avatar
8000mAh 5s 30C
5000mAh 5s 40C
4000mAh 5s 30C
Check out page 3 for recommendations on kv vs lipo cells. You want right answers, you go to the best source for information......Tekno!!!
http://www.teknorc.com/images/V4_instructions_losi.pdf
TLR Team Driver
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
SS Raceway in Tampa Rojna Florida Racing 5042 07-15-2014 12:03 AM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 495 10-08-2010 03:55 PM
2008 BLUE DIAMOND/G FORCE ONOAD SCENE spurcheck Racing Forum 1772 04-16-2009 09:39 AM
